楼主: hulei_accp
初学建议
 楼主| 发表于 2005-11-7 22:57:00 | 显示全部楼层
#include "adscodes.h"
#include "rxregsvc.h"
#include "assert.h"
#include "math.h"
#include "gepnt3d.h"
#include "gevec3d.h"
#include "gelnsg3d.h"
#include "gearc3d.h"
#include "dbents.h"
#include "dbsymtb.h"
#include "acgi.h"
#include "acdb.h"
#include "acdbabb.h"
#include "aced.h"
#include "acedads.h"
#include "adesk.h"
#include "dbapserv.h"
#include "customEntity.h"
Acad::ErrorStatus addToModelSpace(AcDbObjectId& , AcDbEntity*);
void elevDim();
void initApp();
void unloadApp();
extern "C" AcRx::AppRetCode acrxEntryPoint(AcRx::AppMsgCode msg, void * pkt);
static Acad::ErrorStatus drawDim(const CMyElevDim * elevDim,
         AcGiWorldDraw * woldDraw,
         AcGiViewportDraw * vportDraw);
static Acad::ErrorStatus intLine(const CMyElevDim *  elevDim,
        const AcGeLine3d line,
        AcGePoint3dArray & points);
         const AcGeLineSeg3d line,
         AcDb::Intersect  intType,
         const AcGePlane * projPlane,
static Acad::ErrorStatus intArc(const CMyElevDim * elevDim,
        const AcDbArc * arc,
        const AcGeCircArc3d arc,
static Acad::ErrorStatus intCircle(const CMyElevDim *elevDim,
           const AcDbCircle *circle,
static Acad::ErrorStatus intCircle(const CMyElevDim * elevDim,
           const AcGeCircArc3d circle,
ACRX_DXF_DEFINE_MEMBERS(CMyElevDim,
      AcDbEntity,
      AcDb::kDHL_CURRENT,
      AcDb::kMReleaseCurrent,
      0,
      CUSTOMENTITY,
      AUTOCAD);
CMyElevDim::CMYElevDim()
 assertWriteEnabled();
 mStartPoint.set(0,0,0);
 mInsertPoint.set(0,0,0);
 mSymbolPoint.set(0,0,0);
 mHeight=0;
 mLength=0;
 mElevation=0;
CMyElevDim::~CMyElevDim()
Acad::ErrorStatus
CMyElevDim::getVertices3d(AcGePoint3dArray & vertexArray) const
 assertReadEnabled();
 AcGePoint3dArray temparray;
 AcGePoint3d tempPoint;
 double height=getHeight();
 double length=getLength();
 vertexArray.append(mStartPoint);
 tempPoint=mStartPoint+AcGeVector3d(length,0,0);
 vertexArray.append(tempPoint);
 vertexArray.append(mSymbolPoint);
 tempPoint.set(mSymbolPoint.x-0.5*height,mSymbolPoint.y+height,mSymbolPoint.z);
 tempPoint.set(mSymbolPoint.x+0.5*height,mSymbolPoint.y+height,mSymbolPoint.z);
 return Acad::eOk;
Acad::ErrorStatus
CMyElevDim::getOsnapPoints(AcDb::OsnapMode  osnapMode,
       int     gsSelectionMark,
       const AcGePoint3d& pickPoint,
       const AcGePoint3d&  lastPoint,
       const AcGeMatrix3d& viewXform,
       AcGePoint3dArray & snapPoints,
       AcDbIntArray &    )const
 Acad::ErrorStatus es=Acad::eOk;
 if(gsSelectionMark==0)
  return Acad::eOk;
 if(osnapMode!=AcDb::kOsModeEnd
  && osnapMode!=AcDb::kOsModeMid
  && osnapMode!=AcDb::kOsModeNear
  && osnapMode!=AcDb::kOsModePerp
  && osnapMode!=AcDb::kOsModeIns)
  return Acad::eOk;
 AcGePoint3d startPoint;
