查看: 3113|回复: 3
.NET编程求出四个端点组成的两条直线的相交点
发表于 2006-8-6 14:22:00 | 显示全部楼层 |阅读模式
 '''求出两直线的交点
    Public Function inters(ByVal p1 As Point3d, ByVal p2 As Point3d, ByVal p3 As Point3d, ByVal p4 As Point3d, Optional ByVal type As Boolean = True) As Point3d
        If Math.IEEERemainder(Math.Abs(getangle(p1, p2) - getangle(p3, p4)), Math.PI) = 0 Then
            Return Nothing
        End If
        Dim a1, a2, b1, b2, c1, c2, c3, x1, x2, y1, y2, x, y, z As Double
        Dim lp As Point3d
        x1 = p1.X
        y1 = p1.Y
        x2 = p3.X
        y2 = p3.Y
        a1 = p2.Y - p1.Y
        b1 = p2.X - p1.X
        a2 = p4.Y - p3.Y
        b2 = p4.X - p3.X
        c1 = a1 / b1
        c2 = a2 / b2
        c3 = (p2.Z - p1.Z) / b1
        x = (y2 - c2 * x2 + c1 * x1 - y1) / (c1 - c2)
        If b1 = 0 Then
            x = p1.X
            c1 = 1.0E+20
            c3 = c1
        End If
        If b2 = 0 Then
            x = p3.X
            c2 = 1.0E+20
        End If
        y = c1 * (x - x1) + y1
        z = c3 * (x - x1) - p1.Z
        If x - x1 = 0 Then
            y = c2 * (x - x2) + y2
        End If
        lp = New Point3d(x, y, z)
        Dim d1, d2, d3, d4, od1, od2, od3, od4 As Double
        d1 = p1.DistanceTo(p2)
        d3 = p3.DistanceTo(p4)
        od1 = lp.DistanceTo(p1)
        od2 = lp.DistanceTo(p2)
        od3 = lp.DistanceTo(p3)
        od4 = lp.DistanceTo(p4)
        If type Then
            Return lp
        ElseIf od1 <= d1 And od2 <= d1 And od3 <= d3 And od4 <= d3 Then
            Return lp
        Else
            Return Nothing
        End If
    End Function
望各位多指点。我没发现只好自已编了一个,但我怕出毛病。
 楼主| 发表于 2006-8-7 22:02:00 | 显示全部楼层
    '''求出两直线的交点
            Return Nothing
        End If
        Dim lp As Point3d
        x1 = p1.X
        y1 = p1.Y
        x2 = p3.X
        y2 = p3.Y
        a1 = p2.Y - p1.Y
        b1 = p2.X - p1.X
        a2 = p4.Y - p3.Y
        b2 = p4.X - p3.X
        c1 = a1 / b1
        c2 = a2 / b2
        If b1 = 0 Then
            x = p1.X
            c1 = 1.0E+20
            c3 = c1
        End If
        If b2 = 0 Then
            x = p3.X
            c2 = 1.0E+20
        End If
        If x - x1 = 0 Then
        End If
        If type Then
            Return lp
            Return lp
        Else
            Return Nothing
        End If
    End Function
自己编的,请大家评评。
 楼主| 发表于 2006-8-22 21:46:00 | 显示全部楼层
望大侠指点。我对自己编的这个东东不放心。呵……如果程序有就太好了。
发表于 2015-3-27 18:07:25 | 显示全部楼层
单一直线还不错,但是遇到复杂的多段线呢?
GMT+8, 2025-5-2 01:09 , Processed in 0.221661 second(s), 23 queries , Gzip On.
