查看: 5919|回复: 8
Raster design 2007的破解???
发表于 2006-8-21 20:55:00 | 显示全部楼层 |阅读模式
我下了一个 raster design 2007 的破解!
1. Install the software. Disable Samples and tutorials.
2. After installation, copy RasterDesign2007\AeciAdlmDll50.dll to <Installation Directory>\Raster Design 2007\
   and overwrite the original one.
3. Run RegEdit.exe, locate at HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk, and find Add-Ons\RasterDesign\AdLM,
   change the value of "Type" from 0x2a to 0x19,
   e.g. installation of RasterDesign with AutoCAD, the location is
   [HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R17.0\ACAD-5001:409\Add-Ons\RasterDesign\AdLM].
4. Setup Flexlm License Server with the files in the supplied FlexLM directory.
5. Input 2080@your_server_host_name or just point to license.lic while the license is requested.
That is all and enjoy it!
上面是他们破解教的方法,但是到第四和第五步我就不理解拉!
请各位大侠指教!!!
raster design 2007 的下载网址是:
http://www.yxzxz.org/Show/21036.asp
发表于 2006-8-29 08:40:00 | 显示全部楼层
第四步与第五步是安装license管理器,与ARCGIS的安装是一样的,可我按它说的安装了,还是没用,启动后说:D:\Program Files\Raster Design 2007\AeciUi50.arx 无法找到所需的动态链接库或其他文件。可有高手指点一、二!?
发表于 2006-10-18 14:43:00 | 显示全部楼层
我用的好好的啊!
发表于 2006-10-18 16:22:00 | 显示全部楼层
这个东西有什么新的功能没有?
我现在用2000,windows字体不能转成图像。晕
发表于 2006-10-27 13:54:00 | 显示全部楼层
有没有VPSTUDIO8的破解呀大家?
发表于 2006-11-5 10:10:00 | 显示全部楼层
应该可以用的吧  谢谢楼主了
发表于 2007-12-31 19:36:00 | 显示全部楼层
如何破解RasterDesign2008?有破解文件和说明,说明如下,就是操作不好,破解不成,求助。
1. Install Raster Design as network version (with network license support)
2. Create "c:\flexlm" folder and copy "adesk.dat" there
3. Change "this_host" in "adesk.dat" to your PC host name
4. Run "lmtools.exe" from autodesk network license support, check/create
   and run the service as shown in "readme.gif"
5. Check/create environment variable ADSKFLEX_LICENSE_FILE
   It must have the value: c:\flexlm\adesk.dat
6. Overwrite "AeciAdlmDll51.dll" to Raster Design folder
7. Don't forget to reboot PC :)
PS: Use serial 666-66666666 in Raster Design "About" -> "Product information..."
    "Update..." -> menu.
发表于 2009-4-12 01:28:00 | 显示全部楼层
能提供个破解文件不?
发表于 2009-4-15 13:44:00 | 显示全部楼层
你好,请问下你的Raster Design在哪下载的啊?
GMT+8, 2025-5-1 14:30 , Processed in 0.172587 second(s), 29 queries , Gzip On.
