查看: 2614|回复: 1
怎样求实体的型心?
发表于 2006-4-23 11:57:00 | 显示全部楼层 |阅读模式
怎样求实体的型心?
发表于 2006-5-27 21:52:00 | 显示全部楼层
应该是质心吧,大哥。给你一个参考一下。
  1. ;;center质心坐标
  2. (defun c:Centroid (/ poly pl ms va reg cen bh center)
  3.   (if (car (atoms-family 1 '("vl-load-com")))
  4.     (vl-load-com)
  5.   )
  6.   ;;判断是否加载vl-load-com
  7.   (setq poly (car (entsel)))
  8.   ;;选择线
  9.   (setq pl (vlax-ename->vla-object poly))
  10.   (setq bh (vlax-curve-isClosed pl))
  11.   (if bh
  12.     (progn
  13.       (setq ms (vla-get-modelspace
  14.    (vla-get-activedocument (vlax-get-acad-object))
  15.         )
  16.      va (vlax-make-safearray vlax-vbObject '(0 . 0))
  17.       )
  18.       (vlax-safearray-put-element va 0 pl)
  19.       (setq reg (car (vlax-safearray->list
  20.          (vlax-variant-value (vla-addregion ms va))
  21.        )
  22.   )
  23.      cen (vla-get-centroid reg)
  24.       )
  25.       (vla-delete reg)
  26.       (setq center (vlax-safearray->list (vlax-variant-value cen)));;质心
  27.     )
  28.   )
  29. )
GMT+8, 2025-5-2 08:11 , Processed in 0.157577 second(s), 24 queries , Gzip On.
