查看: 5912|回复: 4
[求助]求助一个关于扩展数据的问题
发表于 2006-5-5 20:38:00 | 显示全部楼层 |阅读模式
怎么样把以前添加的AutoCAD扩展数据更新成新的或删除
下面是网上找到的清除扩展数据的代码,我看不懂
void delXdata()
    ads_name eNam;
    ads_point pt;
    int ret = acedEntSel ("\nselect an object:", eNam, pt);
    if ( ret!= RTNORM)
         return;
    AcDbObjectId ObjId;
    acdbGetObjectId(ObjId, eNam);
    AcDbEntity *pEnt;
    acdbOpenAcDbEntity(pEnt, ObjId, AcDb::kForWrite);
    resbuf *xdata = pEnt->xData(NULL);
    if (xdata)
         xdata->rbnext = NULL;
         pEnt->setXData(xdata);
         acutRelRb(xdata);
    pEnt->close();
发表于 2006-5-16 19:10:00 | 显示全部楼层
         public void delXdata()
              ads_name eNam;
              ads_point pt;
              int ret = acedEntSel ("\nselect an object:", eNam, pt);   //点选获得一个实体
              if ( ret!= RTNORM)
                   return;
              AcDbObjectId ObjId;
              acdbGetObjectId(ObjId, eNam);    //获得实体的ID
              AcDbEntity *pEnt;
              acdbOpenAcDbEntity(pEnt, ObjId, AcDb::kForWrite);  //通过ObjectID打开实体来编辑
              resbuf *xdata = pEnt->xData(NULL);   //获取实体的扩展数据结果缓冲区链表
              if (xdata)    //如果该扩展数据结果缓冲区链表不为空
                   xdata->rbnext = NULL;  //将该结果缓冲区链表的后续指针置为空
                   pEnt->setXData(xdata); //将该实体的扩展数据设为置为空了的结果缓冲区
                   acutRelRb(xdata);  //释放链表
              pEnt->close();
发表于 2006-5-17 10:13:00 | 显示全部楼层
本想发贴咨询一下在AutoCAD 2007.NET API中,用C#中如何给实体设置XData扩展属性,现就此贴延续一下了,希望能把XData彻底弄清楚。
VC60下的XData的添加方法,Autodesk公司的示例文档中有很好的代码:
void
addXdata()
    AcDbObject* pObj = selectObject(AcDb::kForRead);
    if (!pObj) {
        acutPrintf("Error selecting object\n");
        return;
    // Get the application name and string to be added to
    // xdata.
    char appName[132], resString[200];
    appName[0] = resString[0] = '\0';
    acedGetString(NULL, "Enter application name: ",
        appName);
    acedGetString(NULL, "Enter string to be added: ",
        resString);
    struct  resbuf  *pRb, *pTemp;
    pRb = pObj->xData(appName);
    if (pRb != NULL) {
        // If xdata is present, then walk to the
        // end of the list.
        for (pTemp = pRb; pTemp->rbnext != NULL;
                pTemp = pTemp->rbnext)
    } else {
        // If xdata is not present, register the application
        // and add appName to the first resbuf in the list.
        // Notice that there is no -3 group as there is in
        // AutoLISP. This is ONLY the xdata so
        // the -3 xdata-start marker isn't needed.
        acdbRegApp(appName);
        pRb = acutNewRb(AcDb::kDxfRegAppName);
        pTemp = pRb;
        pTemp->resval.rstring
            = (char*) malloc(strlen(appName) + 1);
        strcpy(pTemp->resval.rstring, appName);
    // Add user-specified string to the xdata.
    pTemp->rbnext = acutNewRb(AcDb::kDxfXdAsciiString);
    pTemp = pTemp->rbnext;
        = (char*) malloc(strlen(resString) + 1);
    strcpy(pTemp->resval.rstring, resString);
    // The following code shows the use of upgradeOpen()
    // to change the entity from read to write.
    pObj->upgradeOpen();
    pObj->setXData(pRb);
    pObj->close();
    acutRelRb(pRb);
问题是在AutoCAD 2007.NET API下:
网上现有的只是关于Xrecord的示例代码,如下:
public ObjectId createXrecord(string name,string salary,string division)
    Database db = HostApplicationServices.WorkingDatabase;
    Transaction trans = db.TransactionManager.StartTransaction();
    try
        BlockTable bt = (BlockTable)MyT.GetObject(db.BlockTableId, OpenMode.ForWrite, false);
        BlockTableRecord br = (BlockTableRecord)MyT.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
        //Create the custom per-employee data
        Xrecord xRec = new Xrecord();
        //We want to add //Name//, //Salary// and //Division// information.  Here is how:
        xRec.Data = new ResultBuffer(
            new TypedValue((int)DxfCode.Text, name),
            new TypedValue((int)DxfCode.Real, salary),
            new TypedValue((int)DxfCode.Text, division));
        //Next, we need to add this data to the //Extension Dictionary// of the employee.
