查看: 5675|回复: 4
AcdbObject::upgradeOpen()出现的问题!
发表于 2006-5-12 20:57:00 | 显示全部楼层 |阅读模式
当用AcdbObject::upgradeOpen()将一个层表记录改为 kforwrite时,提示Acad::eHadMultipleReaders,无法改变其读写的状态
只有用->close()函数关闭层表记录,再执行upgradeOpen() ,操作成功。
是不是运用upgradeOpen() 前必须关闭对象呢?
但是我在另外一个工程中却没有这样的问题,不解!请高手指教,呵呵。。。
发表于 2006-5-12 23:28:00 | 显示全部楼层
Acad::ErrorStatus
upgradeOpen();
If the object is currently open AcDb::kForRead with only one reader, then this function upgrades the object to open AcDb::kForWrite. In the process of changing to open for write, the object is closed, thus triggering any pertinent notification.
Returns Acad::eOk if successful. If the object has more than one reader, then the open status is not changed and Adesk::eHadMultipleReaders is returned. If the object is already open AcDb::kForWrite, then Acad::eWasOpenForWrite is returned. If the object is currently sending notification, then the open status is not changed and Acad::eWasNotifying is returned.
Note  A call of this function does not need to be matched with a call to downgradeOpen(), since a call to close() or cancel() will sufficiently cleanup the entity抯 open state.
注意这个函数中的说明 If the object has more than one reader, then the open status is not changed and Adesk::eHadMultipleReaders is returned
 楼主| 发表于 2006-5-13 12:28:00 | 显示全部楼层
没有啊,层表记录只有在获得层表记录时以kForRead模式打开的,然后马上用upgradeOpen()函数将其改为kForWrite状态。应该是没有问题的。
还有一个问题是:同是这个程序,放在另外一个工程中并没有这样的问题,百思不得其解。
发表于 2006-5-13 17:47:00 | 显示全部楼层
不好意思,我是现在还是菜鸟,还有很多的问题不懂呢....
望有达人们来解决吧
发表于 2006-5-16 13:21:00 | 显示全部楼层
我还未为达人,建议看看帮助文件
GMT+8, 2025-5-7 11:29 , Processed in 0.157564 second(s), 23 queries , Gzip On.
