查看: 3959|回复: 4
请高手指点呀:怎样删除一个DWG文件
发表于 2005-11-23 14:35:00 | 显示全部楼层 |阅读模式
想请教各位大侠一个问题
在ARX中怎么来实现,打开和删除一个DWG文件
请举个例子,在这里先谢谢了
 楼主| 发表于 2005-11-25 17:27:00 | 显示全部楼层
AcApDocument*    pDoc;
pdoc = acdocmanager->curdocument();
acdocmanager->activatedocument(pdoc, adesk::ktrue);
acdocmanager->closedocument(pdoc);
想用以上代码关闭一个DWG文件,但总会弹出是否保存该文件的对话框,
若将文件保存该怎么用代码来实现,若不保存直接关闭又要怎么实现,还请高手指点呀!在此先谢过了
 楼主| 发表于 2005-11-28 11:42:00 | 显示全部楼层
帮帮忙吧
谢谢了
发表于 2005-12-2 18:27:00 | 显示全部楼层
errBoy发表于2005-11-25 17:27:00 AcApDocument* pDoc; pdoc = acdocmanager->curdocument(); acdocmanager->activatedocument(pdoc, ...
我也想知道,而且如果在对话框中进行closeDocument的命令时,总要等到对话框结束以后才能关闭?不知道为什么
发表于 2005-12-13 17:36:00 | 显示全部楼层
// (C) Copyright 1998-2002 by Autodesk, Inc.
// Permission to use, copy, modify, and distribute this software in
// object code form for any purpose and without fee is hereby granted,
// provided that the above copyright notice appears in all copies and
// that both that copyright notice and the limited warranty and
// restricted rights notice below appear in all supporting
// documentation.
// AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
// AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
// MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
// DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
// UNINTERRUPTED OR ERROR FREE.
// Use, duplication, or disclosure by the U.S. Government is subject to
// restrictions set forth in FAR 52.227-19 (Commercial Computer
// Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
// (Rights in Technical Data and Computer Software), as applicable.
// MDITestDialog.cpp : implementation file
#include "stdafx.h"
#include "acdocman.h"
#include "MDITestDialog.h"
#include "common.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
extern "C" HWND adsw_acadMainWnd();
// MDITestDialog message handlers
// CMDITestDialog dialog
CMDITestDialog::CMDITestDialog(CWnd* pParent /*=NULL*/)
    : CDialog(CMDITestDialog::IDD, pParent)
    //{{AFX_DATA_INIT(CMDITestDialog)
    //}}AFX_DATA_INIT
void CMDITestDialog::DoDataExchange(CDataExchange* pDX)
    CDialog::DoDataExchange(pDX);
    //{{AFX_DATA_MAP(CMDITestDialog)
    DDX_Control(pDX, IDC_ACT_MYLK_STATUS_FIELD_STATIC, m_staticActDocMyLockStatus);
    DDX_Control(pDX, IDC_CURDOC_FIELD_STATIC, m_staticCurrentDoc);
    DDX_Control(pDX, IDC_CUR_LK_STATUS_FIELD_STATIC, m_staticCurDocLockStatus);
    DDX_Control(pDX, IDC_CUR_MYLK_STATUS_FIELD_STATIC, m_staticCurDocMyLockStatus);
    DDX_Control(pDX, IDC_ACT_LK_STATUS_FIELD_STATIC, m_staticActDocLockStatus);
    DDX_Control(pDX, IDC_LOCK_COMBO, m_lockCombo);
    DDX_Control(pDX, IDC_ACTIVEDOC_FIELD_STATIC, m_staticActiveDoc);
    DDX_Control(pDX, IDC_TOBECURRDOC_FIELD_STATIC, m_staticToBeCurrDoc);
    DDX_Control(pDX, IDC_ACTIVATION_CHECK, m_activationCheck);
    DDX_Control(pDX, IDC_NUMDOCS_STATIC, m_staticDocNum);
    DDX_Control(pDX, IDC_DOC_LIST, m_docListBox);
    //}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CMDITestDialog, CDialog)
    ON_MESSAGE( WM_ACAD_KEEPFOCUS, onAcadKeepFocus )
    ON_MESSAGE( WM_ACAD_UPDATEDIALOG, onAcadUpdateDialog )
    ON_MESSAGE( WM_ACAD_CREATEDOC, onAcadCreateDoc )
    ON_MESSAGE( WM_ACAD_DESTROYDOC, onAcadDestroyDoc )
    ON_MESSAGE( WM_ACAD_LOCKMODCHANGED, onAcadLockModeChanged )
    ON_MESSAGE( WM_ACAD_LOCKMODWILLCHANGE, onAcadLockModeWillChange )
    ON_MESSAGE( WM_ACAD_CURRENTDOC, onAcadCurrDoc )
    ON_MESSAGE( WM_ACAD_ACTIVATEDOC, onAcadActivateDoc )
