查看: 2937|回复: 5
[求助][VBA]如何创建块
发表于 2006-8-21 21:15:00 | 显示全部楼层 |阅读模式
请指点,如何把选择集里的对象转换为块?
发表于 2006-8-23 10:13:00 | 显示全部楼层
'Re: Creating a Block from a Selection set
'P.Murali
Sub newblk()
Dim obj() As Object
Dim ss As AcadSelectionSet
Dim blk As AcadBlock
Set ss = ThisDrawing.SelectionSets.Add("ss_SET")
ss.SelectOnScreen
pt = ThisDrawing.Utility.GetPoint(, "Pick an insertion point: ")
ReDim obj(0 To ss.Count - 1) As Object
For i = 0 To ss.Count - 1
Set obj(i) = ss.Item(i)
Next i
Set blk = ThisDrawing.Blocks.Add(pt, "MYBLOCK")
ThisDrawing.CopyObjects obj, blk
'you can delete the original items after this
ss.Delete
End Sub
发表于 2007-9-25 08:12:00 | 显示全部楼层
请问如何用 VBA编程创建 块对象哪?
发表于 2007-9-25 09:06:00 | 显示全部楼层
上面的程序就是
发表于 2016-9-19 23:27:04 | 显示全部楼层
alin 发表于 2007-9-25 09:06
上面的程序就是
NUBILITY
发表于 2016-9-19 23:28:59 | 显示全部楼层
上面的程序就是
NUBILITY
GMT+8, 2025-5-26 00:55 , Processed in 0.185980 second(s), 23 queries , Gzip On.
