楼主: sixsixsix
[注意]AIP 10 的 SP3a 刚出来,约40M
发表于 2005-12-23 16:32:00 | 显示全部楼层
Important: This service pack only applies to Autodesk Inventor® Professional 10. It is not meant for Autodesk Inventor® from the Autodesk Inventor Series product.
Autodesk Inventor Professional 10 Service Pack 3a is an incremental update. You must install Autodesk Inventor Professional 10, apply Service Pack 1 and Service Pack 2 before you can install Service Pack 3. This service pack updates only the locked version of Autodesk Inventor® Professional 10 for all languages.
Note: If you installed Service Pack 3 that was recently released and recalled, this update will apply on top of that as well.
Refer to the Readme for detailed information and installation instructions.
虽然写是这么写着,但这次有点不一样。
他的文件名是
正常的情况下文件名应该是Inventor10_aip_SP3.exe
而他的文件名是Inventor10_aip_SP3a.exe ?
A、B、C、D ?
而且Readyme文件也只有一个英文的。
 楼主| 发表于 2005-12-23 21:34:00 | 显示全部楼层
MDT2006 的 SP1a 也是带“a”的,它的 Readme.txt 带有多国文字。
发表于 2005-12-25 11:35:00 | 显示全部楼层
canyouzeng发表于2005-12-23 11:56:00 为何这样? 23650
应该是没有下载完全得缘故吧。
发表于 2005-12-25 16:14:00 | 显示全部楼层
下来一试
谢谢
发表于 2005-12-25 18:31:00 | 显示全部楼层
谢谢提醒!
发表于 2006-1-12 14:54:00 | 显示全部楼层
好东东
发表于 2006-1-12 20:47:00 | 显示全部楼层
  可以用不会重注
发表于 2006-1-12 22:59:00 | 显示全部楼层
我现在还用着aip9,不知道AIP 10从何处下载,请高手指点,谢谢!!
发表于 2006-1-13 11:06:00 | 显示全部楼层
原来要从头安装,我咋说直接安装SP2老出错。
发表于 2006-1-13 23:13:00 | 显示全部楼层
ding!!!
GMT+8, 2025-5-24 07:43 , Processed in 0.152695 second(s), 18 queries , Gzip On.
