查看: 3075|回复: 2
计算图斑面积时的岛
发表于 2006-1-5 14:50:00 | 显示全部楼层 |阅读模式
我用SelectByPolygon方法进行选择时总是不能选到与边界相连的内部多边形(图形见付件),我在开发论坛问了一个月了也没人回答,希望这里能得到帮助,先谢谢
Sub selectPl()
    Dim ent As AcadEntity
    Dim SelObj As AcadEntity
    Dim NumSel As Integer
    Dim Coord As Variant
    Dim CoordCount As Integer
    Dim NewCoord() As Double
    Dim i As Integer
    Dim ssetObj As AcadSelectionSet
    On Error GoTo Err1:
    Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET2")
    On Error Resume Next
    Do
        ThisDrawing.Utility.GetEntity ent, pnt, "选择多段线:"
        If Err Then Exit Sub
        If TypeName(ent) Like "IAcad*Polyline" Then Exit Do
    Loop
If TypeName(ent) = "IAcadLWPolyline" Then
        Coord = ent.Coordinates
        CoordCount = (UBound(Coord) + 1) / 2 '顶点数
        '定义新的顶点坐标数组
        ReDim NewCoord(0 To (3 * CoordCount - 1)) As Double
        For i = 0 To UBound(Coord) - 1 Step 2
            NewCoord((3 * i) / 2) = Coord(i)
            NewCoord((3 * i) / 2 + 1) = Coord(i + 1)
            NewCoord((3 * i) / 2 + 2) = 0
        Next i
ElseIf TypeName(ent) = "IAcadPolyline" Then
        CoordCount = (UBound(Coord) + 1) / 3
        ReDim NewCoord(0 To UBound(Coord)) As Double
            NewCoord(i) = Coord(i)
        Next
End If
ssetObj.SelectByPolygon acSelectionSetWindowPolygon, NewCoord
ssetObj.Highlight True
ssetObj.Update
NumSel = ssetObj.Count
Exit Sub
Err1:
    ThisDrawing.SelectionSets.Item("TEST_SSET2").Delete
    Resume
End Sub
 楼主| 发表于 2006-1-5 14:53:00 | 显示全部楼层
刚才没把付件搞上
发表于 2019-10-15 08:17:31 来自手机 | 显示全部楼层
谢谢分享,不错
GMT+8, 2025-5-1 03:23 , Processed in 0.184736 second(s), 29 queries , Gzip On.
