查看: 1958|回复: 1
请各位帮忙
发表于 2006-8-10 12:54:00 | 显示全部楼层 |阅读模式
提示 用户选择两个点,将两点联成直线
为何不能实现啊 ,代码如下:
ads_point startPt, endPt;
 acedGetPoint(NULL,"\nLocate start point : ", startPt);
 acedGetPoint(NULL,"\nLocate end point : ", endPt);
  AcDbLine *pLine = new AcDbLine(startPt,endPt);
//error C2664: '__thiscall AcDbLine::AcDbLine(const class AcGePoint3d &,const class AcGePoint3d &)' : cannot convert parameter 1 from 'double [3]' to 'const class AcGePoint3d &'
        Reason: cannot convert from 'double [3]' to 'const class AcGePoint3d'
        No constructor could take the source type, or constructor overload resolution was ambiguous
请各位帮忙指点一二
发表于 2006-8-13 23:09:00 | 显示全部楼层
第一点,AcDbLine接受的不是ads_point而是AcGePoint3d,要把ads_point 转换为AcGePoint3d,可以这样写:
(假定 ads_point s;AcGePoint3d p;)
p.set(s[0],s[1],s[2]);
但是你得程序可以有更快的写法:
AcDbLine *pLine = new AcDbLine(*(AcGePoint3d*)startPt,*(AcGePoint3d*)endPt);
第二点,你必须把你的图元加入到数据库中才行,这个可以参考SDK上的写法:
 AcDbBlockTable *pBlockTable;
  acdbHostApplicationServices()->workingDatabase()
   ->getSymbolTable(pBlockTable, AcDb::kForRead);
  AcDbBlockTableRecord *pBlockTableRecord;
  pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,
   AcDb::kForWrite);
  pBlockTable->close();
  AcDbObjectId lineId;
  pBlockTableRecord->appendAcDbEntity(lineId, pLine);
  pBlockTableRecord->close();
  pLine->close();
GMT+8, 2025-5-23 13:06 , Processed in 0.230069 second(s), 23 queries , Gzip On.
