查看: 1373|回复: 1
arx编译和连接的问题,大家讨论
发表于 2006-4-24 00:11:00 | 显示全部楼层 |阅读模式
我是个初学者,请教个问题
我要做一个文件的打开操作,作成的ARX
编译的时候出错
Compiling...
open.cpp
e:\wd\open\open.cpp(2) : fatal error C1083: Cannot open precompiled header file: 'Debug/open.pch': No such file or directory
Error executing cl.exe.
然后built通过
Compiling resources...
Compiling...
StdAfx.cpp
Compiling...
DocData.cpp
open.cpp
rxdebug.cpp
Generating Code...
Linking...
   Creating library Debug/2open.lib and object Debug/2open.exp
2open.arx - 0 error(s), 0 warning(s)
再编译
Compiling...
Skipping... (no relevant changes detected)
open.cpp
open.obj - 0 error(s), 0 warning(s)
就没有错误了,
但是生成的.arx文件不能加载
2open.arx is incompatible with this version of AutoCAD.
AcRxDynamicLinker failed to load 'E:\WD\open\Debug\2open.arx'
D:\Program Files\AutoCAD 2004\acad.exeUnable to load 2open.arx file.
在哪里出错了呢,我很困惑
发表于 2006-4-24 15:17:00 | 显示全部楼层
ARX的版本和你用的CAD版本不相符. AutoCAD 2004 只能用ObjectArx SDK for 2004
GMT+8, 2025-5-7 13:19 , Processed in 0.158495 second(s), 24 queries , Gzip On.
