查看: 1206|回复: 5
新年好!请教各位。
发表于 2003-2-9 13:08:00 | 显示全部楼层 |阅读模式
小弟有一问题请各位大侠指点:如何批量将ACAD2000的DWG文件转换为R14的DWG文件?谢谢!
发表于 2003-2-9 21:14:00 | 显示全部楼层
save as...
 楼主| 发表于 2003-2-9 21:44:00 | 显示全部楼层
thcad,我想知道如何一次转换一批文件?
发表于 2003-2-10 12:38:00 | 显示全部楼层
这就难了!
R12/13/14文件批量转换的工具就有,但14/15互换的工具我还没发现!!
发表于 2003-2-11 09:16:00 | 显示全部楼层
虽然速度慢了点,但非常实用
;;批量处理档转存别种格式
;;虽然速度慢了点,但非常实用
;;注意:转存R15以下无预览图
;;By LUCAS(龙龙仔)
;;虽配合Expresstools__(acetutil.arx)
;;为加速程序执行,程序将设定系统变量ACADLSPASDOC
;;即<只载入 acad.lsp 至 AutoCAD 执行期所开启的第一个图面>
;;当然程序结束后,会还原系统变量ACADLSPASDOC
;;acR12_DXF:                AutoCAD Release12/LT2  DXF (*.dxf)
;;acR13_DWG:                AutoCAD Release13/LT95 DWG (*.dwg)
;;acR13_DXF:                AutoCAD Release13/LT95 DXF (*.dxf)
;;acR14_DWG:                AutoCAD Release14/LT97 DWG (*.dwg)
;;acR14_DXF:                AutoCAD Release14/LT97 DXF (*.dxf)
;;acR15_DWG:                AutoCAD 2000 DWG (*.dwg)
;;acR15_DXF:                AutoCAD 2000 DXF (*.dxf)
;;acR15_Template:        AutoCAD 2000 Drawing Template File (*.dwt)
;;acNative:                A synonym for the latest drawing release.
;;                      In this release, this value equals acR15_DWG.
;;USAGE: (CH "acR14_DWG")
(arxload "acetutil.arx" NIL)
(vl-load-com)
(defun CH (MODE / HOLDECHO APP DWGNAME PREFIX_DWG NN QQ HOLDLSP WW LL)
  (setq HOLDECHO (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq        PREFIX_DWG
         (strcat
           (strcase (acet-ui-pickdir
                      "选择目录"
                      (vl-string-right-trim "\\" (getvar "dwgprefix"))
                      "移除未使用之具名参考"
  (setq HOLDLSP (getvar "ACADLSPASDOC"))
  (setvar "acadlspasdoc" 0)
  (setq QQ (vl-directory-files PREFIX_DWG "*.DWG"))
  (setq NN 0)
  (if (/= QQ NIL)
      (setq APP (vlax-get-acad-object))
      (repeat (length QQ)
        (setq DWGNAME (strcase (strcat PREFIX_DWG (nth NN QQ))))
        (setq WW (vla-open (vla-get-documents APP) DWGNAME))
        (setq LL (strlen MODE))
        (cond
          ((or (equal (strcase (substr MODE (- LL 2) 3)) "DXF")
               (equal (strcase (substr MODE (- LL 7) 8)) "TEMPLATE")
           (vla-saveas
             WW
             (vl-string-right-trim ".DWG" (strcase DWGNAME))
             (eval (read MODE))
          (t
           (vla-saveas WW DWGNAME (eval (read MODE)))
        (prompt (strcat "\n" DWGNAME " <URGE完成>!!!"))
        (vla-close WW :vlax-false)
        (setq NN (1+ NN))
      (vlax-release-object WW)
      (vlax-release-object APP)
    (prompt "\n所选目录中未有任何图档!!!")
  (setvar "acadlspasdoc" HOLDLSP)
  (setvar "cmdecho" HOLDECHO)
发表于 2003-2-11 10:13:00 | 显示全部楼层
使用autocad migration assistant中的batch convert即可。
GMT+8, 2025-5-20 13:22 , Processed in 0.140664 second(s), 26 queries , Gzip On.