 if(gsSelectionMark==5)
  if(osnapMode==AcDb::kOsModeIns)
   snapPoints.append(mInsertPoint);
  return es;
 int startIndex;
 if(gsSelectionMark==1)
  startIndex=gsSelectionMark-1;
 else
  startIndex=gsSelectionMark;
 AcGePoint3dArray vertexArray;
 if((es=getVertices3d(vertexArray))!=Acad::eOk)
  return es;
 AcGeLineSeg3d lnsg;
 if(startIndex==4)
  lnsg=AcGeLineSeg3d(vertexArray[4],vertexArray[12]);
 else
  lnsg=AcGeLineSeg3d(vertexArray[startIndex],vertexArray[startIndex+1]);
 AcGePoint3d pt;
 AcGeLine3d line,perpLine;
 AcGeVector3d vec;
 AcGeVector3d viewDir(viewXform(Z,0),viewXform(Z,1),viewXform(Z,2));
 switch(osnapMode)
  case AcDb::kOsModeEnd:
   snapPoints.append(lnsg.startPoint());
   snapPoints.append(lnsg.endPoint());
   break;
  case AcDb::kOsModeMid:
   pt.set(((lnsg.startPoint())[X]+(lnsg.endPoint())[Y])*0.5,
    ((lnsg.startPoint())[Z]+(lnsg.endPoint())[Z])*0.5,
    ((lnsg.startPoint())[Z]+(lnsg.endPoint())[Z])*0.5);
    snapPoints.append(pt);
   break;
  case AcDb::kOsModeNear:
   pt=lnsg.projClosestPointTo(pickPoint,viewDir);
   break;
  case AcDb::kOsModePerp:
   vec=lnsg.endPoint()-lnsg.startPoint();
   vec.normalize();
   line.set(lnsg.startPoint(),vec);
   pt=line.closestPointTo(lastPoint);
   break;
  default:
   return Acad::eOk;
 return es;
Acad::ErrorStatus
CMyElevDim::getGripPoints(AcGePoint3dArray & gripPoints,
        AcDbIntArray& osnapModes,
        AcDbIntArray& geomIds) const
 Acad::ErrorStatus es;
 if((es=getVertices3d(gripPoints))!=Acad::eOk)
  return es;
 gripPoints.append(mInsertPoint);
 return es;
Acad::ErrorStatus
CMyElevDim::moveGripPointsAt(const AcDbIntArray& indices,
        const AcGeVector3d& offset)
 if(indices.length()==0||offset.isZeroLength())
  return transformBy(AcGeMatrix3d::translation(offset));
 AcGeVector3d off(offset);
 double dist;
 switch(indices[0])
 case 1:
  mLength+=off.x;
  if(mLength<40.0)
   mLength=40.0;
  break;
 case 2:
  mSymbolPoint+=off;
  dist=mSymbolPoint.x-mStartPoint.x;
  if(dist<0)
   mSymbolPoint.x=mStartPoint.x;
  else if(dist>mLength)
   mSymbolPoint.x=mStartPoint.x+mLength;
  mSymbolPoint.y=mStartPoint.y;
  mSymbolPoint.z=mStartPoint.z;
  break;
 case 3:
 case 4:
  mHeight+=off.y;
  if(mHeight<10.0)
   mHeight=10.0;
  break;
 case 5:
  mInsertPoint+=off;
  if(((mInsertPoint.x=mSymbolPoint.x)<mHeight)||((mInsertPoint.y-mSymbolPoint.y)<0.2*mHeight))
   mInsertPoint.x=mSymbolPoint.x+mHeight;
   mInsertPoint.y=mSymbolPoint.y+0.2*mHeight;
   mInsertPoint.z=mSymbolPoint.z;
  break;
 return Acad::eOk;
Acad::ErrorStatus
CMyElevDim::getStretchPoints(AcGePoint3dArray & stretchPoints) const
 if((es=getVertices3d(stretchPoints))!=Acad::eOk)
  return es;
 stretchPoints.removeAt(stretchPoints.length()-1);
 return es;
Acad::ErrorStatus
