查看: 1900|回复: 4
请教斜切图问题?
发表于 2005-11-18 14:10:00 | 显示全部楼层 |阅读模式
大量图幅要切割,但只用CAD剪切命令显然工作量太大。extrim后还得用用别的命令,一直想编一个能通过画斜矩形框,从而把框外的图形剪切干净。望高手赐教
发表于 2005-11-18 19:54:00 | 显示全部楼层
 楼主| 发表于 2005-11-21 08:17:00 | 显示全部楼层
谢谢!
 楼主| 发表于 2005-11-21 08:35:00 | 显示全部楼层
<TABLE class=tablebody2 style="TABLE-LAYOUT: fixed; WORD-BREAK: break-all" width="90%" border=0>
<TBODY>
<TR>
<TD style="FONT-SIZE: 9pt; LINE-HEIGHT: 12pt" width="100%">高手,这个lisp程序只能切正矩形里面的的图形,我想要一个能通过画斜矩形框,从而把框外的图形剪切干净。望高手赐教</TD></TR></TBODY></TABLE>
 楼主| 发表于 2005-11-21 08:39:00 | 显示全部楼层
我有一个切正矩形的程请高手帮我改一下,改成选一任意矩形切图程序
(defun c:wSave(/ pzx pys p1 p2 p3 p4 s s1)
  (setq pzx (getpoint "\n选择左下角点(用鼠标直接点取或在命令行输入<x,y>):"))
  (setq pys (getpoint "\n选择右上角点(用鼠标直接点取或在命令行输入<x,y>):"))
  (setq p1 (list (- (car pzx) 0.01) (- (cadr pzx) 0.01)))
  (setq p2 (list (+ (car pys) 0.01) (- (cadr pzx) 0.01)))
  (setq p3 (list (+ (car pys) 0.01) (+ (cadr pys) 0.01)))
  (setq p4 (list (- (car pzx) 0.01) (+ (cadr pys) 0.01)))
  (command "rectang" pzx pys)
  (setq s (ssget "L"))
  (command "trim" s "" "F" p1 p2 "" "F" p2 p3 "" "F" p3 p4 "" "F" p4 p1 "" "")
  (command "erase" s "")
  (setq s1 (ssget "WP" (list p1 p2 p3 p4 p1)))
  (rder s1)
  (setq s nil s1 nil)
  (setvar "FILEDIA" 0)
  (command "SaveAs" "" "d:\\test" "close" "n")
  (setvar "FILEDIA" 1)
);end wSave
  (defun rder(s1 / s2 ent s3 n)
     (setq s2 (ssget "X"))
     (if (not s1) (command "erase" s2 "")
  (setq s3 (ssadd) n 0)
  (repeat (sslength s2)
  (setq ent (ssname s2 n))
  (if (not (ssmemb ent s1))
    (ssadd ent s3)
    (setq n (1+ n))
    (command "erase" s3 "" "redraw")
   );end rder
GMT+8, 2025-5-7 19:45 , Processed in 0.184706 second(s), 28 queries , Gzip On.
