查看: 2107|回复: 0
求救,dwginfields()读入数据出错
发表于 2006-4-9 22:52:00 | 显示全部楼层 |阅读模式
我有一个字符数组数据成员需要读入,代码如下:
Acad::ErrorStatus dkfytObj::dwgInFields(AcDbDwgFiler* pFiler)
 assertWriteEnabled();
 Acad::ErrorStatus es;
 // Call dwgInFields from AcDbEntity
 if ((es = AcDbEntity::dwgInFields(pFiler)) != Acad::eOk) {
  return es;
 // Read version number.
 Adesk::UInt16 version;
 pFiler->readItem(&version);
 if (version > VERSION_DKFYTOBJ)
  return Acad::eMakeMeProxy;
 // Read the data members.
 switch (version)
 case (1):
  pFiler->readItem(&m_ipoint);
  pFiler->readItem(inStr);
  // TODO: here you can file datamembers not
  //       created by the ObjectARX Add-In.
  break;
 return pFiler->filerStatus();
在打开图形之前预览的时候发现图形是正常的,但是打开图形后读进来的数据是一串路径字符,不知道是什么原因
GMT+8, 2025-5-7 12:39 , Processed in 0.155606 second(s), 23 queries , Gzip On.