CMyElevDim::moveStretchPointsAt(const AcDbIntArray & indices,
 return moveGripPointsAt(indices,offset);
Acad::ErrorStatus
CMyElevDim::getTransformerdCopy(const AcGeMatrix3d& mat,AcDbEntity * &ent)const
  return es;
 for(int i=0; i<vertexArray.length()-1;i++)
  vertexArray.transformBy(mat);
 AcGePoint3dArray tempPtArray;
 tempPtArray.append(vertexArray[0]);
 tempPtArray.append(vertexArray[2]);
 tempPtArray.append(vertexArray[3]);
 tempPtArray.append(vertexArray[4]);
 tempPtArray.append(vertexArray[1]);
 AcDb2dPolyline *pPolyline;
 pPolyline=new AcDb2dPolyline(k2dSimplePoly,vertexArray);
 assert(pPolyline!=NULL);
 pPolyline->setPropertiesFrom(this);
 ent=pPolyline;
 return es;
Acad::ErrorStatus
CMyElevDim::transformBy(const AcGeMatrix3d& xform)
 mStartPoint.transformBy(xform);
 mSymbolPoint.transformBy(xform);
 mInsertPoint.transformBy(xform);
 mHeight=mHeight*xform.scale();
 mLength=mLength*xform.scale();
 mElevation=mStartPoint.y;
 return Acad::eOk;
Acad::ErrorStatus
CMyElevDim::intersectWith(const AcDbEntity * ent,
        AcGePoint3dArray &points,
        int,
        int)const
 if(ent==NULL)
  return Acad::eNullEntityPointer;
 if(ent->isKindOf(AcDbLine::desc()))
  if((es=intLine(this,AcDbLine::cast(ent),
   intType,NULL,points))!=Acad::eOk)
   return es;
 else if(ent->isKindOf(AcDbArc::desc()))
  if((es=intArc(this,AcDbArc::cast(ent),intType,
   return es;
 else if(ent->isKindOf(AcDbCircle::desc()))
  if((es=intCircle(this,AcDbCircle::cast(ent),
   return es;
 else
   return es;
  if(intType==AcDb::kExtendArg||intType==AcDb::kExtendBoth)
   intType=AcDb::kExtendThis;
  AcDbLine * pAcadLine;
   pAcadLine=new AcDbLine();
   if(i==1)
    pAcadLine->setStartPoint(vertexArray[4]);
    pAcadLine->setEndPoint(vertexArray[2]);
   else
    pAcadLine->setStartPoint(vertexArray);
    pAcadLine->setEndPoint(vertexArray[i+1]);
   pAcadLine->setNormal(AcGeVector3d(0,0,1));
   if((es=ent->intersectWith(pAcadLine,intType,points))!=Acad::eOk)
    delete pAcadLine;
    return es;
   delete pAcadLine;
 return es;
Acad::ErrorStatus
        const AcGePlane & projPlane,
        AcGePoint3dArray & points,
        int,
        int) const
 if(ent=NULL)
   intType,&projPlane,points))!=Acad::eOk)
   return es;
   return es;
   return es;
 else
   return es;
  AcDbLine *pLine;
  for(int i=0; i<vertexArray.length()-1; i++)
   pLine=new AcDbLine();
   if(i==1)
    pLine->setStartPoint(vertexArray[4]);
    pLine->setEndPoint(vertexArray[2]);
    pLine->setNormal(AcGeVector3d(0,0,1));
   else
    pLine->setStartPoint(vertexArray);
    pLine->setEndPoint(vertexArray[i+1]);
   if((es=ent->intersectWith(pLine,intType,
    delete pLine;
    return es;
   delete pLine;
 return es;
void CMyElevDim::list() const
 AcDbEntity::list();
 acutPrintf("%18s%16s%-9.16q0\n",
  "Elevation:",mElevation);
