查看: 3008|回复: 1
求助,高手帮忙调试程序
发表于 2006-7-26 15:52:00 | 显示全部楼层 |阅读模式
请高手帮忙调试一下程序,主要是对话框回调时出错,参数太多,不知道原因出在哪
zh:dialog{
  label = "GPS数据转换";
    : boxed_column {
 label = "文件目录";
 : row {
     : button {
  label = "GPS原始数据...";
  key = "name";
  mnemonic = "B";
  width = 8;
  fixed_width = true;
     : edit_box {
  label = "";
  key = "current_name";
  width = 36;
 : row {
     : button {
  label = "输出转换数据...";
  key = "nen";
  mnemonic = "F";
  width = 8;
  fixed_width = true;
     : edit_box {
  key = "path_name";
  width = 36;
  spacer_1;
  :boxed_column{
   label="数据信息";
   :edit_box{
    label="起始桩号 ";
    key="J_0";
    edit_width=15;
    alignment=centered;
   :edit_box{
    label="起始累距 ";
    key="Pss_0";
    edit_width=15;
    alignment=centered;
   :boxed_radio_row{
           key="scgs";
    label="输出格式";
    :radio_button{label="定位数据";key="t1";}
    :radio_button{label="断面数据";key="t2";}
   width=30;
   fixed_width=true;
   alignment=centered;
  spacer_1;
  ok_cancel;
  spacer_1;
 楼主| 发表于 2006-7-26 15:58:00 | 显示全部楼层
数据如下
GMT+8, 2025-5-25 11:16 , Processed in 0.232353 second(s), 24 queries , Gzip On.
