查看: 2082|回复: 0
紧急求救:关于AcDbEntity派生类无法实现夹点问题
发表于 2006-3-20 23:23:00 | 显示全部楼层 |阅读模式
本人刚在学习ObjectARX,出现如下问题望各位看看:
1:在AcDbEntity派生类中定义了getGripPoints()函数,但在CAD中看不到夹点,
是何原因(下附原程序).
2:在worldDraw()函数中采用AcDbText *pText=new AcDbText()与
mode->geometry().text()定义实体有何区别.
类定义:
class DLLIMPEXP dingteClass : public AcDbCurve
public:
 ACRX_DECLARE_MEMBERS(dingteClass);
 // Constructor / Destructor
 dingteClass();
 virtual ~dingteClass();
 //{{AFX_ARX_METHODS(dingteClass)
 virtual Acad::ErrorStatus dxfOutFields(AcDbDxfFiler* pFiler) const;
 virtual Acad::ErrorStatus dxfInFields(AcDbDxfFiler* pFiler);
 virtual Acad::ErrorStatus dwgOutFields(AcDbDwgFiler* pFiler) const;
 virtual Acad::ErrorStatus dwgInFields(AcDbDwgFiler* pFiler);
 virtual Acad::ErrorStatus getStartPoint(AcGePoint3d& x0) const;
 virtual Acad::ErrorStatus getEndPoint(AcGePoint3d& x0) const;
 virtual Acad::ErrorStatus getGripPoints(AcGePoint3dArray& gripPoints,
                                         AcDbIntArray& osnapModes,
                                         AcDbIntArray& geomIds) const;
 virtual Acad::ErrorStatus moveGripPointsAt(const AcDbIntArray& indices,
                                            const AcGeVector3d& offset);
 virtual Acad::ErrorStatus transformBy(const AcGeMatrix3d& xform);
 virtual Adesk::Boolean worldDraw(AcGiWorldDraw* mode);
 //}}AFX_ARX_METHODS
 //{{AFX_ARX_DATA_ACCESS(dingteClass)
 Acad::ErrorStatus setEntPoint(const AcGePoint3d entPoint);
 Acad::ErrorStatus entPoint(AcGePoint3d& entPoint);
 Acad::ErrorStatus setStartPoint(const AcGePoint3d startPoint);
 Acad::ErrorStatus startPoint(AcGePoint3d& startPoint);
 //}}AFX_ARX_DATA_ACCESS
private:
 //{{AFX_ARX_DATA(dingteClass)
 AcGePoint3d m_entPoint;
 AcGePoint3d m_startPoint;
 //}}AFX_ARX_DATA
private:
 void *operator new[](unsigned nSize) { return 0; }
 void operator delete[](void *p) {};
 void *operator new[](unsigned nSize, const char *file, int line) { return 0; }
类实现:
Adesk::Boolean dingteClass::worldDraw(AcGiWorldDraw* mode)
 assertReadEnabled();
 // TODO: implement this function.
 //AcGePoint3d startPoint,entPoint;
    //this->startPoint(startPoint);
    //this->entPoint(entPoint);
 //AcGeVector3d normal(0.0, 0.0, 1.0);
 //AcGeVector3d direction=m_startPoint-m_entPoint;
    //mode->geometry().text(m_startPoint,normal,direction,5,0.8,0,"toolTe");
 //AcGePoint3d *pVerts=new AcGePoint3d[2];
    //pVerts[0]=m_startPoint;
    //pVerts[1]=m_entPoint;
 //mode->geometry().polyline(2,pVerts);
 AcDbText *pText=new AcDbText();
 pText->setTextString("Hello");
 pText->setPosition(m_startPoint);
 pText->setHeight(5.0);
 pText->worldDraw(mode);
 AcDbLine *line;
 line=new AcDbLine(m_startPoint,m_entPoint);
    line->worldDraw(mode);
 return AcDbEntity::worldDraw(mode);
Acad::ErrorStatus dingteClass::startPoint(AcGePoint3d& startPoint)
 startPoint = m_startPoint;
 return Acad::eOk;
Acad::ErrorStatus dingteClass::setStartPoint(const AcGePoint3d startPoint)
 assertWriteEnabled();
 m_startPoint = startPoint;
 return Acad::eOk;
Acad::ErrorStatus dingteClass::entPoint(AcGePoint3d& entPoint)
 entPoint = m_entPoint;
 return Acad::eOk;
Acad::ErrorStatus dingteClass::setEntPoint(const AcGePoint3d entPoint)
 m_entPoint = entPoint;
 return Acad::eOk;
Acad::ErrorStatus dingteClass::transformBy(const AcGeMatrix3d& xform)
 m_startPoint.transformBy(xform);
 m_entPoint.transformBy(xform);
