楼主: caoyin
[求助]怎样获得选择集的中心点
发表于 2006-6-25 19:25:00 | 显示全部楼层
请看看这个,写得有点繁琐,不过还算是完成了...
(Defun C:test (/ ss)
  (VL-LOAD-COM)
  ;; get the selection set    .
  (princ "\nPlease select object:")
  (setq ss (vl-catch-all-apply 'ssget))
  (if (or (vl-catch-all-error-p ss) (null ss))
    (vl-exit-with-value 0)
  ;; get the Middle point from the selection set .
  (setq pt (GetMidPt ss))
  (if pt
    (foreach n (list "\nThe Middle Point X=" (car pt) "  Y=" (cadr pt)) (princ n))
    (princ "\n There is error , can't get the middle point...")
  (prin1)
;; the sub function to get the middle point from the selection set  .
(defun GetMidPt (ss / i lstX lstY vn pt X1 X2 Y1 Y2)
  (setq i    0
 lstX '()
 lstY '()
  (repeat (sslength ss)
    (setq vn (vlax-ename->vla-object (ssname ss i))
   i  (1+ i)
    (setq pt (vl-catch-all-apply 'vla-getBoundingBox (list vn 'MinPt 'MaxPt)))
    (if (not (vl-catch-all-error-p pt))
 (setq X1 (vlax-safeArray-get-element MinPt 0)
       X2 (vlax-safeArray-get-element MaxPt 0)
       Y1 (vlax-safeArray-get-element MinPt 1)
       Y2 (vlax-safeArray-get-element MaxPt 1)
 (cond
   ;; if this is the first time run,then put the value it .
   ((null lstX)
    (setq lstX (list X1 X2)
   lstY (list Y1 Y2)
   ;; NOTE here,  .
   (T
    ;; X-Min .
    (if (< X1 (car lstX))
      (setq lstX (list X1 (cadr lstX)))
    ;; X-Max
    (if (> X2 (cadr lstX))
      (setq lstX (list (car lstX) X2))
    ;; Y-Min .
    (if (< Y1 (car lstY))
      (setq lstY (list Y1 (cadr lstY)))
    ;; Y-Max
    (if (> Y2 (cadr lstY))
      (setq lstY (list (car lstY) Y2))
  ;; return the point  .
  (if lstX
    (list (* (apply '+ lstX) 0.5) (* (apply '+ lstY) 0.5))
    nil
 楼主| 发表于 2006-6-27 10:59:00 | 显示全部楼层
还是楼上的好!学习!
发表于 2009-2-3 15:27:00 | 显示全部楼层
来看看,好像不难得
GMT+8, 2025-7-30 06:36 , Processed in 0.158329 second(s), 19 queries , Gzip On.
