查看: 4050|回复: 7
VLISP無法設定WINDOWS字型(TTF)????
发表于 2003-1-28 14:13:00 | 显示全部楼层 |阅读模式
Specifies the name of the big font file associated with the text or attribute.
Signature
object.BigFontFile
object        TextStyle The object or objects this property applies to.
BigFontFile        String; read-write The name of the big font file.
Remarks
This property is similar to the FontFile property, except it is used to specify an Asian-language big font file. [U]The only valid file type is SHX.[/U]This property cannot be set to NULL or an empty string.
发表于 2003-1-28 16:44:00 | 显示全部楼层
你所指的是大字体,其实TTF字体你只要指定fontFile属性就行
Specifies the primary font file path and name.
Signature
object.FontFile
object
TextStyle:
FontFile:
String; read-write
The primary font file path.
Remarks :
To specify an Asian-language font file, use the BigFontFile property.
Fonts define the shapes of the text characters that make up each character set.
NOTE: Once this property has been set, you must call the Regen method to see the changes to the text.
从字面上看没有对TTF字体的限制,而实际操作中,使用TTF字体时必须指定路径,因为字体不在AutoCAD的支持路径中。
以下程序(VBA)调用正常:
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
    If (CommandName = "TEXT" Or CommandName = "MTEXT") And _
    ThisDrawing.ActiveTextStyle.BigFontFile = "" And _
    LCase(Right(ThisDrawing.ActiveTextStyle.fontFile, 4)) <> ".ttf" Then
        ThisDrawing.ActiveTextStyle.fontFile = "c:\windows\fonts\SIMSUN.TTF"
    End If
End Sub
 楼主| 发表于 2003-1-28 17:00:00 | 显示全部楼层
為何失敗????
;;By LUCAS
;;修改字型
;;usage: (ch_txtstyle "simplex.shx" "dayuxp.shx")
;;usage: (ch_txtstyle <英文字型> <中文字型>)
(defun CH_TXTSTYLE (FONT BIGFONT / TXT TXTSTYLES DOC)
  (setq        TXTSTYLES (vla-get-textstyles
                    (setq DOC (vla-get-activedocument
                                (vlax-get-acad-object)
  (vlax-for TXT TXTSTYLES
      (vla-put-fontfile TXT FONT)
      (vla-put-bigfontfile TXT BIGFONT)
  (vla-regen DOC acallviewports)
  (vlax-release-object DOC)
  (vlax-release-object TXTSTYLES)
;;為何失敗
;;(CH_TXTSTYLE "c:\windows\fonts\MINGLIU.TTF" "")
发表于 2003-1-28 19:29:00 | 显示全部楼层
没有失败,你试试...
(CH_TXTSTYLE (strcat (getenv "Windir") "\\fonts\\SIMSUN.TTF") "")
你把“\\”给忘了。
其实中间那一段可以这样写:
    (if (= (strcase (substr Font (- (strlen Font) 3) 4)) ".TTF")
      (vla-put-fontfile
        txt
        (strcat (getenv "Windir") "\\fonts\\" FONT)
这样设置TTF字体也不用路径了
函数我把它加到函数栏目中吧
发表于 2003-1-28 19:53:00 | 显示全部楼层
呵呵,函数略做改动,只对改动指定的文字样式
(defun CH_TXTSTYLE (TextStyleName FontName BigFontName / TxtStyle Doc)
  (setq TxtStyle (vla-Item
                   (vla-get-textstyles
                     (setq Doc (vla-get-activedocument
                   TextStyleName
  (if (= (strcase (substr FontName (- (strlen FontName) 3) 4))
         ".TTF"
    (vla-put-fontfile
      TxtStyle
      (strcat (getenv "Windir") "\\fonts\\" FontName)
      (vla-put-fontfile TxtStyle FontName)
      (vla-put-bigfontfile TxtStyle BigFontName)
  (vla-regen Doc acallviewports)
  (vlax-release-object Doc)
  (vlax-release-object TxtStyle)
;;示例:将文字样式设为TTF字体-宋体
  (CH_TXTSTYLE "STANDARD" "SIMSUN.TTF" "")
 楼主| 发表于 2003-1-29 07:58:00 | 显示全部楼层
但windows(ttc)字型如何设定????
发表于 2012-10-4 16:07:39 | 显示全部楼层
error:Automation 错误。 文件处理器错误
发表于 2015-7-13 14:54:23 | 显示全部楼层
xp里没有SIMSUN.TTF但有SIMSUN.TTc
GMT+8, 2025-6-2 21:17 , Processed in 0.214245 second(s), 26 queries , Gzip On.
