查看: 3753|回复: 4
诸位朋友,如何 用setxdata 方法删除实体扩展数据?
发表于 2006-3-10 21:15:00 | 显示全部楼层 |阅读模式
 我是这样做的,但是错了....
我调了一晚上,郁闷的很.
 void clearname(AcDbPolyline* pPolyline)
{ struct  resbuf  *pRb=NULL;
 pPolyline->upgradeOpen();
 pPolyline->setXData(pRb);
 pPolyline->close();
 acutRelRb(pRb);
 楼主| 发表于 2006-3-10 21:26:00 | 显示全部楼层
我 pRb->...type=1001也试过 不行.
发表于 2006-7-20 20:23:00 | 显示全部楼层
我试过,可以的.
  pRb->restype=1001;
   pTemp = pRb;
   pTemp->rbnext=NULL;
pObj->setXData(pRb)
发表于 2006-7-25 16:37:00 | 显示全部楼层
// created: 22/7/2006   17:53   ShangHai
// author:  iPi
// purpose: Delete X-Data of a entity, no matter if there is X-Data attached to the entity
//              when we fail to store a flange,but some information has already been added as x data,
//              we need to delete these x data for consistency
bool DelXData(AcDbObjectId adoiEntity)
    //Open the entity for editing
    AcDbEntity *padEntity;
    if (acdbOpenAcDbEntity(padEntity, adoiEntity, AcDb::kForWrite) != Acad::eOk) {
        return false;
    }//end if
    //Get x data result buffer of the entity
    resbuf *rbXdata = padEntity->xData(NULL);
    //result buffer not null
    if (rbXdata) {
        rbXdata->rbnext = NULL;
        padEntity->setXData(rbXdata);
        acutRelRb(rbXdata);
    }//end if
    padEntity->close();
    return true;
}//end of function : DelXData()
发表于 2014-6-17 22:19:16 | 显示全部楼层
pipilu 发表于 2006-7-25 16:37
兄弟   太谢谢你了
GMT+8, 2025-5-1 12:36 , Processed in 0.166402 second(s), 24 queries , Gzip On.
