帖子
查看: 1715|回复: 2
VBA编程时有没有判断两个三维实体是否相交的方法?
发表于 2005-10-13 14:38:00 | 显示全部楼层 |阅读模式
发表于 2005-10-13 21:33:00 | 显示全部楼层
CheckInterference Method
Checks for interference between two solids and, if specified, creates a solid from the interference.
MSITStore:C:\Program%20Files\AutoCAD%202006\help\acadauto.chm::/checkinterference_see_also.htm" target="_blank" >See Also | MSITStore:C:\Program%20Files\AutoCAD%202006\help\acadauto.chm::/ex_checkinterference.htm" target="_blank" >Example
Signature
RetVal = object.CheckInterference(Object, CreateInterferenceSolid)
Object
MSITStore:C:\Program%20Files\AutoCAD%202006\help\acadauto.chm::/idh_3dsolid_object.htm" target="_blank" >3DSolid object; input-only
The object to check against.
Boolean; input-only
TRUE: Creates the interference solid.
FALSE: Does not create the interference solid.
RetVal
The resulting object if CreateInterferenceSolid is set to TRUE.
 楼主| 发表于 2005-10-14 08:59:00 | 显示全部楼层
谢谢版主!
GMT+8, 2025-7-8 11:07 , Processed in 0.164576 second(s), 23 queries , Gzip On.
