查看: 1628|回复: 7
求助高手!
发表于 2006-5-15 16:27:00 | 显示全部楼层 |阅读模式
程序中我有2个对话框,分别设置2个机构(parallel和aclinic)的参数.当输入命令行输入parallel要调用parallel所对应的对话框!输入aclinic调用aclinic)所对应的对话框!我写的程序调不出来!请教高手指点一下!
                     CAcModuleResourceOverride resOverride;
 char type[100];
 int retCode;
 retCode = acedGetString(1, "\nTo choose frame type[parallel/aclinic]:", type);
 if(retCode = !RTNORM || type[0] == '\0')
  acutPrintf("\nInvalid type name.");
  return;
 if(type == "parallel")
  CWindoParaDlg dlg(CWnd::FromHandle(adsw_acadMainWnd()));
    else if(type == "aclinic")
  CWindoAclDlg dlg(CWnd::FromHandle(adsw_acadMainWnd()));
发表于 2006-5-15 17:59:00 | 显示全部楼层
CWindoParaDlg dlg(CWnd::FromHandle(adsw_acadMainWnd()));//这一句后面要加上下面这一句
[I]dlg.DoModal();[/I]
 楼主| 发表于 2006-5-16 15:51:00 | 显示全部楼层
加了dlg.Modal()还是不行!执行的时候出现异常内部错误!请高手再指点一下
发表于 2006-5-16 20:18:00 | 显示全部楼层
type == "parallel"
改为
strcpy(type,"parallel")
type == "aclinic"
改为
strcpy(type,"aclinic")
就可以了
发表于 2006-5-17 08:34:00 | 显示全部楼层
不应该用strcpy()函数,而应该用strcmp()函数
[U][I]判断而不是拷贝[/I][/U]
发表于 2006-5-17 09:12:00 | 显示全部楼层
 char type[100];
 int retCode;
 if(retCode = !RTNORM || type[0] == '\0'){
  return;
 if(strcmp(type,"parallel")==0){
  dlg.DoModal();
    else if(strcmp(type,"aclinic")==0){
  dlg.DoModal();
 楼主| 发表于 2006-5-17 10:26:00 | 显示全部楼层
谢谢大家了!问题解决了!
发表于 2006-5-18 18:13:00 | 显示全部楼层
搞错了
GMT+8, 2025-5-7 11:08 , Processed in 0.180024 second(s), 24 queries , Gzip On.