 AcGePoint3d sp=getStartPoint();
 acutPrintf("%18s%16s","","Start Point:");
 acutPrintf("x=%-9.16q0,y=%-9.16q0,z=%-9.16q0\n",
  sp.x,sp.y,sp.z);
Acad::ErrorStatus
CMyElevDim::explode(AcDbVoidPtrArray & entitySet) const
  return es;
 AcDbLine * line;
  line=new AcDbLine();
  if(i==1)
   line->setStartPoint(vertexArray[4]);
   line->setEndPoint(vertexArray[2]);
   line->setNormal(AcGeVector3d(0,0,1));
  else
   line->setStartPoint(vertexArray);
   line->setEndPoint(vertexArray[i+1]);
  entitySet.append(line);
 AcDbText *pText;
 double elev;
 char str[132];
 elev=this->getElevation();
 acdbRToS(elev,2,2,str);
 pText=new AcDbText(mInsertPoint,str,AcDbObjectId::kNull,mHeight,0);
 entitySet.append(pText);
 return es;
Adesk::Boolean
CMyElevDim::worldDraw(AcGiWorldDraw * worldDraw)
 if(worldDraw->regenAbort())
  return Adesk::kTrue;
 switch(worldDraw->regenType())
 case kAcGiHideOrShadeCommand:
 case kAcGiRenderCommand:
  break;
 case kAcGiStandardDisplay:
 case kAcGiSaveWorldDrawForR12:
 case kAcGiSaveWorldDrawForProxy:
  AOK(drawDim(this,worldDraw,NULL));
  break;
 default:
  assert(Adesk::kFalse);
Acad::ErrorStatus
CMyElevDim::dwgInFields(AcDbDwgFiler * filer)
 if((es=AcDbEntity::dwgInFields(filer))!=Acad::eOk)
  return es;
 AcGePoint3d startPoint,symPoint,insPoint;
 filer->readPoint3d(&startPoint);
 filer->readPoint3d(&symPoint);
 filer->readPoint3d(&insPoint);
 filer->readDouble(&mHeight);
 filer->readDouble(&mLength);
 filer->readDouble(&mElevation);
 acdbWcs2Ecs(asDblArray(startPoint),asDblArray(startPoint),
  asDblArray(AcGeVector3d(0,0,1)),Adesk::kFalse);
 mStartPoint.set(startPoint.x,startPoint.y,startPoint.z);
 acdbWcs2Ecs(asDblArray(symPoint),asDblArray(symPoint),
 mSymbolPoint.set(symPoint.x,symPoint.y,symPoint.z);
 acdbWcs2Ecs(asDblArray(insPoint),asDblArray(insPoint),
 mInsertPoint.set(insPoint.x,insPoint.y,insPoint.z);
 return filer->filerStatus();
Acad::ErrorStatus
CMyElevDim::dwgOutFields(AcDbDwgFiler * filer) const
 if((es=AcDbEntity::dwgOutFields(filer))!=Acad::eOk)
  return es;
 filer->writePoint3d(mStartPoint);
 filer->writePoint3d(mSymbolPoint);
 filer->writePoint3d(mInsertPoint);
 filer->writeDouble(mHeight);
 filer->writeDouble(mLength);
 filer->writeDouble(mElevation);
#ifdef ORDER_DEPENDENT
Acad::ErrorStatus
CMyElevDim::dxfInFields(AcDbDxfFiler * filer)
 if((AcDbEntity::dxfInFields(filer)!=Acad::eOk)||!filer->atSubClassData("CMyElevDim"))
 try
  AcGePoint3d sp,sympt,inspt;
  filer->readItem(&rb);
  if(rb.restype!=AcDb::kDxfXCoord)
   throw AcDb::kDxfXCoord;
  sp=asPnt3d(rb.resva.rpoint);
  if(rb.restype!=AcDb::kDxfXCoord+1)
   throw AcDb::kDxfXCoord+1;
  sympt=asPnt3d(re.resval.rpoint);
  if(rb.restype!=AcDb::kDxfXCoord+2)
   throw AcDb::kDxfXCoord+2;
  inspt=asPnt3d(rb.resval.rpoint);
