查看: 3680|回复: 5
按dxf的格式写dxf文件!
发表于 2003-3-26 09:46:00 | 显示全部楼层 |阅读模式
我现在有点线面的等图元的坐标文件,我想直接按dxf的格式去生成DXF,请问除了entities块中外,其他的五大块我应该注意那些事项,谢谢!
发表于 2003-7-16 15:17:00 | 显示全部楼层
其他五大块可以不管他!
发表于 2003-8-9 17:12:00 | 显示全部楼层
好像光实体段还不能完全解决问题,线型,线宽就不好解决。
发表于 2004-3-18 23:29:00 | 显示全部楼层
Hi, Below is my experience: header section, settings of variables associated with the drawing, ie. drawing size. table section, can setup line type, text style, layer, ... block, can be ignored class, can be ignored, application-defined classes entities, meat are here object, can be ignored, nongraphical objects
发表于 2007-2-5 19:07:00 | 显示全部楼层
网上找到的
'Build the header, this header is set with my personal preferences
Private Function DXF_Header() As String
Dim HS(19) As String
    HS(0) = "  0|SECTION|  2|HEADER|  9"
        HS(1) = "$ACADVER|  1|AC1009|  9"
        HS(2) = "$INSBASE| 10|0.0| 20|0.0| 30|0.0|  9"
        HS(3) = "$EXTMIN| 10|  0| 20|  0| 30|  0|  9"
        HS(4) = "$EXTMAX| 10|368| 20|326| 30|0.0|  9"
        HS(5) = "$LIMMIN| 10|0.0| 20|0.0|  9"
        HS(6) = "$LIMMAX| 10|100.0| 20|100.0|  9"
        HS(7) = "$ORTHOMODE| 70|     1|  9"
        HS(8) = "$DIMSCALE| 40|8.0|  9"
        HS(9) = "$DIMSTYLE|  2|STANDARD|  9"
        HS(10) = "$FILLETRAD| 40|0.0|  9"
        HS(11) = "$PSLTSCALE| 70|     1|  0"
    HS(12) = "ENDSEC|  0"
    HS(13) = "SECTION|  2|TABLES|  0"
        HS(14) = "TABLE|  2|VPORT| 70|     2|  0|VPORT|  2|*ACTIVE| 70|     0| 10|0.0| 20|0.0| 11|1.0| 21|1.0| 12|50.0| 22|50.0| 13|0.0| 23|0.0| 14|1.0| 24|1.0| 15|0.0| 25|0.0| 16|0.0| 26|0.0| 36|1.0| 17|0.0| 27|0.0| 37|0.0| 40|100.0| 41|1.55| 42|50.0| 43|0.0| 44|0.0| 50|0.0| 51|0.0| 71|     0| 72|   100| 73|     1| 74|     1| 75|     0| 76|     0| 77|     0| 78|     0|  0|ENDTAB|  0"
        HS(15) = "TABLE|  2|LTYPE| 70|     1|  0|LTYPE|  2|CONTINUOUS|  70|     0|  3|Solid Line| 72|    65| 73|     0| 40|0.0|  0|ENDTAB|  0"
        HS(16) = "TABLE|  2|LAYER| 70|     3|  0|LAYER|  2|0| 70|     0| 62|     7|  6|CONTINUOUS|  0|LAYER|  2|CLOCK_FACE| 70|     0| 62|     7|  6|CONTINUOUS|  0|LAYER|  2|DEFPOINTS| 70|     0| 62|     7| 6|CONTINUOUS|  0|ENDTAB|  0"
        HS(17) = "TABLE|  2|VIEW| 70|     0|  0|ENDTAB|  0"
        HS(18) = "TABLE|  2|DIMSTYLE| 70|     1|  0|DIMSTYLE|  2|STANDARD| 70|     0|  3||  4||  5||  6||  7|| 40|1.0| 41|0.18| 42|0.0625| 43|0.38| 44|0.18| 45|0.0| 46|0.0| 47|0.0| 48|0.0|140|0.18|141|0.09|142|0.0|143|25.4|144|1.0|145|0.0|146|1.0|147|0.09| 71|     0| 72|     0| 73|     1| 74|     1| 75|     0| 76|     0| 77|     0| 78|     0|170|     0|171|     2|172|     0|173|     0|174|     0|175|     0|176|     0|177|     0|178|     0|  0|ENDTAB|  0"
    HS(19) = "ENDSEC|  0|"
    DXF_Header = Join$(HS(), "|")
End Function
发表于 2012-2-6 04:31:39 | 显示全部楼层
读写 dxf谁能提供 可直接调用的源码啊
GMT+8, 2025-5-25 05:24 , Processed in 0.205377 second(s), 24 queries , Gzip On.