        br.CreateExtensionDictionary();
        DBDictionary brExtDict = (DBDictionary)trans.GetObject(br.ExtensionDictionary, OpenMode.ForWrite, false);
        brExtDict.SetAt("EmployeeData", xRec); //Set our XRecord in the dictionary at //EmployeeData//.
        trans.AddNewlyCreatedDBObject(xRec, true);
        return xRec.ObjectId;
    catch
        return ObjectId.Null;
但为何添加XData扩展数据就会报错eBadDxfSequence呢?
public void addXData(Entity ent,string name,string salary,string division)
            Transaction MyT = db.TransactionManager.StartTransaction();
            try
                BlockTableRecord btr = (BlockTableRecord)MyT.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
                ent.XData = new ResultBuffer();
                btr.AppendEntity(ent);
                MyT.AddNewlyCreatedDBObject(ent, true);
            catch
后来又试过如下方法:
                    Autodesk.AutoCAD.DatabaseServices.SymbolUtilityServices.IsRegAppAcadName("name");
                    pEnt.XData = new ResultBuffer(new TypedValue((int)DxfCode.ExtendedDataRegAppName,"name"));
                    pEnt.XData.Add(new TypedValue((int)DxfCode.ExtendedDataControlString, "this is a test!"));
也报错……为eRegappIdNotFound,应该是因为未注册应用程序名的原因,
求教全局函数acdbRegApp(appName)在C#中的对应方法!!
发表于 2007-7-22 01:43:00 | 显示全部楼层
 public void AddXData()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("添加扩充数据XDATA\n");
            PromptEntityOptions entOps = new PromptEntityOptions("选择要打开的对象\n");
            PromptEntityResult entRes;
            entRes = ed.GetEntity(entOps);
            if (entRes.Status != PromptStatus.OK)
                ed.WriteMessage("选择对象失败,退出");
                return;
            ObjectId objId = entRes.ObjectId;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                Entity ent = trans.GetObject(objId, OpenMode.ForWrite) as Entity ;
                ent.ColorIndex = 1;
                RegAppTable appTbl = trans.GetObject(db.RegAppTableId, OpenMode.ForWrite) as RegAppTable ;
                if (!appTbl.Has("MyAppName"))
                    RegAppTableRecord appTblRcd = new RegAppTableRecord();
                    appTblRcd.Name = "MyAppName";
                    appTbl.Add(appTblRcd);
                    trans.AddNewlyCreatedDBObject(appTblRcd, true);
                ResultBuffer resBuf = new ResultBuffer();//new TypedValue(1001, "MyAppName"), new TypedValue(1000, "开发部门"));
                resBuf.Add(new TypedValue(1001, "MyAppName"));//注册程序名称
                resBuf.Add(new TypedValue(1000 , " Hongxian Qin"));//姓名
                resBuf.Add(new TypedValue(1000 , " 工程部"));//部门
                resBuf.Add(new TypedValue(1040, 2000.0));//薪水
                ent.XData =  resBuf;
                trans.Commit();
发表于 2007-7-22 01:44:00 | 显示全部楼层
        [CommandMethod("GETXDATA")]
        public void GETXDATA()
            ed.WriteMessage("获取扩充数据XDATA\n");
            PromptEntityOptions entOps = new PromptEntityOptions("选择要打开的对象");
            PromptEntityResult entRes = ed.GetEntity(pr);
                return;
            Database db = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                ResultBuffer resBuf = ent.XData;
                if (rb != null)
                    IEnumerator iter = resBuf.GetEnumerator();
                    while (iter.MoveNext())
                        TypedValue tmpVal = (TypedValue)iter.Current;
                        ed.WriteMessage(tmpVal.TypeCode.ToString() + ":");
                        ed.WriteMessage(tmpVal.Value.ToString() + "\n");
GMT+8, 2025-5-22 10:21 , Processed in 0.210987 second(s), 24 queries , Gzip On.
