查看: 2682|回复: 9
[原创]标准直齿圆柱齿轮程序
发表于 2006-6-27 10:23:00 | 显示全部楼层 |阅读模式
自己做的一个小程序,与大家共享.
加载后在命令行输入:CW回车
以后按提示输入相关参数.
(defun c:cw ()
  (setvar "cmdecho" 0)
  ;;;获得已知参数
  (setq c (getpoint "\n 请指定标准齿轮中心点<0,0>:"))
  (if (null c) (setq c '(0 0)))
  (setq m (getreal "\n 请指定轮齿模数<2.5>:"))
  (if (null m) (setq m 2.5))
  (setq z (getint "\n 请确定齿数<20>:"))
  (if (null z) (setq z 20))
  ;;;计算齿轮参数
  (setq d (* m z))
  (setq ha m)
  (setq hf (* m 1.25))
  (setq da (+ d ha ha))
  (setq df (- d hf hf))
  (setq db (* d (cos (* (/ pi 180) 20))))
  ;;;计算过程参数
  (setq b (* db 0.5))
  (setq c1 (* da 0.5))
  (setq c2 (* d 0.5))
  (setq c3 (* df 0.5))
  (setq a (sqrt (- (* c2 c2) (* b b))))
  (setq zc1 (* 0.5 (+ a b c1)));;;zc为计算三角形周长的一半
  (setq zc2 (* 0.5 (+ a b c2)))
  (setq zc3 (* 0.5 (+ a b c3)))
  (setq s1 (sqrt (* zc1 (- zc1 a) (- zc1 b) (- zc1 c1))))
  (setq s2 (sqrt (* zc2 (- zc2 a) (- zc2 b) (- zc2 c2))))
  (setq s3 (sqrt (* zc3 (- zc3 a) (- zc3 b) (- zc3 c3))))
  (setq h1 (/ (* s1 2) c1))
  (setq h2 (/ (* s2 2) c2))
  (setq h3 (/ (* s3 2) c3))
  (setq w1 (sqrt (- (* b b) (* h1 h1))))
  (setq w2 (sqrt (- (* b b) (* h2 h2))))
  (setq w3 (sqrt (- (* b b) (* h3 h3))))
  (setq ang (* pi (/ (- (/ 360 (* z 4)) 0.02) 180)))
  (setq ang1 (atan (/ h1 w1)))
  (setq ang2 (atan (/ h2 w2)))
  (setq ang3 (atan (/ h3 w3)))
  (setq z1 (- ang2 ang1))
  (setq z2 (- ang3 ang2))
  (setq a1 (- ang z1))
  (setq a3 (+ ang z2))
  (setq angz (/ (* pi 2) z))
  (setq angs (* a3 2))
  (setq angc (- angz angs))
  ;;;计算绘图点
  (setq b1 (polar c (- 0 a1) c1))
  (setq b2 (polar c (- 0 ang) c2))
  (setq b3 (polar c (- 0 a3) c3))
  (setq p (polar c 0 c1))
  (setq pt1 (polar c (+ 0 a1) c1))
  (setq pt2 (polar c (+ 0 ang) c2))
  (setq pt3 (polar c (+ 0 a3) c3))
  (setq pt4 (polar c (+ 0 angc a3) c3))
  ;;;开始绘制轮齿
  (command "layer" "M" "3中心线" "C" 4 "" "L" "center" "" "")
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  (command "clayer" "0")
  (command "pline" b3 "w" 0 "" "a" "s" b2 b1 "s" p pt1 "s" pt2 pt3 "ce" c pt4 "")
  (command "array" (entlast) "" "p" c z "" "")
  (command "circle" c "d" c2)
  (command "clayer" "中心线")
  (command "circle" c c2)
  (setvar "osmode" os)
发表于 2006-6-27 10:38:00 | 显示全部楼层
啥多没有
发表于 2006-6-28 19:06:00 | 显示全部楼层
怎么不上传附件呀
发表于 2006-6-29 09:50:00 | 显示全部楼层
发贴心情
怎么不上传附件呀
发表于 2006-7-1 16:50:00 | 显示全部楼层
好,谢谢!!!
发表于 2010-11-24 13:27:00 | 显示全部楼层
好,谢谢!!!
发表于 2010-11-25 07:15:00 | 显示全部楼层
感谢楼主分享!
发表于 2011-3-22 03:14:28 | 显示全部楼层
谢谢搂主 分享
发表于 2011-3-22 09:35:34 | 显示全部楼层
不错,收藏,虽然不怎么用到齿轮
发表于 2011-7-9 14:22:09 | 显示全部楼层
多谢分享!!!
GMT+8, 2025-7-25 11:09 , Processed in 0.200719 second(s), 25 queries , Gzip On.