  if(rb.restype!=AcDb::kDxfReal)
   thrwo AcDb::kDxfReal;
  mHeight=rb.resval.rreal;
  if(rb.restype!=AcDb::kDxfReal+1)
   throw AcDb::kDxfReal+1;
  mLength=rb.resva.rreal;
  filer->realItem(&rb);
  if(rb.restype!=AcDb::kDxfReal+2)
   throw AcDb::kDxfReal+2;
  mElevation=rb.resval.rreal;
  acDbWcs2Ecs(asDblArray(sp),asDblArray(sp),
  mStartPoint.set(sp.x,sp.y,sp.z);
  acdbWcs2Ecs(asDblArray(sympt),asDblArray(sympt),
  mSymbolPoint.set(sympt.x,sympt.y,sympt.z);
  acdbWcs2Ecs(asDblArray(inspt),asDblArray(inspt),
   asDblArray(AcGeVector3d(0,0,,1)),Adesk::kFalse);
  mInsertPoint.set(inspt.x,inspt.y,intpt.z);
 catch(AcDb::DxfCode code)
  filer->pushBackItem();
  filer->setError(Acad::EInvalidDxfCode,"\nError:expected group code %d",code);
#else
Acad::ErrorStatus
 resbuf rb;
 if((AcDbEntity::dxfInFields(filer)!=Acad::eOk)||!filer->atSubclassData("CMyElevDim"))
 Adesk::UInt32 fieldsFlags=0;
 while((es==Acad::eOk) && ((es=filer->readResBuf(&rb))==Acad::eOk))
  switch(rb.restype)
  case AcDb::kDxfXCoord:
   sp=asPnt3d(rb.resval.rpoint);
   fieldsFlags=0x1;
   break;
  case AcDb::kDxfXCoord+1:
   sympt=asPnt3d(rb.resval.rpoint);
   fieldsFlags=0x2;
   break;
  case AcDb::kDxfXCoord+2:
   fieldsFlags=0x3;
   break;
  case AcDb::kDxfReal:
   fieldsFlags=0x4;
   break;
  case AcDb::kDxfReal+1:
   mLength=rb.resval.rreal;
   fieldsFlags=0x5;
   break;
  case AcDb::kDxfReal+2:
   fieldsFlags=0x6;
   break;
  default:
   es=Acad::eEndOfFile;
   break;
 if(es!=Acad::eEndOfFile)
  return Acad::eInvalidResBuf;
 acdbWcs2Ecs(asDblArray(sp),asDblArray(sp),
 mInsertPoint.set(inspt.x,inspt.y,inspt.z);
 return es;
#endif
Acad::ErrorStatus
CMyElevDim::dxfOutFields(AcDbDxfFiler * filer) const
 if((es=AcDbEntity::dxfOutFields(filer))!=Acad::eOk)
  return es;
 filer->writeItem(AcDb::kDxfSubclass,"CMyElevDim");
 filer->writePoint3d(AcDb::kDxfXCoord,mStartPoint);
 filer->writePoint3d(AcDb::kDxfXCoord+1,mSymbolPoint);
 filer->writePoint3d(AcDb::kDxfXCoord+2,mInsertPoint);
 filer->writeDouble(AcDb::kDxfReal,mHeight);
 filer->writeDouble(AcDb::kDxfReal+1,mLength);
 filer->writeDouble(AcDb::kDxfReal+2,mElevation);
  AcGiWorldDraw *  worldDraw,
 if((es=elevDim->getVertices3d(vertexArray))!=Acad::eOk)
  return es;
 AcGePoint3d ptArray[2];
 for(int i=0;i<vertexArray.length()-1; i++)
  if(i==1)
   if(worldDraw!=NULL)
    worldDraw->subEntityTraits().setSelectionMarker(4);
    ptArray[0]=vertexArray[4];
    ptArray[1]=vertexArray[2];
    worldDraw->geometry().polyline(2,ptArray);
   else
   continue;
  if(worldDraw!=NULL)
   if(i==0)
    worldDraw->subEntityTraits().setSelectionMarker(i+1);
   else
    worldDraw->subEntityTraits().setSelectionMarker(i);
  else
  ptArray[0]=vertexArray;
  ptArray[1]=vertexArray[i+1];
  if(worldDraw!=NULL)
  else
 if(worldDraw!=NULL)
  AcGePoint3d insPt;
