帖子
查看: 1690|回复: 2
如何实现复合选择(如选择图层为"zd",红色的多段线)
发表于 2005-9-13 21:44:00 | 显示全部楼层 |阅读模式
cad的帮助写的太简略了
ssObj.select语句,它的过滤条件不知道怎么写
请高手相助,我想应该能够一次选中吧?
发表于 2005-9-13 22:31:00 | 显示全部楼层
Sub Example_Select()
    Dim ssetObj As AcadSelectionSet
    On Error Resume Next
    Set ssetObj = ThisDrawing.SelectionSets.Add("SSET")
    If Err <> 0 Then
      Set ssetObj = ThisDrawing.SelectionSets.Item("SSET")
      ssetObj.Clear
    End If
    Dim mode As Integer
    Dim obj As AcadEntity
    mode = acSelectionSetAll
    Dim gpCode(2) As Integer
    Dim dataValue(2) As Variant
    gpCode(0) = 0
    dataValue(0) = "LWPOLYLINE"
    gpCode(1) = 8
    dataValue(1) = "zd"
    gpCode(2) = 62
    dataValue(2) = 1
    Dim groupCode As Variant, dataCode As Variant
    groupCode = gpCode
    dataCode = dataValue
    ssetObj.Select mode, , , groupCode, dataCode
    MsgBox "图中有" & ssetObj.Count & "个图元已加入到选择集SSET中。"
    For Each obj In ssetObj
     obj.Highlight True
    Next
End Sub
 楼主| 发表于 2005-9-14 22:57:00 | 显示全部楼层
3ku vermuch
GMT+8, 2025-7-9 16:22 , Processed in 0.146013 second(s), 23 queries , Gzip On.
