帖子
查看: 3657|回复: 12
请教各位高手,如何根据填充图案,反推出填充边界?
发表于 2006-1-25 21:06:00 | 显示全部楼层 |阅读模式
请教各位高手,如何根据填充图案,反推出填充边界(比如能反画出填充边界线)?
发表于 2006-1-26 17:58:00 | 显示全部楼层
;;; 11 功能:通过选定的阴影图案生成边界线=================================
(defun c:hb () (c:hatchb))  called hb
 ;; this line can be commented out if there is an existing command
(defun c:hatchb (/          es         blay       ed1        ed2
                 loops1     bptf       part       et         noe
                 plist      ic         bul        nr         ang1
                 ang2       obj        *ModelSpace*
                 *PaperSpace*          space      cw         errexit
                 undox      olderr     oldcmdecho ss1        lastent
                 en1        en2        ss         lwp
                 list->variantArray    3dPoint->2dPoint      A2k
                 ent        i          ss2        knot-list
                 controlpoint-list     kn         cn         pos
                 xv
  (setq A2k (wcmatch (getvar "ACADVER") "15*"))
  (if A2k
    (defun list->variantArray (ptsList / arraySpace sArray)
      (setq arraySpace
             (vlax-make-safearray
               vlax-vbdouble
               (cons 0 (- (length ptsList) 1))
             ) ;_ 结束vlax-make-safearray
      ) ;_ 结束setq
      (setq sArray (vlax-safearray-fill arraySpace ptsList))
      (vlax-make-variant sArray)
    ) ;_ 结束defun
  ) ;_ 结束if
  (if A2k
    (defun 3dPoint->2dPoint (3dpt)
      (list (float (car 3dpt)) (float (cadr 3dpt)))
    ) ;_ 结束defun
  ) ;_ 结束if
  (defun errexit (s)
    (princ "\nError:  ")
    (princ s)
    (restore)
  ) ;_ 结束defun
  (defun undox ()
    (command "._ucs" "_p")
    (command "._undo" "_E")
    (setvar "cmdecho" oldcmdecho)
    (setq *error* olderr)
  ) ;_ 结束defun
  (setq olderr  *error*
        restore undox
        *error* errexit
  ) ;_ 结束setq
  (setq oldcmdecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "._UNDO" "_BE")
  (if A2k
      (vl-load-com)
      (setq *ModelSpace* (vla-get-ModelSpace
                           (vla-get-ActiveDocument (vlax-get-acad-object))
                         ) ;_ 结束vla-get-ModelSpace
            *PaperSpace* (vla-get-PaperSpace
                         ) ;_ 结束vla-get-PaperSpace
      ) ;_ 结束setq
    ) ;_ 结束progn
  ) ;_ 结束if
  ;; For testing purpose
  ;; (setq A2k nil)
  (if (/= (setq ss2 (ssget '((0 . "HATCH")))) nil)
      (setq i 0)
      (while (setq ent (ssname ss2 i))
        (setq ed1 (entget ent))
        (if (not (equal (assoc 210 ed1) '(210 0.0 0.0 1.0)))
          (princ "\nHatch not in WCS!")
        ) ;_ 结束if
        (setq xv (cdr (assoc 210 ed1)))
        (command "._ucs" "_w")
        (setq loops1 (cdr (assoc 91 ed1)))
                                        ; number of boundary paths (loops)
        (if (and A2k (= (strcase (cdr (assoc 410 ed1))) "MODEL"))
          (setq space *ModelSpace*)
          (setq space *PaperSpace*)
        ) ;_ 结束if
        (repeat loops1
          (setq ed1 (member (assoc 92 ed1) ed1))
          (setq bptf (cdr (car ed1)))   ; boundary path type flag
          (setq ic (cdr (assoc 73 ed1))) ; is closed
          (setq noe (cdr (assoc 93 ed1))) ; number of edges
          (setq ed1 (member (assoc 72 ed1) ed1))
          (setq bul (cdr (car ed1)))    ; bulge
          (setq plist nil)
          (setq blist nil)
          (cond
            ((> (boole 1 bptf 2) 0)     ; polyline
             (repeat noe
               (setq ed1 (member (assoc 10 (cdr ed1)) ed1))
               (setq plist (append plist (list (cdr (assoc 10 ed1)))))
               (setq blist (append blist
                                   (if (> bul 0)
                                     (list (cdr (assoc 42 ed1)))
                                     nil
                                   ) ;_ 结束if
                           ) ;_ 结束append
               ) ;_ 结束setq
             ) ;_ 结束repeat
             (if A2k
                 (setq polypoints
                        (apply 'append
                               (mapcar '3dPoint->2dPoint plist)
                        ) ;_ 结束apply
                 ) ;_ 结束setq
                 (setq VLADataPts (list->variantArray polypoints))
                 (setq
                   obj (vla-addLightweightPolyline space VLADataPts)
                 ) ;_ 结束setq
                 (setq nr 0)
                 (repeat (length blist)
                   (if (/= (nth nr blist) 0)
                     (vla-setBulge obj nr (nth nr blist))
                   ) ;_ 结束if
                   (setq nr (1+ nr))
                 ) ;_ 结束repeat
                 (if (= ic 1)
                   (vla-put-closed obj T)
                 ) ;_ 结束if
               ) ;_ 结束progn
                 (if (= ic 1)
                   (entmake '((0 . "POLYLINE") (66 . 1) (70 . 1)))
                   (entmake '((0 . "POLYLINE") (66 . 1)))