  AcGeVector3d normal(0,0,1),direction(1,0,0);
  double height,elev;
  char str[132];
  insPt=elevDim->getInsertPoint();
  acdbEcs2Wcs(asDblArray(insPt),asDblArray(insPt),
  height=elevDim->getHeight();
  elev=elevDim->getElevation();
  worldDraw->subEntityTraits().setSelectionMarker(5);
  worldDraw->geometry().text(insPt,normal,direction,height,0.8,0,str);
 else
 return es;
  AcGePoint3dArray& points)
  return es;
 AcGeLineSeg3d tlnsg;
 AcGePoint3d pt;
  if(i==1)
   tlnsg.set(vertexArray[4],vertexArray[2]);
  else
   tlnsg.set(vertexArray,vertexArray[i+1]);
  if(!tlnsg.intersectWith(line,pt))
   continue;
  else
   points.append(pt);
 return es;
  const AcDbLine * line,
  const AcGePlane *projPlane,
  AcGePoint3dArray &points)
 AcGeLineSeg3d lnsg(line->startPoint(),line->endPoint());
 es=intLine(elevDim,lnsg,intType,projPlane,points);
 return es;
  const AcGeLineSeg3d lnsg,
 if((es=elevDim->getVertices3d(vertexArray) )!=Acad::eOk)
  return es;
 AcGeLine3d aline(lnsg.startPoint(),lnsg.endPoint());
 AcGePoint3d pt;
 AcGePoint3d dummy;
  if(i==1)
  else
   if(projPlane==NULL)
    if(!tlnsg.intersectWith(aline,pt))
     continue;
    else
     points.append(pt);
   else
    if(!tlnsg.projIntersectWith(aline,projPlane->normal(),pt,dummy))
     continue;
    else
     points.append(pt);
  else
   if(projPlane==NULL)
    if(!tlnsg.intersectWith(lnsg,pt))
     continue;
    else
     points.append(pt);
   else
    if(!tlnsg.projIntersectWith(lnsg,projPlane->normal(),pt,dummy))
     continue;
    else
     points.append(pt);
 return es;
 AcGeCircArc3d aarc(arc->center(),arc->normal(),
  arc->normal().perpVector(),arc->radius(),
  arc->startAngle(),arc->endAngle());
 es=intArc(elevDim,aarc,intType,projPlane,points);
 return es;
  return es;
 AcGeCircArc3d acircle(arc.center(),arc.normal(),arc.radius());
 AcGeLineSeg3d lnsg;
 AcGePoint3d pt1,pt2;
 AcGePoint3d dummy1 ,dummy2;
 int howMany;
  if(i==1)
  else
   if(projPlane==NULL)
    if(!acircle.intersectWith(lnsg,howMany,pt1,pt2))
     continue;
    else
     if(howMany>1)
      points.append(pt1);
      points.append(pt2);
     else
      points.append(pt1);
   else
    if(!acircle.projIntersectWith(lnsg,projPlane->normal(),
     howMany,pt1,pt2,dummy1,dummy2))
     continue;
    else
     if(howMany>1)
      points.append(pt1);
      points.append(pt2);
     else
      points.append(pt1);
  else
   if(projPlane==NULL)
    if(!arc.intersectWith(lnsg,howMany,pt1,pt2))
     continue;
    else
     if(howMany>1)
      points.append(pt1);
      points.append(pt2);
     else
      points.append(pt1);
   else
    if(!arc.projIntersectWith(lnsg,projPlane->normal(),
     continue;
    else
     if(howMany>1)
      points.append(pt1);
      points.append(pt2);
     else
      points.append(pt1);
