查看: 2211|回复: 4
CAD中的字体乱码问题?>
发表于 2005-9-7 16:59:00 | 显示全部楼层 |阅读模式
void addtext(char textString[512])
 AcDbBlockTable *pBlockTablew;
 acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTablew, AcDb::kForRead);
 AcDbBlockTableRecord *pBlockTableRecordw;
 pBlockTablew->getAt(ACDB_MODEL_SPACE, pBlockTableRecordw, AcDb::kForWrite);
 pBlockTablew->close();
 AcGePoint3d textPosition(10.0, 10.0, 0.0);
 AcGePoint3d atextPosition(20.0, 10.0, 0.0);
 //char textString[512] = "建设项目选址意见书[2005字]    号红线附图";
 double textHeight = 5.5296;
 double textWidthFactor = 0.8000;
 double textRotation = 0.0;
 AcDbText *pText=new AcDbText(textPosition, textString, AcDbObjectId::kNull, textHeight, textRotation);
 pText->setHorizontalMode(AcDb::kTextMid);
 pText->setAlignmentPoint(atextPosition);
   //???? pText->setTextStyle(1);//=HZTXT;
 AcDbObjectId textId;
 pBlockTableRecordw->appendAcDbEntity(textId, pText);
 pBlockTableRecordw->close();
 pText->close();
如上   我在执行文字标注时 用到这个函数
结果文字是乱码,请问是不是AcDbObjectId::kNull这个变量需要改一下,我想字体设置成:HZTXT,怎么改?
发表于 2005-9-8 08:52:00 | 显示全部楼层
我帮你顶
 楼主| 发表于 2005-9-8 10:49:00 | 显示全部楼层
共享一段mm给我的代码    一起研究!
  AcDbDatabase *pDb = acdbHostApplicationServices()->workingDatabase ();
      AcDbBlockTable *pBT;
      AcDbBlockTableRecord *pBTR;
      Acad::ErrorStatus  es; //打开数据库->块表->块表记录
es = pDb->getBlockTable (pBT,AcDb::kForRead );
      // ERROR HANDLE
      es = pBT->getAt (ACDB_MODEL_SPACE,pBTR,AcDb::kForWrite );
//get the standard text style
      AcDbTextStyleTable *pTST;
      AcDbTextStyleTableRecord *pTSTR;
      es = pDb->getTextStyleTable (pTST,AcDb::kForRead );
//文字样式表-〉文字样式表记录-〉打开记录读取
AcDbObjectId idTextStyle;
      es = pTST->getAt("Standard",idTextStyle);
      es = pTST->getAt("Standard",pTSTR,AcDb::kForWrite );
      pTSTR->setFileName("iso");//****
      if(es != Acad::eOk){
          acutPrintf("fail to get the standard text style\n");
      //es = acdbOpenObject(pEnt,idTextStyle,AcDb::kForRead );
      AcDbMText *pText = new AcDbMText();
      pText->setLocation (AcGePoint3d(10,10,0));
      pText->setTextStyle (idTextStyle);
      pText->setRotation (0.5);
      pText->setContents ("\\T1.2;this is only simple char");
      pText->setColorIndex (1);
      AcDbObjectId idTxt = AcDbObjectId::kNull ;
      pBTR->appendAcDbEntity(idTxt,pText);
      pText->close();//文本对象
pBTR->close();//块表记录
pBT->close();//块表
pTST->close();//文字样式表
pTSTR->close();//文字样式表记录
发表于 2005-9-8 10:58:00 | 显示全部楼层
首先应该看看有没有缺少字体文件,然后考虑文字样式的设置问题
 楼主| 发表于 2005-9-8 14:19:00 | 显示全部楼层
楼上说的对  我的问题解决了,按照上个程序,设置字体如下:
  pTSTR->setFileName("HZTXT");
然后在CAD中输入:style
新建一个字体样式:HZTXT
选中大字体,然后选中txt.shx,后面选中:hztxt
运行一下,一切OK!!!(附上字体文件)
GMT+8, 2025-5-9 02:49 , Processed in 0.171552 second(s), 23 queries , Gzip On.
