查看: 3045|回复: 3
[ARX]如何用程序暂时隐藏ACAD的菜单和工具条?
发表于 2006-7-14 16:41:00 | 显示全部楼层 |阅读模式
比如文件--》帮助;标准-对象捕获等
发表于 2006-7-15 05:52:00 | 显示全部楼层
ctrl+0
发表于 2010-5-31 14:42:00 | 显示全部楼层
VB开发CAD
Public Declare Function SetMenu Lib "user32" (ByVal hwnd As Long, ByVal hMenu As Long) As Long
Private Sub HIdeMenus_Click() ''隐藏/显示CAD菜单
    On Error Resume Next
    If hMenu <> 0 Then Exit Sub
    If HIdeMenus.Checked = False Then
        cMenu = GetMenu(lHwnd)
        SetMenu lHwnd, 0
        HIdeMenus.Checked = True
    Else
        SetMenu lHwnd, cMenu
    End If
End Sub
Private Sub HideTool_Click()  '隐藏/显示CAD工具栏
    Dim Menugroup As Object
    Dim Toolbar As Object
    Dim i As Integer
    Static CadTools() As Boolean
    If Hidetool.Checked = False Then
        For Each Menugroup In AcadApp.MenuGroups
            ReDim CadTools(1 To Menugroup.Toolbars.Count)
            For Each Toolbar In Menugroup.Toolbars
                i = i + 1
                CadTools(i) = Toolbar.Visible '添加工具栏状态
                Toolbar.Visible = False
            Next Toolbar
        Next Menugroup
        Hidetool.Checked = True
    Else
                i = i + 1
                Toolbar.Visible = CadTools(i)
            Next Toolbar
        Next Menugroup
    End If
End Sub
发表于 2010-6-1 13:58:00 | 显示全部楼层
用COM!不过觉得实用性不大
GMT+8, 2025-5-1 23:21 , Processed in 0.185705 second(s), 24 queries , Gzip On.