 return es;
    const AcDbCircle * circle,
 AcGeCircArc3d acircle(circle->center(),circle->normal(),circle->radius());
 es=intCircle(elevDim,acircle,intType,projPlane,points);
 return es;
  return es;
 AcGeLineSeg3d lnsg;
 AcGePoint3d dummy1,dummy2;
 int howMany;
  if(i==1)
  else
  if(projPlane==NULL)
   if(!circle.intersectWith(lnsg,howMany,pt1,pt2))
    continue;
   else
    if(howMany>1)
     points.append(pt1);
     points.append(pt2);
    else
     points.append(pt1);
  else
   if(!circle.projIntersectWith(lnsg,projPlane->normal(),
    continue;
   else
    if(howMany>1)
     points.append(pt1);
     points.append(pt2);
    else
     points.append(pt1);
 return es;
Acad::ErrorStatus
addToModelSpace(AcDbObjectId & objId,AcDbEntity *pEntity)
 AcDbBlockTable * pBlockTable;
 AcDbBlockTableRecord *pSpaceRecord;
 acdbHostApplicationServices()->workingDatabase()
  ->getSymbolTable(pBlockTable,AcDb::kForRead);
 pBlockTable->getAt(ACDB_MODEL_SPACE,pSpaceRecord,AcDb::kForWrite);
 pSpaceRecord->appendAcDbEntity(objId,pEntity);
 pBlockTable->close();
 pEntity->close();
 pSpaceRecord->close();
 return es;
void elevDim()
 ads_name ename;
 AcGePoint3d pt;
 if(acedEntSel("\nPick a line:",ename,asDblArray(pt))!=RTNORM)
  acutPrintf("\nPick entity fail!");
  return;
 AcDbObjectId objId;
 AcDbLine * pLine;
 acdbGetObjectId(objId,ename);
 if(acdbOpenAcDbEntity((AcDbEntity * &)pLine,
  objId,AcDb::kForRead)!=Acad::eOk)
  return;
 AcGePoint3d startPt,endPt;
 if(pLine!=NULL)
  startPt=pLine->startPoint();
  endPt=pLine->endPoint();
  pLine->close();
 else
  return;
 if(fabs(startPt.y-endPt.y)>1e-10)
  acutPrintf("\nThe line must be horizontal!");
  return;
 double height=10.0;
 double length=50.0;
 if(acedGetPoint(NULL,"\nPlease input start point:",asDblArray(startPoint))!=RTNORM)
  return;
 startPoint.set(startPoint.x,startPt.y,startPoint.z);
 CMyElevDim * pDim=new CMyElevDim;
 if(pDim==NULL)
  ads_printf("\nOut of memory");
  return;
 pDim->set(startPoint,height,length);
 pDim->setDatabaseDefaults(acdbHostApplicationServices()->workingDatabase());
 if(addToModelSpace(objId,pDim)!=Acad::eOk)
  delete pDim;
 return ;
void initApp()
 acedRegCmds->addCommand("ASDK_CUSTOMENTITY_COMMANDS",
  "ELEVDIM",
  "ELEVDIM",
  ACRX_CMD_MODAL,
  elevDim);
 CMyElevDim::rxInit();
 acrxBuildClassHierarchy();
void unloadApp()
 acedRegCmds->removeGroup("ASDK_CUSTOMENTITY_COMMANDS");
 deleteAcRxClass(CMyElevDim::desc());
AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg,void *pkt)
 switch(msg)
 case AcRx::kInitAppMsg:
  acrxUnlockApplication(pkt);
  acrxRegisterAppMDIAware(pkt);
  initApp();
  break;
 case AcRx::kUnloadAppMsg:
  unloadApp();
  break;
 return AcRx::kRetOK;
GMT+8, 2025-5-11 07:00 , Processed in 0.177330 second(s), 17 queries , Gzip On.
