查看: 5167|回复: 4
[推荐]Thumbnailer.arx for objectdbx
发表于 2005-10-20 11:01:00 | 显示全部楼层 |阅读模式
Thumbnailer.arx  Copyright 2005  www.caddzone.com
   Thumbnailer ActiveX Server Documentation
   Library:   Thumbnailer.arx
   Class:     Application
   ProgID:    "Thumbnailer.Application"
   Reference: "Thumbnailer 1.0 Type Library"
   Requirements:  AutoCAD 2004-2006
   Terms and conditions of use:
      This software may be used and freely distributed,
      provided this notice and the copyright notice
      displayed by the application when it loads, is not
      removed, altered, or concealed.
      This software is not warranted to be free of defects.
      Any and all use of this software is undertaken at the
      risk of the user. The author is not responsible for
      any loss resulting directly or indirectly from the
      use of this software.
      Your use of this software constitutes your acceptance
      of these terms and conditions.
  Installation:
      Thumbnailer.arx must be registered once when installed,
      by dragging it onto the AutoCAD window, or by loading it
      as an ARX library using any supported means. If the
      location of the Thumbnailer.arx file changes, it must
      be re-registered again.
      IMPORTANT: To install this library you must be logged
      in with superuser or administrator rights.
      IMPORTANT: Use of this library does NOT require it to be
      loaded as an ARX library, and it should never be loaded
      as such for normal use (e.g., do not add Thumbnailer.arx
      to the startup suite or the acad.rx file, and do not load
      it via the LoadArx() method or the LISP equivalent).
  Methods:  PreserveThumbnail
      obj.PreserveThumbnail(IAcadDatabase Database)
      Call this method and pass it the value of the
      Database property of an AxDbDocument, before
      calling the AxDbDocument's SaveAs() method, and
      the existing thumbnail preview (if there is one)
      will be preserved
   AutoLISP wrapper/example:
      Pass an AxDbDocument to the following LISP function
      to save it to a DWG file, with its existing thumbnail
      preview retained:
      (defun SaveAsEx (dbxDoc filename / app)
         (setq app
           (vla-GetInterfaceObject
              (vlax-get-acad-object)
         (vlax-invoke-method app 'PreserveThumbnail
            (vlax-get-property dbxDoc 'Database)
         (vlax-release-object app)
         (vlax-invoke-method dbxDoc 'SaveAs filename)
Source:
   The implementation of this method is fairly simple:
   STDMETHODIMP CApplication::PreserveThumbnail(IAcadDatabase* Database)
      HRESULT hr = S_OK;
      CComQIPtr<IAcadBaseDatabase> pBase(Database);
      if( pBase != NULL )
         AcDbDatabase* pDb = NULL;
         hr = pBase->GetDatabase(&pDb);
         if( FAILED( hr ) )
            return hr;
         pDb->setRetainOriginalThumbnailBitmap(true);
      return hr;
发表于 2005-12-5 13:32:00 | 显示全部楼层
谢谢龙兄!请你有for R15的吗?我在那个网没有找到。
 楼主| 发表于 2005-12-8 17:04:00 | 显示全部楼层
注意:Requirements:  AutoCAD 2004-2006
它for r15!   我在r2005~r2006测试通过! r2004未试!
发表于 2006-12-6 08:22:00 | 显示全部楼层
怎么测试?
 楼主| 发表于 2007-1-18 09:17:00 | 显示全部楼层
GMT+8, 2025-5-1 05:56 , Processed in 0.213079 second(s), 25 queries , Gzip On.