    ON_MESSAGE( WM_ACAD_DEACTIVATEDOC, onAcadDeactivateDoc )
    ON_MESSAGE( WM_ACAD_ACTMODIFIED, onAcadActModifiedDoc )
    //{{AFX_MSG_MAP(CMDITestDialog)
    ON_BN_CLICKED(IDC_NEWDOC_BUTTON, OnNewdocButton)
    ON_BN_CLICKED(IDC_APPNEWDOC_BUTTON, OnAppnewdocButton)
    ON_BN_CLICKED(IDC_APPOPENDOC_BUTTON, OnAppopendocButton)
    ON_BN_CLICKED(IDC_ACTIVATION_CHECK, OnActivationCheck)
    ON_BN_CLICKED(IDC_SENDSTRING_BUTTON, OnSendstringButton)
    ON_BN_CLICKED(IDC_OPENDOC_BUTTON, OnOpendocButton)
    ON_BN_CLICKED(IDC_ISQUIESCENT_BUTTON, OnIsquiescentButton)
    ON_BN_CLICKED(IDC_CLOSEDOC_BUTTON, OnClosedocButton)
    ON_BN_CLICKED(IDC_ACTIVATEDOC_BUTTON, OnActivatedocButton)
    ON_BN_CLICKED(IDC_SETCURRENTDOC_BUTTON, OnSetcurrentdocButton)
    ON_BN_CLICKED(ID_REFRESH_BUTTON, OnRefreshButton)
    //}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CMDITestDialog message handlers
BOOL CMDITestDialog::Create( CWnd* pParent )
    // TODO: Add your specialized code here and/or call the base class
    return CDialog::Create(CMDITestDialog::IDD, pParent);
//    This function gets called repeatedly whenever the mouse is moved over
//    the AutoCAD window.
LRESULT CMDITestDialog::onAcadKeepFocus( WPARAM, LPARAM )
    return TRUE;
LRESULT CMDITestDialog::onAcadUpdateDialog( WPARAM, LPARAM )
    // update elements of the dialog to reflect the current
    // state of the documents
    // get the current number of documents
    m_staticDocNum.SetWindowText( getDocCount() );
    // check/uncheck document activation
    m_activationCheck.SetCheck( acDocManager->isDocumentActivationEnabled() );
    // set the current document fields
    CString fName;
    AcApDocument *pCurrDoc = acDocManager->curDocument();
    if( pCurrDoc ) {
        fName = pCurrDoc->docTitle();
        m_staticCurrentDoc.SetWindowText(fName);
        m_staticToBeCurrDoc.SetWindowText(fName);
        m_staticCurDocLockStatus.SetWindowText( modeStr(pCurrDoc->lockMode()) );
        m_staticCurDocMyLockStatus.SetWindowText( modeStr(pCurrDoc->myLockMode()) );
    else {
        m_staticToBeCurrDoc.SetWindowText("");
        m_staticCurDocLockStatus.SetWindowText("");
        m_staticCurDocMyLockStatus.SetWindowText("");
    // set the active document data
    AcApDocument *pActDoc = acDocManager->mdiActiveDocument();
    if( pActDoc ) {
        // active document name
        fName = pActDoc->docTitle();
        m_staticActiveDoc.SetWindowText(fName);
        // active document lock modes
        m_staticActDocLockStatus.SetWindowText( modeStr(pActDoc->lockMode()) );
        m_staticActDocMyLockStatus.SetWindowText( modeStr(pActDoc->myLockMode()) );
    else {
        m_staticActiveDoc.SetWindowText("");
        m_staticActDocLockStatus.SetWindowText("");
        m_staticActDocMyLockStatus.SetWindowText("");
    // rebuild listbox
    RebuildListBox();
 return TRUE;
// Note: here you could do different actions for each reactor
// intercepted. For this sample I use a brute force approach:
// everything just updates the ui (with few exceptions)
LRESULT CMDITestDialog::onAcadCreateDoc ( WPARAM, LPARAM )
    onAcadUpdateDialog(0,0L);
 return TRUE;
LRESULT CMDITestDialog::onAcadDestroyDoc ( WPARAM, LPARAM )
    // if we went to 0 doc state, clean all the pertinent
    // ui elememnts of the dialog. Note however, that this function is
    // activated upon SendMessage (instead of PostMessage) so the document
    // count right here is still one more than the end result.
