楼主: l_shiqiang
请教高手怎样选择框内数字,并将他们相加,计算和是多少?
发表于 2006-3-9 13:22:00 | 显示全部楼层
isnumber是VB自带的函数啊!有问题?
发表于 2006-3-9 13:51:00 | 显示全部楼层
Sub tt()
On Error Resume Next
Dim ss As AcadSelectionSet
Dim ft(0) As Integer, fd(0)
ThisDrawing.SelectionSets("Test").Delete
Set ss = ThisDrawing.SelectionSets.Add("Test")
ft(0) = 0: fd(0) = "*Text"
    ss.SelectOnScreen ft, fd
    textvalue = 0
    For Each i In ss
        If IsNumeric(i.TextString) Then
           textvalue = textvalue + Val(i.TextString)
        End If
    Next
    MsgBox "The result is:" & textvalue
End Sub
发表于 2006-3-9 14:56:00 | 显示全部楼层
呵呵!是IsNumeric不是IsNumber,记错了......
发表于 2006-3-22 22:01:00 | 显示全部楼层
这样可以只选择数据字符,就不用IsNumeric判断了
Sub tt()
Dim ft(2) As Integer, fd(2)
ft(1) = 1: fd(1) = "~*[~.0-9]*"
ft(2) = 1: fd(2) = "~*.*.*"
    textvalue = 0
    For Each i In ss
    Next
End Sub
GMT+8, 2025-7-13 01:55 , Processed in 0.129862 second(s), 16 queries , Gzip On.