                 ) ;_ 结束if
                 (setq nr 0)
                 (repeat (length plist)
                   (if (= bul 0)
                     (entmake (list (cons 0 "VERTEX")
                                    (cons 10 (nth nr plist))
                              ) ;_ 结束list
                     ) ;_ 结束entmake
                                    (cons 42 (nth nr blist))
                              ) ;_ 结束list
                     ) ;_ 结束entmake
                   ) ;_ 结束if
                   (setq nr (1+ nr))
                 ) ;_ 结束repeat
                 (entmake '((0 . "SEQEND")))
               ) ;_ 结束progn
             ) ;_ 结束if
            (t                          ; not polyline
             (setq lastent (entlast))
             (setq lwp T)
             (repeat noe
               (setq et (cdr (assoc 72 ed1)))
               (cond
                 ((= et 1)              ; line
                  (if A2k
                    (vla-AddLine
                      space
                      (vlax-3d-point (cdr (assoc 10 ed1)))
                      (vlax-3d-point (cdr (assoc 11 ed1)))
                    ) ;_ 结束vla-AddLine
                    (entmake
                      (list
                        (cons 0 "LINE")
                        (list 10
                              (cadr (assoc 10 ed1))
                              (caddr (assoc 10 ed1))
                              0
                        ) ;_ 结束list
                        (list 11
                              (cadr (assoc 11 ed1))
                              (caddr (assoc 11 ed1))
                              0
                        ) ;_ 结束list
                                        ;  (cons 210 xv)
                      ) ;_ 结束list
                    ) ;_ 结束entmake
                  ) ;_ 结束if
                  (setq ed1 (cddr ed1))
                 ((= et 2)              ; circular arc
                  (setq ang1 (cdr (assoc 50 ed1)))
                  (setq ang2 (cdr (assoc 51 ed1)))
                  (setq cw (cdr (assoc 73 ed1)))
                  (if (equal ang2 6.28319 0.00001)
                      (if A2k
                        (vla-AddCircle
                          space
                          (cdr (assoc 40 ed1))
                        ) ;_ 结束vla-AddCircle
                        (entmake (list (cons 0 "CIRCLE")
                                       (assoc 10 ed1)
                                       (assoc 40 ed1)
                                 ) ;_ 结束list
                        ) ;_ 结束entmake
                      ) ;_ 结束if
                      (setq lwp nil)
                    ) ;_ 结束progn
                    (if A2k
                      (vla-AddArc
                        space
                        (if (= cw 0)
                          (- 0 ang2)
                          ang1
                        ) ;_ 结束if
                        (if (= cw 0)
                          (- 0 ang1)
                          ang2
                        ) ;_ 结束if
                      ) ;_ 结束vla-AddArc
                      (entmake (list (cons 0 "ARC")
                                     (assoc 10 ed1)
                                     (assoc 40 ed1)
                                     (cons 50
                                           (if (= cw 0)
                                             (- 0 ang2)
                                             ang1
                                           ) ;_ 结束if
                                     ) ;_ 结束cons
                                     (cons 51
                                           (if (= cw 0)
                                             (- 0 ang1)
                                             ang2
                                           ) ;_ 结束if
                                     ) ;_ 结束cons
                               ) ;_ 结束list
                      ) ;_ 结束entmake
                    ) ;_ 结束if
                  ) ;_ 结束if
                  (setq ed1 (cddddr ed1))
                 ((= et 3)              ; elliptic arc
                  (if A2k
                      (setq obj (vla-AddEllipse
                                  space
                                ) ;_ 结束vla-AddEllipse
                      ) ;_ 结束setq
                      (vla-put-startangle
                        obj
                        (if (= cw 0)
                          (- 0 ang2)
                          ang1
                        ) ;_ 结束if
                      ) ;_ 结束vla-put-startangle
                      (vla-put-endangle
                        obj
                        (if (= cw 0)
                          (- 0 ang1)
                          ang2
                        ) ;_ 结束if
                      ) ;_ 结束vla-put-endangle
                    ) ;_ 结束progn
                    (princ "\n不支持椭圆或椭圆弧!")