    // That's why 1 is subtracked from nDoc in the comparison.
    int nDoc = acDocManager->documentCount();
    if( 0 == nDoc - 1 )
        cleanUpUI();
    else
 return TRUE;
LRESULT CMDITestDialog::onAcadLockModeChanged ( WPARAM, LPARAM pCh )
 return TRUE;
LRESULT CMDITestDialog::onAcadLockModeWillChange ( WPARAM, LPARAM pCh )
 return TRUE;
LRESULT CMDITestDialog::onAcadCurrDoc ( WPARAM, LPARAM )
    onAcadUpdateDialog(0, 0L);
 return TRUE;
LRESULT CMDITestDialog::onAcadActivateDoc ( WPARAM, LPARAM )
 return TRUE;
LRESULT CMDITestDialog::onAcadDeactivateDoc ( WPARAM, LPARAM )
    // clear the fields related to the active document
 return TRUE;
LRESULT CMDITestDialog::onAcadActModifiedDoc ( WPARAM, LPARAM bValue )
    // check/uncheck document activation depending on the activation value sent
    if( 1L == bValue )
        m_activationCheck.SetCheck( TRUE );
    else
        m_activationCheck.SetCheck( FALSE );
 return TRUE;
// ui related actions
void CMDITestDialog::OnNewdocButton()
    // document context.
    Acad::ErrorStatus st = acDocManager->newDocument();
void CMDITestDialog::OnOpendocButton()
    Acad::ErrorStatus st = acDocManager->openDocument();
void CMDITestDialog::OnAppnewdocButton()
    static char pData[] = "acad.dwt";
    Acad::ErrorStatus st = acDocManager->appContextNewDocument((const char *)pData);
void CMDITestDialog::OnAppopendocButton()
    static char pData[] = "test1.dwg";
    Acad::ErrorStatus st = acDocManager->appContextOpenDocument((const char *)pData);
void CMDITestDialog::OnActivationCheck()
    Acad::ErrorStatus st;
    // get status of the button and set the activation state from it.
    UINT check = m_activationCheck.GetCheck();
    if( (check && 0x0003) == 0 ) {
        // unchecked - we need to disable the activation
        st = acDocManager->disableDocumentActivation();
    else {
        // checked - we need to enable the activation
        st = acDocManager->enableDocumentActivation();
void CMDITestDialog::OnSendstringButton()
    if( acDocManager->documentCount() == 0 )
        return;
    AcApDocument *pDoc = getSelectedDocument();
    if(pDoc) {
        Acad::ErrorStatus st = acDocManager->sendStringToExecute( pDoc, "_line 0,0 1,1 \n",
                                                         false, true);
//        Acad::ErrorStatus st = acDocManager->sendStringToExecute( pDoc, "_text 5,5 0.2 15 Testing\r\r");
    else
        AfxMessageBox("Please select a document on the list box");
void CMDITestDialog::OnIsquiescentButton()
    AcApDocument *pDoc = acDocManager->curDocument();
    if(pDoc) {
        CString tempStr;
        tempStr.Format("Current Doc is %s\nlockMode() returned %s\nand myLockMode() returned %s.",
                        pDoc->isQuiescent() ? "Quiescent." : "NOT Quiescent.",
                        modeStr(pDoc->lockMode()),
                        modeStr(pDoc->myLockMode()) );
        AfxMessageBox( tempStr );
void CMDITestDialog::OnClosedocButton()
        return;
    if(pDoc) {
        // if you close the doc, update the UI
        if( acDocManager->closeDocument(pDoc) == Acad::eOk ) {
    else
void CMDITestDialog::OnActivatedocButton()
        return;
    if( pDoc )
        acDocManager->activateDocument( pDoc );
    else
BOOL CMDITestDialog::OnInitDialog()
    CDialog::OnInitDialog();
    // select one of the elements of the CComboBox to be displayed
    m_lockCombo.SetCurSel(2);
    // set up all the UI elements
    // here I call the functions that update the ui elements directly
    // instead of waiting for posted messages.
