查看: 3490|回复: 1
关于数据库联结问题
发表于 2006-6-9 08:44:00 | 显示全部楼层 |阅读模式
在VBA中用下列语句连结数据库
      Set conn = New ADODB.Connection
      conn.CursorLocation = adUseClient
      conn.Provider = "Microsoft.Jet.OLEDB.4.0;"
      connstr = "Data Surce=d:\制图\数据库\塔巴庙探井.mdb;"
      conn.Open connstr
但运行时出现错误如下:
     Compile error:
     Can't find project or library
我引用的是Microsoft ActiveX Data Objects 2.5  library
请问如何解决?非常感谢!
发表于 2006-6-30 18:33:00 | 显示全部楼层
菜单 工具 -〉引用-〉Micorsoft Access 11.0 Objects  library 试试
Set Public conn As New ADODB.Connection   '定义新连接
Public cmd As New ADODB.Command     '定义指令
Public rs As New ADODB.Recordset  '定义两个记录集
set conn = New Connection
conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=d:\制图\数据库\塔巴庙探井.mdb"
Set cmd.ActiveConnection = conn
cmd.CommandText = "select * from 表名"
rs.CursorLocation = adUseClient
rs.Open cmd, , adOpenStatic, adLockBatchOptimistic
GMT+8, 2025-5-1 06:00 , Processed in 0.162529 second(s), 25 queries , Gzip On.
