查看: 1773|回复: 2
[求助]想到这样一个问题
发表于 2005-7-10 12:23:00 | 显示全部楼层 |阅读模式
为了加快文字输入速度和准确性,能否像定义快捷键似的。
在单行文本编辑是时候,定义某一个键就代替一个常用的字符窜。
比如在单行文本编辑时候,用小键盘的*(因为这个键很少用)来代替为:123456
这样的想法能否实现?
发表于 2005-7-10 20:07:00 | 显示全部楼层
理论上是可以,编程可以实现,也可以用replace功能实现。
发表于 2005-7-13 23:14:00 | 显示全部楼层
当然是可以啊!
(defun c:*(/ pt1 h) (SETQ pt1 (getpoint "\n输入文字起点:"))
        (command "text" "s" "仿宋体" pt1 pause "0" "边钉线割") (print))
(defun c:T01(/ pt1 h) (SETQ pt1 (getpoint "\n输入文字起点:"))
        (command "text" "s" "仿宋体" pt1 pause "0" "导柱") (print))
(defun c:T02(/ pt1 h) (SETQ pt1 (getpoint "\n输入文字起点:"))
         (command "text" "s" "仿宋体" pt1 pause "0" "管位") (print))
(defun c:T03(/ pt1 h) (SETQ pt1 (getpoint "\n输入文字起点:"))
         (command "text" "s" "仿宋体" pt1 pause "0" "边钉") (print))
(defun c:T04(/ pt1 h) (SETQ pt1 (getpoint "\n输入文字起点:"))
         (command "text" "s" "仿宋体" pt1 pause "0" "杯头") (print))
(defun c:T05(/ pt1 h) (SETQ pt1 (getpoint "\n输入文字起点:"))
         (command "text" "s" "仿宋体" pt1 pause "0" "螺纹") (print))
(defun c:T06(/ pt1 h) (SETQ pt1 (getpoint "\n输入文字起点:"))
         (command "text" "s" "仿宋体" pt1 pause "0" "浮钉") (print))
其余的相同!
GMT+8, 2025-5-2 08:15 , Processed in 0.195736 second(s), 23 queries , Gzip On.