 return AcDbEntity::transformBy(xform);
Acad::ErrorStatus dingteClass::moveGripPointsAt(const AcDbIntArray& indices,
 dingteClass* te=new dingteClass();
    AcGePoint3d entPoint,startPoint;
 te->getEndPoint(entPoint);
 te->getStartPoint(startPoint);
 startPoint +=offset;
 entPoint +=offset;
 te->setEntPoint(entPoint);
 te->setStartPoint(startPoint);
 return AcDbEntity::moveGripPointsAt(indices, offset);
Acad::ErrorStatus dingteClass::getGripPoints(AcGePoint3dArray& gripPoints,
 startPoint=m_startPoint;
 entPoint=m_entPoint;
 acdbEcs2Wcs(asDblArray(startPoint),
  asDblArray(startPoint),asDblArray(normal),Adesk::kFalse);
 acdbEcs2Wcs(asDblArray(entPoint),
  asDblArray(entPoint),asDblArray(normal),Adesk::kFalse);
 gripPoints.append(startPoint);
 gripPoints.append(entPoint);
 return AcDbEntity::getGripPoints(gripPoints, osnapModes, geomIds);
Acad::ErrorStatus dingteClass::getEndPoint(AcGePoint3d& x0) const
 x0=m_entPoint;
 return AcDbCurve::getEndPoint(x0);
Acad::ErrorStatus dingteClass::getStartPoint(AcGePoint3d& x0) const
 x0=m_startPoint;
 return AcDbCurve::getStartPoint(x0);
Acad::ErrorStatus dingteClass::dwgInFields(AcDbDwgFiler* pFiler)
 Acad::ErrorStatus es;
 // Call dwgInFields from AcDbCurve
 if ((es = AcDbCurve::dwgInFields(pFiler)) != Acad::eOk) {
  return es;
 // Read version number.
 Adesk::UInt16 version;
 pFiler->readItem(&version);
 if (version > VERSION_DINGTECLASS)
  return Acad::eMakeMeProxy;
 // Read the data members.
 switch (version)
 case (1):
  pFiler->readItem(&m_startPoint);
  pFiler->readItem(&m_entPoint);
  // TODO: here you can file datamembers not
  //       created by the ObjectARX Add-In.
  break;
 return pFiler->filerStatus();
Acad::ErrorStatus dingteClass::dwgOutFields(AcDbDwgFiler* pFiler) const
 // Call dwgOutFields from AcDbCurve
 if ((es = AcDbCurve::dwgOutFields(pFiler)) != Acad::eOk) {
  return es;
 // Write version number.
 pFiler->writeItem((Adesk::UInt16) VERSION_DINGTECLASS);
 // Write the data members.
 pFiler->writeItem(m_startPoint);
 pFiler->writeItem(m_entPoint);
Acad::ErrorStatus dingteClass::dxfInFields(AcDbDxfFiler* pFiler)
 struct resbuf rb;
 if ((AcDbCurve::dxfInFields(pFiler) != Acad::eOk) ||
     !pFiler->atSubclassData("dingteClass"))
 pFiler->readItem(&rb);
 if (rb.restype != AcDb::kDxfInt16) {
  pFiler->pushBackItem();
  pFiler->setError(Acad::eInvalidDxfCode,
                  "nError: expected object version group code %d",
                   AcDb::kDxfInt16);
 } else {
  Adesk::UInt16 version = rb.resval.rint;
 if (rb.restype == AcDb::kDxfXCoord) {
  m_startPoint = asPnt3d(rb.resval.rpoint);
 } else {
                  "nError: expected group code %d",
                  AcDb::kDxfXCoord);
 if (rb.restype == AcDb::kDxfXCoord + 1) {
  m_entPoint = asPnt3d(rb.resval.rpoint);
 } else {
                  AcDb::kDxfXCoord + 1);
Acad::ErrorStatus dingteClass::dxfOutFields(AcDbDxfFiler* pFiler) const
 if ((es = AcDbCurve::dxfOutFields(pFiler)) != Acad::eOk)
  return es;
 // Write subclass marker.
 pFiler->writeItem(AcDb::kDxfSubclass, "dingteClass");
 pFiler->writeItem(AcDb::kDxfInt16, (Adesk::UInt16) VERSION_DINGTECLASS);
 pFiler->writeItem(AcDb::kDxfXCoord, m_startPoint);
 pFiler->writeItem(AcDb::kDxfXCoord + 1, m_entPoint);
 return es;
GMT+8, 2025-5-7 12:31 , Processed in 0.164597 second(s), 24 queries , Gzip On.
