查看: 2011|回复: 6
[ARX]cad报错 (附源码)
发表于 2005-9-1 09:33:00 | 显示全部楼层 |阅读模式
dd
这是个曲柄摇杆机构的运动轨迹的仿真程序,代码编译无错,但在CAD2002中出错提示如下:
希望高人们能指点一下,先在这里谢过了!
 楼主| 发表于 2005-9-1 09:39:00 | 显示全部楼层
主要代码如下:
#include "StdAfx.h"
#include "StdArx.h"
#include "resource.h"
#include <stdio.h>
#include "adslib.h"
#include "adesk.h"
#include "aced.h"
#include "math.h"
#include "acdb.h"
#include "dbents.h"
#include <dbsymtb.h>
#include "rxregsvc.h"
#include <rxdlinkr.h>
#include <geassign.h>
#include <dbapserv.h>
// This is command 'MOTOIN, by  [2005-8-31], ,
void xlgisMotoin()
#ifdef OARXWIZDEBUG
 acutPrintf ("\nOARXWIZDEBUG - xlgisMotoin() called.");
#endif // OARXWIZDEBUG
 double A[3]={130.000,83.000,0.000};
 double D[3]={213.000,83.000,0.000};
 //四边边长
 double a,b,c,d;
 a=34.000;
 b=101.000;
 c=64.000;
 d=D[0]-A[0];
 //定义四点abcd
 AcGePoint3d  APt(A[0],A[1],A[2]);
 AcGePoint3d  DPt(D[0],D[1],D[2]);
 double B[36][3];
 double C[36][3];
 //B点和C点的运动轨迹计算结果数组
 AcGePoint3d  BPt[36];
 AcGePoint3d  CPt[36];
 ///计算分析
 double DETFI,FI,THETA,THETA1,THETA2;
 DETFI=3.1415926*10/180;//步长
 FI=0;//初始角度
 for (int i=0;i<36;i++)
 {//计算各点的坐标
  double BD=sqrt(a*a+d*d-2*a*d*cos(FI));
  THETA1=acos(-(a*a-d*d-BD*BD)/(2*d*BD));
  THETA2=acos(-(b*b-c*c-BD*BD)/(2*c*BD));
  THETA=THETA1+THETA2;
  //B点坐标
  B[0]=A[0]+a*cos(FI);
  B[1]=A[1]+a*sin(FI);
  B[2]=0.000;
  //C点坐标
  C[0]=D[0]+c*cos(THETA);
  C[1]=D[1]+c*sin(THETA);
  C[2]=0.000;
  FI=FI+DETFI;
  BPt.x=B[0];
  BPt.y=B[1];
  BPt.z=B[2];
  CPt.x=C[0];
  CPt.y=C[1];
  CPt.y=C[2];
 //创建各图形
 AcDbLine  *pLine=new  AcDbLine(APt,DPt);//创建直线AD实体对象
 AcDbBlockTable *pBlockTable;
 acdbHostApplicationServices()->workingDatabase()->getBlockTable(
  pBlockTable,AcDb::kForRead);//    //获得当前块表(下)
 //获得当前块表的块表记录(下)
    AcDbBlockTableRecord *pBlockTableRecord;
    pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,
        AcDb::kForWrite);
    pBlockTable->close();//使用完毕,关闭块表
 AcDbObjectId  lineId;
 AcDbObjectId  circleId_A;
 AcDbObjectId  circleId_D;
 AcDbCircle  *pCircleA;
 AcDbCircle  *pCircleD;
 pCircleA=new  AcDbCircle(APt,AcGeVector3d(0,0,1),1);
 //创建A点小圆实体对象R=1
 pCircleD=new  AcDbCircle(DPt,AcGeVector3d(0,0,1),1);
 //创建D点小圆实体对象R=1
 pBlockTableRecord->appendAcDbEntity(lineId,pLine);
 //将直线IO加入到块表记录中
 pBlockTableRecord->appendAcDbEntity(circleId_A,pCircleA);
 //将A点小圆加入到块表记录中
 pBlockTableRecord->appendAcDbEntity(circleId_D,pCircleD);
 //将D点小圆加入到块表记录中
 pBlockTableRecord->close();//关闭块表记录
    pLine->close();//关闭实体直线AD对象
 pCircleA->close();//关闭A点小圆实体对象
 pCircleD->close();//关闭D点小圆实体对象
 AcDbObjectId  circleId_B[36];
 AcDbObjectId  circleId_C[36];
 AcDbCircle  *pCircleB;
 AcDbCircle  *pCircleC;
 for ( i=0;i<36;i++ )
 {//创建BC点小圆 和AB  BC  CD
  AcDbObjectId  idLine_AB;
  AcDbObjectId  idLine_BC;
  AcDbObjectId  idLine_CD;
  //获得当前块表(下)
   ->getSymbolTable(pBlockTable, AcDb::kForRead);
  //获得当前块表的块表记录(下)
   AcDb::kForWrite);
  pCircleB=new  AcDbCircle(BPt,AcGeVector3d(0,0,1),1);
  //创建B点小圆实体对象R=1
  pCircleC=new  AcDbCircle(CPt,AcGeVector3d(0,0,1),1);
  //创建C点小圆实体对象R=1
  AcDbLine *pLine_AB=new  AcDbLine(APt,BPt);
  //创建AB实体对象
  AcDbLine *pLine_BC=new  AcDbLine(BPt,CPt);
  //创建BC实体对象
  AcDbLine *pLine_CD=new  AcDbLine(CPt,DPt);   //创建CD实体对象
  //加入到块表记录
  pBlockTableRecord->appendAcDbEntity(circleId_B,pCircleB);
  pBlockTableRecord->appendAcDbEntity(circleId_C,pCircleC);
  pBlockTableRecord->appendAcDbEntity(idLine_AB,pLine_AB);
  pBlockTableRecord->appendAcDbEntity(idLine_BC,pLine_BC);
  pBlockTableRecord->appendAcDbEntity(idLine_CD,pLine_CD);
  //关闭各图形对象
  pCircleB->close();
  pCircleC->close();
  pLine_AB->close();
  pLine_BC->close();
  pLine_CD->close();
 }//循环结束
 // TODO: Implement the command
发表于 2005-9-1 13:14:00 | 显示全部楼层
出现C000005的错误原因就是指针是null的时候进行了操作, 你检查看看
发表于 2005-9-2 10:14:00 | 显示全部楼层
我下载了,运行没有问题。
 楼主| 发表于 2005-9-6 13:54:00 | 显示全部楼层
我还是没查出来!那位高手能帮忙看下吗?先谢了
发表于 2005-9-7 11:47:00 | 显示全部楼层
没有什么问题一切正常 你重新加载一下尝试一下
 楼主| 发表于 2005-9-7 17:34:00 | 显示全部楼层
呵呵  奇怪  是没问题!是不是因为我这回是在release模式下编译的缘故啊
GMT+8, 2025-5-9 03:10 , Processed in 0.289093 second(s), 24 queries , Gzip On.
