查看: 2895|回复: 4
[求助][ARX]如何根据鼠标在屏幕上面的移动轨迹画出它的相应CAD实体?
发表于 2006-2-28 00:13:00 | 显示全部楼层 |阅读模式
利用Arx进行二次开发的时候,如何根据鼠标在屏幕上面的移动轨迹画出它的相应CAD实体?请斑竹和各位高手赐教!谢谢!
发表于 2006-3-2 19:59:00 | 显示全部楼层
我试过了,这个可以。是转载别处的代码
//而且目前所有的参考书上对AcEdJig类的使用都是以拖动一个椭圆为例(作者都互相抄袭)
//因此我就想,把要生成的系列图形定义成一个自定义实体,不就可以使用AcEdJig了吗!
class  CMARectWindow : public AcDbEntity
public:
 ACRX_DECLARE_MEMBERS(CMARectWindow);
 CMARectWindow();
 virtual ~CMARectWindow();
 virtual Acad::ErrorStatus dwgOutFields(AcDbDwgFiler* pFiler) const;
 virtual Acad::ErrorStatus dwgInFields(AcDbDwgFiler* pFiler);
 virtual Adesk::Boolean worldDraw(AcGiWorldDraw* mode);
        //设置插入基点
 Acad::ErrorStatus setStartPt(const AcGePoint3d startPt);
        //取得插入基点
 AcGePoint3d startPt();
private:
        //成员变量,图形插入基点
        AcGePoint3d m_startPt;
///////////////CMARectWindow 类实现文件//////////////////
ACRX_DXF_DEFINE_MEMBERS(CMARectWindow, AcDbEntity,
                        AcDb::kDHL_CURRENT, AcDb::kMReleaseCurrent,
                        AcDbProxyEntity::kNoOperation,
                        CMAWINDO_INFO, PGL_02);
CMARectWindow::CMARectWindow()
 m_startPt.set(0.0, 0.0, 0.0);
CMARectWindow::~CMARectWindow()
 // TODO: clean up.
Adesk::Boolean CMARectWindow::worldDraw(AcGiWorldDraw* mode)
 assertReadEnabled();
 AcGePoint3d pt;  //插入点
 AcGePoint3d pt1, pt2, pt3, pt4;  //四个角点
 AcGeVector3d vec;
 AcGeVector3d normal(0.0, 0.0, 1.0);
 pt = startPt();
 vec.set(0, 50, 0);
 pt1 = pt - vec;
 pt4 = pt + vec;
 vec.set(60, 0, 0);
 pt2 = pt1 + vec;
 pt3 = pt4 + vec;
 AcGePoint3d pLineArray[5];
 pLineArray[0] = pt1;
 pLineArray[1] = pt2;
 pLineArray[2] = pt3;
 pLineArray[3] = pt4;
 pLineArray[4] = pt1;
 //设置颜色为红色
 mode->subEntityTraits().setColor(1);
 //绘制矩形
 mode->geometry().polyline(5, pLineArray);
 //绘制圆
 mode->geometry().circle(pt, 30.0, normal);
 return AcDbEntity::worldDraw(mode);
Acad::ErrorStatus CMARectWindow::dwgInFields(AcDbDwgFiler* pFiler)
 assertWriteEnabled();
 Acad::ErrorStatus es;
 if ((es = AcDbEntity::dwgInFields(pFiler)) != Acad::eOk)
  return es;
 pFiler->readItem(&m_startPt);
 return pFiler->filerStatus();
Acad::ErrorStatus CMARectWindow::dwgOutFields(AcDbDwgFiler* pFiler) const
 if ((es = AcDbEntity::dwgOutFields(pFiler)) != Acad::eOk)
  return es;
 pFiler->writeItem(m_startPt);
AcGePoint3d CMARectWindow::startPt()
 return m_startPt;
Acad::ErrorStatus CMARectWindow::setStartPt(const AcGePoint3d startPt)
 m_startPt = startPt;
 return Acad::eOk;
////////////拖动函数/////////////////////////
class pglyxqLine : public AcEdJig
public:
    pglyxqLine();
    void doIt();
    virtual DragStatus sampler();
    virtual Adesk::Boolean update();
    virtual AcDbEntity* entity() const;
private:
    CMARectWindow *pRectWindow;
    AcGePoint3d ptm, movePt;
///////////////构造函数//////////////////////////////////////
pglyxqLine::pglyxqLine()
///////////////拖动图形/////////////////////////////////////
void
pglyxqLine::doIt()
    pRectWindow = new CMARectWindow;
    if(!pRectWindow)
      acutPrintf("****CMARectWindow对象不存在****");
      return;
    setDispPrompt("\n指定位置: ");
    AcEdJig::DragStatus stat = drag();
    append();
//////////////捕获定点设备并作出分析////////////////////////
AcEdJig::DragStatus
pglyxqLine::sampler()
    DragStatus stat;
    static AcGePoint3d tempPoint;
    stat = acquirePoint(movePt);
    if (tempPoint != movePt)
        tempPoint = movePt;
    else if (stat == AcEdJig::kNormal)
        return AcEdJig::kNoChange;
    return stat;
/////////更新数据///////并更新类成员变量的值/////////////////
Adesk::Boolean
pglyxqLine::update()
    ptm = movePt;
    pRectWindow->setStartPt(ptm);
    return Adesk::kTrue;
//////////////////更新实体///////////////////////////////////
AcDbEntity*
pglyxqLine::entity() const
    return pRectWindow;
////////////命令执行函数//////////////////////////////////////////////
void
create_tuxing()
    //初始化一个拖动派生类实体
    pglyxqLine *pJig = new pglyxqLine();
    //拖动实体
    pJig->doIt();
    delete pJig;
void
initApp()
    acedRegCmds->addCommand("PGL_YXQ", "PGLYXQ", "PGLYXQ", ACRX_CMD_MODAL, create_tuxing);
    //自定义类初始化函数
    CMARectWindow::rxInit();
    acrxBuildClassHierarchy();
void
unloadApp()
    acedRegCmds->removeGroup("PGL_YXQ");
    deleteAcRxClass(CMARectWindow::desc());
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
    switch (msg)
    case AcRx::kInitAppMsg:
        acrxDynamicLinker->unlockApplication(appId);
 acrxDynamicLinker->registerAppMDIAware(appId);
        initApp();
        break;
    case AcRx::kUnloadAppMsg:
        unloadApp();
    return AcRx::kRetOK;
 楼主| 发表于 2006-3-2 22:07:00 | 显示全部楼层
谢谢badboy518朋友的答案。正在认真学习中。。。
发表于 2006-3-2 22:10:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-3-3 08:28:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-5-7 13:19 , Processed in 0.177277 second(s), 23 queries , Gzip On.
