查看: 1332|回复: 2
[求助]各位帮帮忙!~!!~
发表于 2005-10-21 21:39:00 | 显示全部楼层 |阅读模式
我刚开始安AutoCAD2006 没一会就出现了先面的提示;
已中止AutoCad2006-SimplifiedChinese安装 请检查"C:\Documents and Settings\Administrator.WORKGROU-8F2E42\Local Settings\Temp\AutoCad2006  Setup.log"以获取详细信息.
请问是什么问题? 是不是我的系统有问题啊?
AutoCad2006 Setup.log"文件里面的内容是:
[10/20/2005 20:58:22] === Installation started on WORKGROU-8F2E42 by Administrator ===
[10/20/2005 20:58:24] [Info] Windows Installer upgrade is not required
[10/20/2005 20:58:24]   System Version = 3.0.3790.2180
[10/20/2005 20:58:24] Installation skipped: MSI Runtime 3.0
[10/20/2005 20:58:24] Installation started: .NET Framework Runtime 1.1
[10/20/2005 20:58:24]   Command = "I:\Bin\AcadFEUI\support\dotnetfx\dotnetfx.exe" /q /c:"install /l /qb"
[10/20/2005 20:59:02] [Error: 1603] 安装时发生严重错误
[10/20/2005 20:59:02] Installation failed: .NET Framework Runtime 1.1
[10/20/2005 20:59:02] Installation aborted
[10/20/2005 21:09:46] === Installation ended ===
发表于 2005-10-22 20:23:00 | 显示全部楼层
可能是你的系统有问题,我以前也有这个问题,把系统覆盖安装一遍就好了。
发表于 2005-10-22 20:28:00 | 显示全部楼层
系统问题
GMT+8, 2025-5-15 08:22 , Processed in 0.191185 second(s), 28 queries , Gzip On.
