查看: 2778|回复: 2
对象的关联
发表于 2005-9-9 11:19:00 | 显示全部楼层 |阅读模式
exam10b.cpp
#include "string.h"
#include "stdlib.h"
#include "aced.h"
#include "dbents.h"
#include "dbsymtb.h"
#include "dbapserv.h"
#include "adslib.h"
void assocLines();
void addToModelSpace(AcDbObjectId&,AcDbEntity *);
void initApp(void);
void unloadApp(void);
extern "C"
AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode,void *);
class MyObjectNotify:public AcDbObject
public:
 ACRX_DECLARE_MEMBERS(MyObjectNotify);
 MyObjectNotify(){};
 void eLinkage(AcDbObjectId i,double f=1.0)
  mId=i;
  mFactor=f;
 void modified(const AcDbObject *);
 Acad::ErrorStatus dwgInFields(AcDbDwgFiler *);
 Acad::ErrorStatus dwgOutFields(AcDbDwgFiler *)const ;
 Acad::ErrorStatus dxfInFields(AcDbDxfFiler *);
 Acad::ErrorStatus dxfOutFields(AcDbDxfFiler *) const;
private:
 AcDbObjectId mId;
 double mFactor;
ACRX_DXF_DEFINE_MEMBERS(MyObjectNotify,AcDbObject,
      AcDb::kDHL_CURRENT,AcDb::kMReleaseCurrent,
      0,MYOBJECTMODIFY,exam10b);
void MyObjectNotify::modified(const AcDbObject *pObj)
 AcDbLine *pLine=AcDbLine::cast(pObj);
 if(!pLine)
  const char * str=pObj->isA()->name();
  acutPrintf("This is a %s.\n",str);
  acutPrintf("i only work with lines,sorry.\n");
  return;
 acutPrintf("\nReactor attached to %lx calling %lx.\n",
  pLine->objectId(),mId);
 AcDbLine *pLine2;
 if(acdbOpenObject((AcDbObject *&)pLine2,mId,
  AcDb::kForWrite)==Acad::eOk)
  AcGePoint3d p=pLine->startPoint();
  AcGePoint3d q=pLine->endPoint();
  AcGeVector3d v=q-p;
  double len=v.length();
  p=pLine2->startPoint();
  q=pLine2->endPoint();
  v=q-p;
  v=len*mFactor *v.normal();
  pLine2->setEndPoint(p+v);
  pLine2->close();
Acad::ErrorStatus
MyObjectNotify::dwgInFields(AcDbDwgFiler * filer)
 assertWriteEnabled();
 AcDbObject::dwgInFields(filer);
 filer->readItem(&mFactor);
 filer->readItem((AcDbSoftPointerId *) &mId);
 return filer->filerStatus();
Acad::ErrorStatus
MyObjectNotify::dwgOutFields(AcDbDwgFiler * filer) const
 assertReadEnabled();
 AcDbObject::dwgOutFields(filer);
 filer->writeItem(mFactor);
 filer->writeItem((AcDbSoftPointerId *) &mId);
Acad::ErrorStatus
MyObjectNotify::dxfInFields(AcDbDxfFiler * filer)
 Acad::ErrorStatus es;
 if((es=AcDbObject::dxfInFields(filer))!=Acad::eOk)
  return es;
 if(!filer->atSubclassData("MyObjectNotify"))
  return Acad::eBadDxfSequence;
 struct resbuf rbIn;
 while(es==Acad::eOk)
  if((es=filer->readItem(&rbIn))==Acad::eOk)
   if(rbIn.restype==AcDb::kDxfReal)
    mFactor=rbIn.resval.rreal;
   else if(rbIn.restype==AcDb::kDxfSoftPointerId)
    acdbGetObjectId(mId,rbIn.resval.rlname);
   else
    return (filer->pushBackItem());
Acad::ErrorStatus
MyObjectNotify::dxfOutFields(AcDbDxfFiler * filer) const
 AcDbObject::dxfOutFields(filer);
 filer->writeItem(AcDb::kDxfSubclass,
  "MyObjectNotify");
 filer->writeItem(AcDb::kDxfReal,mFactor);
 filer->writeItem(AcDb::kDxfSoftPointerId,mId);
