查看: 4157|回复: 7
五金模具中集体偏移的程序
发表于 2005-7-13 23:45:00 | 显示全部楼层 |阅读模式
我想做一个五金模具中集体偏移的程序.
比如我的图形有5个圆,5个封闭复合线.
我现在选择此10个图元后,我输入正值,此10个图元集体向外偏移.
我输入负值,此10个图元集体向内偏移.
考虑了好久,没搞定输入负值的情况,请高手指点.
(我需要程序原代码)
发表于 2005-7-18 12:20:00 | 显示全部楼层
;1. 将下载的“off1.fas”存入G盘目录下,如存入
;   其它地址,则修改程序中“(load "g:/off1.fas")”
;   使之相符。
;2. 使用以下示例程序,即可完成图元的集体偏移。
(defun c:cc()
    (if (null off1)(load "g:/off1.fas"))
    (while (setq jl (getreal "\n 请选择偏移距离<回车结束>:"))
        (princ "\n 请选择要偏移的图元:")
        (if (and jl (setq sa (ssget))) (off1 jl sa))
;   使之相符。
(defun c:cc()
发表于 2005-7-18 12:28:00 | 显示全部楼层
怎么附件传不上来,请致电hrycly@126.com
发表于 2005-10-6 12:11:00 | 显示全部楼层
(defun c:fs(/ oce vs1 ent_list id list_len ent msg od)
  ;(setq oce (getvar "cmdecho"))
  ;(setvar "cmdecho" 0)
  (setq vs1 (getvar "vsmax"))
  (setq msg (strcat "Give the offset dist<"  (rtos (getvar "offsetdist")) ">:" ))
  (setq od (getdist  msg ))
  (if (= nil od)
   (setq od (getvar "offsetdist"))
   (setvar "offsetdist" od)
  (setq ent_list (ssget))
  (setq list_len (sslength ent_list))
  (setq id 0)
  (ssname ent_list id)
  (repeat list_len
    (setq ent (ssname ent_list id))
    (command ".offset"  "" ent vs1 "")
    (command ".change" (entlast) "" "p" "c" "red" "")
    (entdel ent)
    (setq id (1+ id))
  (prinC (strcat (rtos list_len 2 0)  " Entites has offseted."))
  (PRINC)
不过这个只能放大
发表于 2021-12-6 20:16:27 | 显示全部楼层
chenknight 发表于 2005-10-6 12:11
(defun c:fs(/ oce vs1 ent_list id list_len ent msg od)&nbsp; ;(setq oce (getvar "cmdecho"))&nbsp; ;( ...
谢谢兄弟 分享的好程序
发表于 2021-12-7 09:22:10 | 显示全部楼层
(defun C:py ( / curve ent holdcmd holdosmode jang n pt pt1 pt2 ss tmp x)
        (if (not (tblsearch "layer" "补偿前"))
    (command "layer" "n" "补偿前" "c" "4" "补偿前" "")
  (defun LEN (CURVE / TLEN)
    (setq TLEN (vlax-curve-getdistatparam
   CURVE
   (vlax-curve-getendparam CURVE)
  (setq HOLDOSMODE (getvar "OSMODE"))
  (setq HOLDCMD (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (setvar "OSMODE" 0)
                (while
  (setq ss (ssget '((0 . "*LINE,circle,ARC"))))
      (setq n 0)
      (initget 2)
        (if *move*
                (setq tee_dist (getreal (strcat  "\n请输入补偿:<" (rtos *move* 2 2) ">:")))
                (setq tee_dist (getreal "\n请输入补偿:"))
        (if (null tee_dist)
                (setq tee_dist *move*)
                (setq *move* tee_dist)
                        (setq tee_dist(/ tee_dist 2))
      (repeat (sslength ss)
(setq ent (ssname ss n)
       n   (1+ n)
(setq CURVE (vlax-ename->vla-object ENT)
       x     (vlax-curve-getParamAtDist curve (/ (len curve) 3.33))
       pt    (vlax-curve-getPointAtParam curve x)
(setq JANG (angle '(0 0 0) (vlax-curve-getfirstderiv CURVE X)))
(setq PT1 (polar PT (+ JANG (* 0.5 pi)) 0.00000001))
(setq PT2 (polar PT (- JANG (* 0.5 pi)) 0.00000001))
(command "_.OFFSET" (abs tee_dist) ENT PT1 "")
(if (or (and (> tee_dist 0) (> (LEN CURVE) (LEN (entlast))))
  (and (< tee_dist 0) (< (LEN CURVE) (LEN (entlast))))
     (entdel (entlast))
                      (command "_.OFFSET" (abs tee_dist) ENT PT2 "")
(command "change" ss "" "p" "la" "补偿前" "c" 150 "")
          (setq sc_pd (getstring "\n是否删除对象[删除(Y)]:"))
  (if (or (eq sc_pd "y") (eq sc_pd "Y") (eq sc_pd ""))
       (command "ERASE" ss "" ) )
  (setvar "OSMODE" HOLDOSMODE)
  (setvar "CMDECHO" HOLDCMD)
发表于 2021-12-27 00:11:07 来自手机 | 显示全部楼层
感谢你的分享
GMT+8, 2025-5-1 07:32 , Processed in 0.182308 second(s), 25 queries , Gzip On.
