查看: 1776|回复: 4
求助:调试的问题。
发表于 2006-5-27 11:01:00 | 显示全部楼层 |阅读模式
这是我编的一个选取实体来生成block的一段程序,但是当调试运行到:err=acdbGetObjectId(idsel,sget);
跳出上面的Find Symble的 对话框,"Please enter the path for acdbhdr.pdb"不知道什么意思。。。
并且编译以后,在cad中运行并不能生成图块,但是凭我的水平怎么也找不出问题了。
希望哪位大虾能帮帮我,先谢了。
#include "StdAfx.h"
#include "StdArx.h"
#include "resource.h"
#include "dbsymtb.h "
#include "acedads.h"
#include "dbmain.h"
// This is command 'SETLAYER'
void Asdkpblock()
  bool const openErasedEntity = false;
  bool const openErasedRec = false;
  ads_name sget;
  ads_point pt;
  AcDbObjectId idsel;
  AcDbEntity *entsel;
  Acad::ErrorStatus err;
  int rc=1;
  AcDbBlockTableRecord *pSelRec=new AcDbBlockTableRecord;
  pSelRec->setName("firstblock");
  pSelRec->setOrigin(AcGePoint3d(0,0,0));
  while(rc)
   rc=acedEntSel("\nplease select an entity:",sget,pt);
   switch(rc)
   case RTNORM:
    if(err!=Acad::eOk)
     acutPrintf("\n Invalid ads_name.");
     return;
    acutPrintf("\n ObjectId is %s",idsel);
    acdbOpenAcDbEntity(entsel,idsel,AcDb::kForRead,openErasedEntity);
    entsel->highlight();
    pSelRec->appendAcDbEntity(entsel);
    entsel->close();
    acedSSFree(sget);
    break;
   case RTERROR:
    acutPrintf("\n Invalid selection.");
    return;
    break;
   case RTCAN:
    acutPrintf("\n Selection over.");
    rc=0;
    break;
   } //End of switch.
  AcDbDatabase *pcurdb=NULL;
  AcDbBlockTable *pbTable;
  pcurdb=acdbHostApplicationServices()->workingDatabase();
  pcurdb->getBlockTable(pbTable,AcDb::kForWrite);
  pbTable->add(pSelRec);
  pbTable->close();
  pSelRec->close();
发表于 2006-5-29 22:01:00 | 显示全部楼层
我的这个可以点选以生成块,
void test()
 ads_name en;
 ads_point pt;
 int rt=1;
 Acad::ErrorStatus es;
 AcDbBlockTable *pBlockTable;
 acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable,AcDb::kForWrite);
 AcDbBlockTableRecord *pBlk=new AcDbBlockTableRecord;
 es=pBlk->setName("TestBlk");
 es=pBlk->setOrigin(AcGePoint3d(0,0,0));
 while (rt)
  rt=acedEntSel("\nSpecify a object:",en,pt);
  switch(rt)
   case RTERROR:
    break;
   case RTCAN:
    rt=0;
    break;
   case RTNORM:
    AcDbObjectId eId;
    acdbGetObjectId(eId,en);
    AcDbEntity *pEnt=NULL,*pClone=NULL;
    es=acdbOpenAcDbEntity(pEnt,eId,AcDb::kForRead);
    pClone=AcDbEntity::cast(pEnt->clone());
    es=pBlk->appendAcDbEntity(eId,pClone);
    pBlockTable->add(eId,pBlk);
    pEnt->close();
    pClone->close();
    break;
 pBlk->close();
 pBlockTable->close();
 楼主| 发表于 2006-6-3 18:54:00 | 显示全部楼层
呵呵,谢谢,想明白是什么问题了。
还有一个问题是:当在调试模式下面,运行到acdbGetObjectId()时,会跳出一个Find Symble对话框,提示:"Please enter the path for acdbhdr.pdb"  不知道什么意思。。。
不知各位碰到过没有。我选择的 结束 ,没有理它,但是并不影响程序的运行。如果不在调试模式下,就不会出现这个问题。
我用的是vc++6.0和acad2002。
发表于 2006-6-4 20:56:00 | 显示全部楼层
我也不知道,我也是半桶水,应该还没有半桶昵,
我用的也是 VC6+CAD2002的了
有机会一起来学习啊
 楼主| 发表于 2006-6-8 22:55:00 | 显示全部楼层
好啊好啊。。。。
其实觉得学objectarx也不难,有帮助文档就可以啦。现在开始有整体的感觉了。
GMT+8, 2025-5-7 11:03 , Processed in 0.155634 second(s), 24 queries , Gzip On.