void assocLines()
 AcDbDatabase *pDb=acdbHostApplicationServices()->workingDatabase();
 AcDbObjectId aId,bId;
 AcDbLine *pLineA=new AcDbLine;
 pLineA->setDatabaseDefaults(pDb);
 pLineA->setStartPoint(AcGePoint3d(1,1,0));
 pLineA->setEndPoint(AcGePoint3d(2,1,0));
 addToModelSpace(aId,pLineA);
 ads_printf("Line A is %lx from 1,1 to 2,1j.\n",
  pLineA->objectId());
 AcDbLine *pLineB=new AcDbLine;
 pLineB->setDatabaseDefaults(pDb);
 pLineB->setStartPoint(AcGePoint3d(1,2,0));
 pLineB->setEndPoint(AcGePoint3d(2,2,0));
 addToModelSpace(bId,pLineB);
 ads_printf("Line B is %lx from 1,2 to 2,2.\n",
  pLineB->objectId());
 AcDbDictionary *pNamedObj;
 AcDbDictionary *pNameList;
 pDb->getNamedObjectsDictionary(pNamedObj,
  AcDb::kForWrite);
 if(pNamedObj->getAt("ASDK_DICT",
  (AcDbObject * &) pNameList,AcDb::kForWrite)
  ==Acad::eKeyNotFound)
  pNameList=new AcDbDictionary;
  AcDbObjectId DictId;
  pNamedObj->setAt("ASDK_DICT",pNameList,DictId);
 pNamedObj->close();
 MyObjectNotify *pObj=new MyObjectNotify();
 pObj->eLinkage(bId);
 AcDbObjectId objId;
 if((pNameList->getAt("object_to_notify_A",objId))
  pNameList->setAt("object_to_notify_A",pObj,objId);
  pObj->close();
 else
  delete pObj;
  ads_printf("object_to_notify_A already existes\n");
 pLineA->addPersistentReactor(objId);
 pLineA->close();
 pObj->eLinkage(aId);
 if((pNameList->getAt("object_to_notify_B",objId))
  pNameList->setAt("object_to_notify_B",pObj,objId);
  pObj->close();
 else
  delete pObj;
  ads_printf("object_to_notify_b already existes\n");
 pNameList->close();
 pLineB->addPersistentReactor(objId);
 pLineB->close();
void addToModelSpace(AcDbObjectId &objId,AcDbEntity * pEntity)
 AcDbBlockTable *pBlockTable;
 AcDbBlockTableRecord *pSpaceRecord;
  ->getSymbolTable(pBlockTable,AcDb::kForRead);
 pBlockTable->getAt(ACDB_MODEL_SPACE,pSpaceRecord,
  AcDb::kForWrite);
 pBlockTable->close();
 pSpaceRecord->appendAcDbEntity(objId,pEntity);
 pSpaceRecord->close();
 return;
void initApp()
 acedRegCmds->addCommand("EXAM10b",
  "ALINES",
  "ALINES",
  ACRX_CMD_MODAL,
  assocLines);
 MyObjectNotify::rxInit();
 acrxBuildClassHierarchy();
void unloadApp()
 acedRegCmds->removeGroup("EXAM10B");
 deleteAcRxClass(MyObjectNotify::desc());
AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void *appId)
 switch(msg)
 case AcRx::kInitAppMsg:
  acrxDynamicLinker->unlockApplication(appId);
  acrxDynamicLinker->registerAppMDIAware(appId);
  initApp();
  break;
 case AcRx::kUnloadAppMsg:
  unloadApp();
 return AcRx::kRetOK;
 楼主| 发表于 2005-9-9 11:20:00 | 显示全部楼层
exam10b.def
LIBRARY  exam10b
DESCRIPTION  "EXAM10B APPLICATION"
EXPORTS
acrxEntryPoint  RIVATE
acrxGetApiVersion RIVATE
 楼主| 发表于 2005-9-9 11:23:00 | 显示全部楼层
用vc++6.0开发,autocad2002中使用正常。
command :ALINES
会增加两条直线,对任意一条直线操作,都会影响到第二个直线。
GMT+8, 2025-5-9 02:44 , Processed in 0.165654 second(s), 25 queries , Gzip On.