    return TRUE;  // return TRUE unless you set the focus to a control
                  // EXCEPTION: OCX Property Pages should return FALSE
void CMDITestDialog::OnSetcurrentdocButton()
    if( !pDoc ) {
        return;
    // get the lock mode to be used from the combo box
    AcAp::DocLockMode lockMode = getSelectedLockMode();
    acDocManager->unlockDocument( pDoc ); // in case we had lock it before
    acDocManager->setCurDocument( pDoc, lockMode );
// other MDITestDialog member functions
void CMDITestDialog::cleanUpUI( void )
    m_staticCurrentDoc.SetWindowText("");
    m_staticDocNum.SetWindowText( "0" );
    m_docListBox.ResetContent();
CString CMDITestDialog::getDocCount( void )
    CString tempStr;
    tempStr.Format("%d",nDoc);
    return tempStr;
CString CMDITestDialog::makeStringFromPtr( LONG pCh )
    CString tempStr;
    char *pChar = (char*) pCh;
    if( pChar ) {
        tempStr.Format("%s",pChar);
        if( *pChar )
            delete pChar;
    else
        tempStr = "";
    return tempStr;
// getDocFromFilename()
//  Passed a filename, it finds the corresponding document pointer
//  Returns true if successful
bool CMDITestDialog::getDocFromFilename(CString csFileName, AcApDocument* &pNewDocument)
    // Iterate over the open documents. We will match the filename if:
    //      The filename specified matches the fully qualified path
    //      name, as returned by AcApDocument::filename()
    //      -or-
    //      The filename specified matches the filename portion of the
    //      document name
    AcApDocumentIterator* iter = acDocManager->newAcApDocumentIterator();
    AcApDocument* pThisDocument = NULL;
    CString csThisFilename;
    CString csThisFilenameShort;
    csFileName.MakeUpper(); // uppercase comparisons
    while(!iter->done()) {   // Tiptoe through the tulips
        pThisDocument = iter->document();
        csThisFilename = pThisDocument->docTitle();
        csThisFilename.MakeUpper();
        csThisFilenameShort = csThisFilename.Right(csThisFilename.GetLength() -
            csThisFilename.ReverseFind('\\') - 1);
        if(csFileName == csThisFilename ||       // Full path match
            csFileName == csThisFilenameShort || // Matches filename only
            csFileName == csThisFilenameShort.Left( // Filename less extension
                          csThisFilenameShort.GetLength() - 4))
            pNewDocument = pThisDocument;
            if( iter )
                delete iter;
            return true;
        iter->step();
    pNewDocument = NULL;
    if( iter )
        delete iter;
    // no match found
    return false;
AcApDocument* CMDITestDialog::getSelectedDocument( void )
    AcApDocument *pDoc = NULL;
    CString fName;
    int ndx = m_docListBox.GetCurSel();
    if( LB_ERR != ndx ) {
        m_docListBox.GetText(ndx, fName);
        // find out which document has this file name and get its document pointer.
        if( !getDocFromFilename( fName, pDoc ) )
            AfxMessageBox("Document NOT found.");
    return pDoc;
AcAp::DocLockMode CMDITestDialog::getSelectedLockMode( void )
    AcAp::DocLockMode lm = AcAp::kNone;
    int ndx = m_lockCombo.GetCurSel();
    CString lModeStr;
        m_lockCombo.GetLBText(ndx, lModeStr);
        // to activate the document, first I need to find out which document
        // has this file name and get its document pointer.
        if( !getLockModeFromStr( lModeStr, lm ) )
            AfxMessageBox("Error with lock mode combo box"); //should never get here.
    return lm;
void CMDITestDialog::RebuildListBox()
    m_docListBox.ResetContent(); // start from an empty list box
    // at this moment, get all drawing names and add them to the list box.
    AcApDocument* pDoc = NULL;
    CString csFilename;
        pDoc = iter->document();
        if(pDoc) {                     // #### make sure pDoc is not NULL ####
            csFilename = pDoc->docTitle();
            m_docListBox.AddString( csFilename );
        iter->step();
    if( iter )
        delete iter;
void CMDITestDialog::OnRefreshButton()
    // Just to give peace of mind: if you think something is displayed wrong
    // in the dialog, this button will update all ui of the dialog
GMT+8, 2025-7-2 13:38 , Processed in 0.188612 second(s), 23 queries , Gzip On.
