查看: 4023|回复: 1
[求助][ARX]请问一下关于屏幕刷新?
发表于 2006-5-10 17:42:00 | 显示全部楼层 |阅读模式
readfromfile()
AcDbDatabase *pDb=new AcDbDatabase();
  Acad::ErrorStatus es=pDb->readDwgFile ("e:\\3.dwg");
  if(es!=Acad::eOk)
   acutPrintf("Fail load dwg file.code:1");
   return;
  AcDbBlockTable *pBlockTable;
   es=pDb->getBlockTable (pBlockTable,AcDb::kForWrite );
  if(es!=Acad::eOk)
   acutPrintf("Fail load AcDbBlockTable.code:2");
   return;
  AcDbBlockTableRecord *pBlockTableRecord;
  AcDbObjectId Id;
  es=pBlockTable->getAt ("10",pBlockTableRecord,AcDb::kForRead );
  if(es!=Acad::eOk)
   acutPrintf("Fail found special block!.code:3");
   return;
  else
   acutPrintf("Sucessfully find the block!\n");
   AcDbBlockTableRecordIterator* pBTRIterator;
   es=pBlockTableRecord->newIterator (pBTRIterator);
   if(es!=Acad::eOk )
    acutPrintf("Fail to construct BlockTableRecord Iterator.code:4");
    return;
   else
    int No=0;
    for(pBTRIterator->start ();!pBTRIterator->done ();pBTRIterator->step ())
     AcDbEntity *pEnt;
     int ReadOrWrite=1;
     es=pBTRIterator->getEntity(pEnt,AcDb::kForWrite );
     if(es!=Acad::eOk)
      acutPrintf("Fail to find the Entity in No:%i,.code:5",No);
      return;
     else
      if(ReadOrWrite==1)
      acutPrintf("And it is opened for write!\n");
       // 如果当前实体是以AcDb::kForWrite方式打开的,则要这样做
      pEnt->downgradeOpen();
      pEnt->draw();
      No++;
     }//if
    }//for
    acutPrintf("The Record contain %i blocks!",No);
    // 刷新显示屏幕
    actrTransactionManager->flushGraphics();
    acedUpdateDisplay();
  pBlockTable->close ();
  pBlockTableRecord->close ();
  delete pDb;
  return;
请问我的这段代码为什么刷新不了显示屏啊?
谢谢!
发表于 2014-5-24 19:12:37 | 显示全部楼层
8年了,都没人能解释下吗?8年后的今天,又有新人同问为什么没有效果??
    // 刷新显示屏幕
GMT+8, 2025-5-1 15:01 , Processed in 0.180007 second(s), 24 queries , Gzip On.
