楼主: raven
[求助]如何判断一点在pline围成的封闭空间内
发表于 2004-5-29 19:12:00 | 显示全部楼层
  1. ;|利用 offset 方法判断点在曲线的内外关系.  测试版 -----------无痕。
  2. 返回T=在内.           !!!***************支持不闭合曲线***********************!!!
  3.            对自相交曲线有bug.不支持!
  4. (defun c:test (/ e) (while (setq e (entsel "\n选曲线:"))(print (ptin e (getpoint "\n选点:")))))
  5. |;
  6. (defun ptin (ept pt / oecho oe obj e ll ur k)
  7.    (vl-load-com)
  8.    (setq oecho (getvar "cmdecho"))
  9.    (vl-cmdf ".undo" "be")
  10.    (setvar "cmdecho" 0)
  11.    (setq obj (vlax-ename->vla-object (car ept))
  12.   e     (entlast))
  13.    (vla-getboundingbox obj 'll 'UR)
  14.    (setq d (apply 'distance   (mapcar 'vlax-safearray->list (list LL UR))))
  15.    (vl-cmdf "_.offset" d ept pt)(vl-cmdf);偏移
  16.    (setq k (if (eq (entlast) e) T nil))
  17.    (vl-cmdf ".undo" "e" "u")
  18.    (setvar "cmdecho" oecho)
  19.    k
  20. )
GMT+8, 2025-11-11 07:57 , Processed in 0.166653 second(s), 19 queries , Gzip On.
