查看: 4771|回复: 9
[LISP]求助:帮我改一个展点程序
发表于 2006-5-14 20:04:00 | 显示全部楼层 |阅读模式
各位大侠,帮我改下这个展点程序,本来是用来将注记展成点的,可是这个程序里面是注记左下角对齐,我想要中心对齐的。不知道我说的名不明白,我的MSN:ivyej11@hotmail,联系我吧。。。谢谢啦。
 楼主| 发表于 2006-5-16 14:10:00 | 显示全部楼层
请各位帮忙~~
发表于 2010-10-21 22:06:00 | 显示全部楼层
     ;LISP展点程序
     ;展1000点:在HP(AMD Athlon64  3000+  256MB)电胶上仅耗时0.142秒;
     ;在金利(Geleron(R) CPU 2.40GHz 256MB)电脑上耗时0.882秒
     ;数据文件格式为:每一点的数据(点号、X、Y、H)为一行,用逗号或空格作为分隔符,即
     ;点号1  X1  Y1 H1   或者 点号1,  X1,  Y1, H1
     ;点号2  X2  Y2 H2   或者 点号2,  X2,  Y2, H2
     ;点号3  X3  Y3 H3   或者 点号3,  X3,  Y3, H3
     ;点号n  Xn  Yn Hn   或者 点号n,  Xn,  Yn, Hn1
(defun c:kszd ()
  (setq ff   (open (getfiled "请选择要展点的数据文件" "" "txt" 2) "r")
 fhb  nil
 t0   (getvar "cdate")
 cm   (getvar "cmdecho")
 os   (getvar "osmode")
 tcm1 "高程注记"
 tcm2 "点记"
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (if (= (tblsearch "layer" tcm1) nil)
    (command "layer" "n" tcm1 "")
  (if (= (tblsearch "layer" tcm2) nil)
    (command "layer" "n" tcm2 "")
  (setq tap 1)
  (while (= tap 1)
    (Progn
      (setq n 1
     fhb nil
      (while (< n 2001)
 (if (setq zb (read-line ff))
   (Progn
     (while (vl-string-search "," zb)
       (setq zb (vl-string-subst " " "," zb))
     (setq zb  (read (strcat "(" zb ")"))
     ;zb  (list (list (nth 2 zb) (nth 1 zb)) (vl-princ-to-string  (last zb)));注记高程
       (vl-princ-to-string (car zb))
        )   ;提示:注记点号请用该行
    fhb (append fhb (list zb))
     (setq n (+ 1 n))
   (setq n   2001
  tap 0
      (setq t1 (getvar "cdate"))
      (setq zb (vl-sort fhb
   '(lambda (e1 e2) (< (car (car e1)) (car (car e2))))
     x0 (car (car (car zb)))
     x1 (car (car (last zb)))
     zb (vl-sort
   fhb
   '(lambda (e1 e2) (< (cadr (car e1)) (cadr (car e2))))
     y0 (cadr (car (car zb)))
     y1 (cadr (car (last zb)))
      (command "zoom" "w" (list x0 y0) (list x1 y1))
      (setq t2 (getvar "cdate"))
      (foreach zb fhb
 (setq zfc (last zb)
     ;pt  (mapcar '+ (car zb) '(1.5 -1.25));这行改为如下
       pt  (car zb)
 (entmake (list '(0 . "TEXT")
         '(100 . "AcDbEntity")
         '(100 . "AcDbText")
         '(62 . 1)
         '(40 . 2.5)
         '(50 . 0.0)
     ;(cons 8 tcm1)   (cons 1 zfc)  (cons 10 pt);这行改为如下
         (cons 8 tcm1)
         (cons 1 zfc)
         (cons 10 (mapcar '+ pt '(1.5 -1.25)))
 (entmake (list '(0 . "POINT")
         '(100 . "AcDbPoint")
         '(62 . 2)
         (cons 8 tcm2)
         (cons 10 pt)
      (setq t3 (getvar "cdate")
     dt1 (* 1000000 (- t1 t0))
     dt2 (* 1000000 (- t3 t2))
      (princ (strcat "读入数据共耗时:"
       (rtos dt1 2 3)
       "秒   展点共耗时"
       (rtos dt2 2 3)
       "秒"
       "展点数:"
       (itoa (length fhb))
       "个  每展一点耗:"
       (rtos (/ dt2 (length fhb)) 2 10)
       "秒\n"
      (setq dt3 (* 1000000 (- t3 t0))
      (princ (strcat "共耗时:"
       (rtos dt3 2 3)
       "秒\n"
  (setvar "cmdecho" cm)
  (setvar "osmode" os)
  (close ff)
发表于 2010-10-21 22:09:00 | 显示全部楼层
这是改进的展点程序,要不展点过20000时太慢
SXYCZPYLHP山西榆次物测院人用半月试验成!!
发表于 2010-10-21 22:11:00 | 显示全部楼层
改进的原理是:分而治之,各个击破,分块解决!!!有同仁欢迎商讨!!
发表于 2010-10-21 22:13:00 | 显示全部楼层
本人邮箱sxyczpylhp@126.com
发表于 2010-10-21 22:14:00 | 显示全部楼层
20101016编成
发表于 2013-1-17 10:35:48 | 显示全部楼层
发表于 2013-6-5 23:29:43 | 显示全部楼层
sxyczpylhp 发表于 2010-10-21 22:06
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;LISP展点程序 &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;展1000点:在HP(AMD Athlon ...
标注的是点号,不是高程
发表于 2015-3-31 21:48:37 | 显示全部楼层
山西省煤炭地质物探测绘院?
GMT+8, 2025-5-1 14:47 , Processed in 0.203381 second(s), 25 queries , Gzip On.
