帖子
查看: 1379|回复: 0
固定标注值并改变标注颜色出现的新问题
发表于 2006-4-19 16:44:00 | 显示全部楼层 |阅读模式
Private Sub CommandButton1_Click()
On Error GoTo Err_handle
    Dim FilterType(0) As Integer
    Dim FilterData(0) As Variant
    Dim point As Variant
    Me.Hide
    Set SSdim = ThisDrawing.SelectionSets.Add("S_t_dim")
        FilterType(0) = 0
        FilterData(0) = "DIMENSION"
        SSdim.SelectOnScreen FilterType, FilterData
    If SSdim.Count = 0 Then
        MsgBox "你没有选择标注,程序中止!", vbOKOnly
        ThisDrawing.SelectionSets.Item("S_t_dim").Delete
        End
    End If
    Dim EntityInBlock As AcadEntity
    Dim TextString As String
    Dim Sobj As AcadObject
    Dim BlkId As Double
    For Each Sobj In SSdim
        BlkId = Sobj.OwnerID
        TextString = "123"
        For Each EntityInBlock In ThisDrawing.ObjectIdToObject(BlkId)
            If EntityInBlock.ObjectName = "AcDbMText" Then
                TextString = EntityInBlock.TextString
                Exit For
            End If
        Next
        Sobj.TextOverride = TextString
        Sobj.TextColor = acYellow
    Next
    Exit Sub
Err_handle:
    If Err.Number = -2145320851 Then   '已经存在“S_t_dim”选集
    End If
End Sub
GMT+8, 2025-7-9 19:44 , Processed in 0.193763 second(s), 23 queries , Gzip On.