                  ) ;_ 结束if
                  (setq lwp nil)
                 ((= et 4)              ; spline
                  (setq ed1 (member (assoc 94 (cdr ed1)) ed1))
                  (setq knot-list nil)
                  (setq controlpoint-list nil)
                  (setq kn (cdr (assoc 95 ed1)))
                  (setq cn (cdr (assoc 96 ed1)))
                  (setq pos (vl-position (assoc 40 ed1) ed1))
                  (repeat kn
                    (setq
                      knot-list (cons (cons 40 (cdr (nth pos ed1)))
                                      knot-list
                                ) ;_ 结束cons
                    ) ;_ 结束setq
                    (setq pos (1+ pos))
                  ) ;_ 结束repeat
                  (setq pos (vl-position (assoc 10 ed1) ed1))
                  (repeat cn
                           (cons
                             (cons 10 (cdr (nth pos ed1)))
                             controlpoint-list
                           ) ;_ 结束cons
                    ) ;_ 结束setq
                    (setq pos (1+ pos))
                  ) ;_ 结束repeat
                  (setq knot-list (reverse knot-list))
                  (setq controlpoint-list (reverse controlpoint-list))
                  (entmake (append
                             (list '(0 . "SPLINE"))
                             (list (cons 100 "AcDbEntity"))
                             (list (cons 100 "AcDbSpline"))
                             (list (cons 70
                                         (+ 1
                                            8
                                            (* 2 (cdr (assoc 74 ed1)))
                                            (* 4 (cdr (assoc 73 ed1)))
                                         ) ;_ 结束+
                                   ) ;_ 结束cons
                             ) ;_ 结束list
                             (list (cons 71 (cdr (assoc 94 ed1))))
                             (list (cons 72 kn))
                             (list (cons 73 cn))
                             knot-list
                             controlpoint-list
                           ) ;_ 结束append
                  ) ;_ 结束entmake
                  (setq ed1 (member (assoc 10 ed1) ed1))
                  (setq lwp nil)
               )                        ; end cond
             )                          ; end repeat noe
             (if lwp
                 (setq en1 (entnext lastent))
                 (setq ss (ssadd))
                 (ssadd en1 ss)
                 (while (setq en2 (entnext en1))
                   (ssadd en2 ss)
                   (setq en1 en2)
                 ) ;_ 结束while
                 (command "_.pedit" (entlast) "_Y" "_J" ss "" "")
               ) ;_ 结束progn
             ) ;_ 结束if
            )                           ; end t
          )                             ; end cond
        )                               ; end repeat loops1
        (setq i (1+ i))
      ) ;_ 结束while
    ) ;_ 结束progn
  ) ;_ 结束if
  (restore)
) ;_ 结束defun
有样条曲线的不好用  发表于 2012-4-22 21:49
参与人数 1金钱 +5 收起 理由
仲文玉 + 5 淡定
发表于 2006-1-26 18:21:00 | 显示全部楼层
见下图,直接重新创建边界即可
 楼主| 发表于 2006-1-27 12:44:00 | 显示全部楼层
谢谢asdf159!!!因为我公司用的是cad2002,所以没有CAD2006的新功能!谢谢liusz111
发表于 2006-1-30 16:48:00 | 显示全部楼层
也许是边界被盖掉所以看不见了。果真如此可以:
DRAWORDER→选取hatch→ENTER
发表于 2006-2-6 18:07:00 | 显示全部楼层
为什么我的 是灰色不可选??
发表于 2006-2-6 22:45:00 | 显示全部楼层
先要没了边界才可以重新生成边界呀。双击填充图案按钮就会变亮了。
发表于 2009-6-26 18:55:00 | 显示全部楼层
用编辑器生成的编辑都是一段段的,不连续!还是asdf159的LISP程序好!太棒了!非常感谢!
发表于 2012-3-4 16:08:36 | 显示全部楼层
asdf159 发表于 2006-1-26 17:58
;;; 11 功能:通过选定的阴影图案生成边界线=================================(defun c:hb () (c:hatchb)) ...
找了很久啊 非常感谢啊
发表于 2012-3-30 09:58:14 | 显示全部楼层
非常感谢楼主,楼主威武
GMT+8, 2025-6-5 09:43 , Processed in 0.229256 second(s), 31 queries , Gzip On.
