查看: 2351|回复: 3
新手提问,如何运行ARX
发表于 2006-6-22 14:08:00 | 显示全部楼层 |阅读模式
以下代码是ARX2007中地例题,已编译成ARX文件,在ACD2007已经加载
可我如何来查看我运行地结果啊?
先输入这个命令ASDK_MKENTS,然后呢???
谁来帮帮我啊,非常谢谢
#if defined(_DEBUG) && !defined(AC_FULL_DEBUG)
#error _DEBUG should not be defined except in internal Adesk debug builds
#endif
#include <string.h>
#include <aced.h>
#include <dbents.h>
#include <dbsymtb.h>
#include <dbgroup.h>
#include <dbapserv.h>
#include "tchar.h"
AcDbObjectId createLine();
AcDbObjectId createCircle();
void createNewLayer();
void createGroup();
Acad::ErrorStatus changeColor(AcDbObjectId, Adesk::UInt16);
    AcGePoint3d startPt(4.0, 2.0, 0.0);
    AcGePoint3d endPt(10.0, 7.0, 0.0);
    AcDbLine *pLine = new AcDbLine(startPt, endPt);
    AcDbBlockTable *pBlockTable;
    acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pBlockTableRecord;
    pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite);
    pBlockTable->close();
    AcDbObjectId lineId;
    pBlockTableRecord->appendAcDbEntity(lineId, pLine);
    pBlockTableRecord->close();
    pLine->close();
    return lineId;
    AcGePoint3d center(9.0, 3.0, 0.0);
    AcGeVector3d normal(0.0, 0.0, 1.0);
    AcDbCircle *pCirc = new AcDbCircle(center, normal, 2.0);
    AcDbObjectId circleId;
    pBlockTableRecord->appendAcDbEntity(circleId, pCirc);
    pCirc->close();
    return circleId;
    AcDbLayerTable *pLayerTable;
    acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pLayerTable, AcDb::kForWrite);
    AcDbLayerTableRecord *pLayerTableRecord = new AcDbLayerTableRecord;
    pLayerTableRecord->setName(_T("ASDK_MYLAYER"));
 pLayerTable->add(pLayerTableRecord);
    pLayerTable->close();
    pLayerTableRecord->close();
void createGroup(AcDbObjectIdArray& objIds, TCHAR* pGroupName)
    AcDbGroup *pGroup = new AcDbGroup(pGroupName);
    AcDbDictionary *pGroupDict;
    acdbHostApplicationServices()->workingDatabase()->getGroupDictionary(pGroupDict, AcDb::kForWrite);
    AcDbObjectId pGroupId;
    pGroupDict->setAt(pGroupName, pGroup, pGroupId);
    pGroupDict->close();
    for (int i = 0; i < objIds.length(); i++) {
        pGroup->append(objIds);
 pGroup->close();
Acad::ErrorStatus changeColor(AcDbObjectId entId, Adesk::UInt16 newColor)
    AcDbEntity *pEntity;
    acdbOpenObject(pEntity, entId,
        AcDb::kForWrite);
    pEntity->setColorIndex(newColor);
    pEntity->close();
    return Acad::eOk;
void runIt()
    createNewLayer();
    AcDbObjectIdArray idArr;
    idArr.append(createLine());
    idArr.append(createCircle());
    changeColor(idArr.last(), 1);
    createGroup(idArr, _T("ASDK_TEST_GROUP"));
void initApp()
    acedRegCmds->addCommand(_T("ASDK_MAKE_ENTS"),
                            _T("ASDK_MKENTS"),
                            _T("MKENTS"),
                            ACRX_CMD_MODAL,
                            runIt);
void unloadApp()
        acedRegCmds->removeGroup(_T("ASDK_MAKE_ENTS"));
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
        switch (msg) {
        case AcRx::kInitAppMsg:
         acrxDynamicLinker->unlockApplication(appId);
    acrxDynamicLinker->registerAppMDIAware(appId);
                initApp();
                break;
        case AcRx::kUnloadAppMsg:
                unloadApp();
        return AcRx::kRetOK;
发表于 2006-6-22 16:57:00 | 显示全部楼层
上述程序是生成一个直线和一个圆.
程序加栽后,键入命令后,在屏幕上生成一条直线和一个圆.
 楼主| 发表于 2006-6-22 17:06:00 | 显示全部楼层
楼上地,谢谢你啊
问题是这样地,我键入命令ASDK_MKENTS后
上面一点反应都没有,怎么回事呀
 楼主| 发表于 2006-6-22 18:01:00 | 显示全部楼层
我知道了,因为太小太小,看不清楚,放大就看到了,谢谢楼上楼上地啊
GMT+8, 2025-5-7 10:44 , Processed in 0.168983 second(s), 23 queries , Gzip On.
