楼主: masterlong
请教一个很特别的问题
 楼主| 发表于 2005-7-31 22:39:00 | 显示全部楼层
发个图上来大家看看
1M多
目前我唯一能想到的解决办法
就是转为dxf格式后
删除不需要的内容再转为dwg
可是我能这样做
那些只会CAD操作的人不会啊
 楼主| 发表于 2005-7-31 22:40:00 | 显示全部楼层
论坛上传功能不能用吗
 楼主| 发表于 2005-7-31 22:44:00 | 显示全部楼层
  当您的朋友需要提取此文件时只需:
     匿名提取文件连接 http://pickup.mofile.com/4784767482425701
     或登录Mofile,使用提取码 4784767482425701 提取文件
还是发我的mofile里吧
三天后过期
想看的人要下抓紧
 楼主| 发表于 2005-8-2 01:29:00 | 显示全部楼层
编了个简单的程序,将就的用
(defun ts_err()
 (setvar "cmdecho" 0)
 (setvar "filedia" 0)
 (setq olderr *error* )
   (defun *error*(msg)
    (princ "\n程序中断,未清除任何“命名图层过滤器”")
    (close *dxf文件_old)
 (close *dxf文件_new)
 (setvar "filedia" 1)
 (setvar "cmdecho" 1)
 (setq *error* olderr)
(defun c:pulf()
 (princ "\n本程序将完全清理文件内的“命名图层过滤器”。")
 (princ "\n若文件内并无“命名图层过滤器”,运行本程序可能导致死循环.")
 (princ "\n程序长时间无反应,请按“ESC键”退出,并检查文件内是否含有“命名图层过滤器”.")
 (princ "\n若文件内确实含有“命名图层过滤器”,请再次运行本程序,并耐心等待")
 (ts_err)
 (setq *dwgname (getvar "DWGNAME"))
 (setq *dwgname (strcat (substr *dwgname 1 (- (strlen *dwgname) 4)) ".dwg" ))
 (setq *dxfname (strcat (substr *dwgname 1 (- (strlen *dwgname) 4)) ".dxf" ))
 (setq *scrname (strcat (substr *dwgname 1 (- (strlen *dwgname) 4)) ".scr" ))
 (setq *path (getvar "DWGPREFIX"))
 (setq *alldxf (strcat *path *dxfname))
 (setq *alldwg (strcat *path *dwgname))
 (setq *allscr (strcat *path *scrname))
 (princ "\n正在清理图层过滤器,请稍后....")
 (setq *dxf文件_old (open *alldxf "w"))
 (close *dxf文件_old)
 (command "saveas" "DXF" "V" "2000" "16" *alldxf "y")
 (command "saveas" "2000" *alldwg "y")
 (清理层过滤表)
 (关再开)
(defun 清理层过滤表()
 (setq *dxf文件_old (open *alldxf "r"))
 (setq *dxf文件_new (open (strcat (substr *alldxf 1 (- (strlen *alldxf) 4)) "new.dxf" ) "w") )
 (setq loop_1 T)
 (while loop_1
  (setq a (read-line *dxf文件_old))
  (cond
   ((null a)(setq loop_1 nil) )
   ((= a "AcDbDictionary")
    (write-line a *dxf文件_new)
     (setq loop_2 T)
     (while loop_2
      (setq a1 (read-line *dxf文件_old))
      (setq a2 (read-line *dxf文件_old))
      (setq a3 (read-line *dxf文件_old))
      (setq a4 (read-line *dxf文件_old))
      (write-line a1 *dxf文件_new)
      (write-line a2 *dxf文件_new)
      (write-line a3 *dxf文件_new)
      (write-line a4 *dxf文件_new)
      (if  (and
        (= a1 "280")
        (= a2 "     1")
        (= a3 "281")
        (= a4 "     1")
        (setq loop_3 T)
        (while loop_3
         (if (and (= a1 "  0")(= a2 "DICTIONARY"))
           (setq loop_3 nil)
           (setq loop_2 nil)
       (setq loop_2 nil)
   ((/= a "AcDbDictionary") (write-line a *dxf文件_new) )
 (close *dxf文件_old)
 (close *dxf文件_new)
 (princ "ok")
 (princ "\n重新打开文件")(princ)
(defun 关再开()
 (setq *scrfile (open *allscr "w"))
 (write-line "close" *scrfile)
 (write-line "open" *scrfile)
 (write-line (strcat (substr *alldxf 1 (- (strlen *alldxf) 4)) "new.dxf" ) *scrfile)
 (write-line "saveas" *scrfile)
 (write-line "2000" *scrfile)
 (write-line *alldwg *scrfile)
 (write-line "Y" *scrfile)
 (write-line "filedia" *scrfile)
 (write-line "1" *scrfile)
 (write-line "cmdecho" *scrfile)
 (close *scrfile)
 (command "script" *allscr)
GMT+8, 2025-12-20 00:09 , Processed in 0.156278 second(s), 16 queries , Gzip On.
