查看: 20257|回复: 29
[推荐]ProENGINEER 3.0 Wildfire 野火版(正式版)BT种子
发表于 2006-4-14 23:05:00 | 显示全部楼层 |阅读模式
BT可能已经失效了,下面是电骡的一个链接
http://board.verycd.com/t91936.html
1.45GB
传说中的最新注册机
 楼主| 发表于 2006-4-15 19:18:00 | 显示全部楼层
第二个据说是MAGNiTUDE组织重新做的野火3.0新的破解(无时间限制,全模块)!
可以用,安装比较复杂,
1.计算机名称不能含中文。
2.不需要建环境变量“LANG=CHS”。
3.可以象PROE2.0一样挂EMX4.1。
4.还是浮动许可证,需装许可证服务器。
 楼主| 发表于 2006-4-15 19:20:00 | 显示全部楼层
破解说明的部分翻译:
PTC.PRO.ENGINEER.WILDFIRE.V3.0.WORKiNG.CRACK.FiX.READ.NFO-MAGNiTUDE:
PTC Wildfire 3.0-F000 (32 & 64 bit)
The ZWTiSO release has several items not working:
a) The ZWTiSO release has no distributed services functionality. This is because the license features
   are incorrectly written with a suffix. There is no DS_SERVICE or DS_MANAGER to license as per the wf3.bmp.
b) The ZWTiSO release does not contain a full licensed version of Advanced Vericut. As of Wildfire 3.0 the advanced
   functionality of Vericut is now licensed through a CGTech license.
Installation:
1) In the crack directory open the file called ptc.dat and host to your computer name  and 00-00-00-00-00-00
   to you host ID. Run keygen.bat which will create a license.dat.
   用计事本打开名称为ptc.dat的文件,用你的计算机名称替代host,用你的host ID替代00-00-00-00-00-00。
   运行keygen.bat,将自动生成文件license.dat。
2) Run setup and Install the Ptc License manager. Browse to the license.dat file created in step #1.
   运行安装程序,安装许可证管理器(Ptc License manager)。选前一步中生成的license.dat文件。
3) Run setup and install Pro/e, and optionally, Pro Mechanica and Distributed Services.
   运行安装程序,安装Pro/e,
4) Copy the "PTC_WF3.exe" or "PTC_WF3_x64.exe" patcher to the following directories and run it:
   拷贝补丁文件"PTC_WF3.exe" 或 "PTC_WF3_x64.exe" 到下列路径并运行:
   32 bit:
   32位系统:
   - Pro/e: x:\Program Files\proeWildfire 3.0\i486_nt\obj
   - Pro/Mechanica: x:\Program Files\mechWildfire 3.0\i486_nt\bin
   - Distributed Services: x:\Program Files\ptc_distributed_services\i486_nt\obj
   64 bit:
   64位系统:
   - Pro/e: x:\Program Files\proeWildfire 3.0\x86e_win64\obj
   - Pro/Mechanica: x:\Program Files\mechWildfire 3.0\x86e_win64\bin
   - Distributed Services: x:\Program Files\ptc_distributed_services\x86e_win64\obj
5) To full license Vericut (32 bit only) copy "WF3_VC544.exe" to x:\Program Files\proeWildfire 3.0\i486_nt\obj and run it.
   Also edit \x:\Program Files\proeWildfire 3.0\bin\proev.bat and edit the 3rd to last line in the file
   (add the comment "PTC_KEY=0").
   拷贝补丁文件"WF3_VC544.exe"到目录x:\Program Files\proeWildfire 3.0\i486_nt\obj下,并运行。
   编辑文件\x:\Program Files\proeWildfire 3.0\bin\proev.bat,在倒数第三行的末尾加上"PTC_KEY=0"
   e.g. %start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;
        %CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0
  例如  %start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;
发表于 2006-4-22 23:04:00 | 显示全部楼层
谢谢!!!
已下载完并安装成功了!!!
刻成光盘保存。
发表于 2006-4-23 23:06:00 | 显示全部楼层
谢谢  找了好久了
发表于 2006-4-24 18:34:00 | 显示全部楼层
发表于 2006-4-25 11:41:00 | 显示全部楼层
谢谢!!!
已下载完。
安装在用。
并刻成光盘保存。
再次谢谢!!!
发表于 2006-4-25 13:28:00 | 显示全部楼层
安装后好像与UG。NX4.0有冲突,先启动UG再启动ProE就提示许可证错误,请各位大侠帮忙
发表于 2006-4-25 18:44:00 | 显示全部楼层
为什么比电驴下的小很多,是不是有什么小了的,担心ING
 楼主| 发表于 2006-5-2 19:51:00 | 显示全部楼层
电驴上有好多的,3CD版的是一样大的。
有人去掉了一部分语言,就小了许多。
这个BT的不少啊。
GMT+8, 2025-5-1 03:43 , Processed in 0.217223 second(s), 31 queries , Gzip On.
