查看: 1370|回复: 1
[ARX]请高手们指点一下
发表于 2006-1-4 20:31:00 | 显示全部楼层 |阅读模式
如果知道两点坐标
用ARX如何实现尺寸标注?可以的话给个程序段源码。
在线等,请高手们指点
另外,我下面的函数写出的字体的宽度系数和设置的宽度系数不一致,其他没问题
请帮忙看一下,哪里有问题,谢谢!
Acad::ErrorStatus es;
  AcDbTextStyleTable *pTsTable;
  es = curDoc()->database()->getSymbolTable(pTsTable,AcDb::kForRead);
  if (es != Acad::eOk)
   AfxMessageBox("Couldn't get the text style table.");
  CString theFont = "宋体";
  if (!pTsTable->has((LPTSTR)(LPCSTR)theFont))
   AcDbTextStyleTableRecord *pStyle = new AcDbTextStyleTableRecord;
   pStyle->setFont((LPTSTR)(LPCTSTR)theFont,Adesk::kFalse,Adesk::kFalse,0,34);
   pStyle->setFileName(theFont);
   pStyle->setBigFontFileName(theFont);
   pStyle->setTextSize(8);
   pStyle->setXScale(0.3);
   pStyle->setObliquingAngle(0);
   pStyle->setName(theFont);
   pStyle->setIsShapeFile(Adesk::kFalse);
   pStyle->setIsVertical(Adesk::kFalse);
   pTsTable->upgradeOpen();
   es = pTsTable->add(pStyle);
    CString message;
    message.Format("%d",es);
    AfxMessageBox(message);
   pStyle->close();
  AcDbObjectId styleId;
  es = pTsTable->getAt(theFont,styleId);
   CString message;
  pTsTable->close();
  AcDbText * text = new AcDbText(AcGePoint3d(10,10,0),"你好",styleId,8,0);
  AcDbBlockTable *pBlockTable;
  acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable,AcDb::kForRead);
  AcDbBlockTableRecord *pBlockTableRecord;
  pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
  pBlockTable->close();
  AcDbObjectId textId;
  es = pBlockTableRecord->appendAcDbEntity(textId,text);
  text->close();
  pBlockTableRecord->close();
发表于 2006-1-5 12:09:00 | 显示全部楼层
AcDb3PointAngularDimension::AcDb3PointAngularDimension 函数
AcDb3PointAngularDimension(
const AcGePoint3d& centerPoint,
const AcGePoint3d& xLine1Point,
const AcGePoint3d& xLine2Point,
const AcGePoint3d& arcPoint,
const char* dimText = NULL,
AcDbObjectId dimStyle = AcDbObjectId::kNull);
centerPoint
输入被标注的角度的中点(顶点)(在WCS中)
xLine1Point
输入第一条界线的开始点(在WCS中)
xLine2Point
输入第二条界线的开始点(在WCS中)
arcPoint
输入将在标注弧上的一个点
dimText
输入作为标注文本的文本字符串
dimStyle
输入要使用的AcDbDimStyleTableRecord的对象ID
GMT+8, 2025-5-8 03:44 , Processed in 0.230127 second(s), 24 queries , Gzip On.
