查看: 1985|回复: 2
面积计算VBA代码myfreemind 问题
发表于 2005-7-1 12:52:00 | 显示全部楼层 |阅读模式
能不能没有比例尺的限制啊
  1. Sub  sarea()  '计算多边形面积程序
  2. On  Error  GoTo  err
  3. Dim  areaobj  As  AcadLWPolyline
  4. Dim  sset  As  AcadSelectionSet
  5. Dim  minpnt  As  Variant
  6. Dim  maxpnt  As  Variant
  7. Dim  areains(0  To  2)  As  Double  '
  8. Dim  txtarea  As  String
  9. Dim  txtins  As  String
  10. Dim  ms  As  String
  11. Dim  txtobj  As  AcadText
  12. Dim  us1  As  Integer  '比例尺
  13. us1  =  ThisDrawing.GetVariable("userr1")  '取得比例尺For  i  =  0  To  ThisDrawing.SelectionSets.Count  -  1
  14. ThisDrawing.SelectionSets.Item(i).Clear
  15. ThisDrawing.SelectionSets.Item(i).Delete
  16. NextSet  sset  =  ThisDrawing.SelectionSets.Add("sarea")sset.SelectOnScreen
  17. If  sset.Item(0).Closed  =  False  Then
  18. MsgBox  "图形不闭合,请检查!"
  19. Exit  Sub
  20. End  If
  21. sset.Item(0).GetBoundingBox  minpnt,  maxpntareains(0)  =  (minpnt(0)  +  maxpnt(0))  /  2
  22. areains(1)  =  (minpnt(1)  +  maxpnt(1))  /  2
  23. areains(2)  =  0Select  Case  us1
  24. Case  500
  25. txtarea  =  sset.Item(0).area  /  4Case  1000
  26. txtarea  =  sset.Item(0).area
  27. Case  2000
  28. txtarea  =  sset.Item(0).area  *  2
  29.   Case  Else
  30. MsgBox  "你的比例尺不在可计算之列,请检查你的比例尺"
  31. Exit  SubEnd  Selectms  =  Format(txtarea  /  666.6666,  "#0.000")
  32. txtarea  =  Format(txtarea,  "#0.000")txtins  =  "S="  &  txtarea  &  "平方米="  &  ms  &  "亩"Set  txtobj  =  ThisDrawing.ModelSpace.AddText(txtins,  areains,  5)txtobj.Color  =  acGreen
  33. '*******************************Dim  hatchobj  As  AcadHatch
  34. Dim  pname  As  String  '阴影名称
  35. Dim  pype  As  Long  '阴影类型
  36. pname  =  "ANSI31"
  37. ptype  =  0Set  hatchobj  =  ThisDrawing.ModelSpace.AddHatch(ptype,  pname,  True)
  38. Dim  outloop(0  To  0)  As  AcadEntitySet  outloop(0)  =  sset.Item(0)hatchobj.AppendOuterLoop  (outloop)
  39. hatchobj.Evaluate
  40. err:
  41. Exit  Sub
  42. End  Sub
 楼主| 发表于 2005-7-1 13:00:00 | 显示全部楼层
为什么非要加比例尺呢。 Case 1000
Case 2000
Case Else
'''MsgBox "你的比例尺不在可计算之列,请检查你的比例尺" txtarea = sset.Item(0).area
''Exit Sub end sub 是不是这样就行了啊
 楼主| 发表于 2005-7-1 15:55:00 | 显示全部楼层
能不能点他区域内就能得出面积啊。
GMT+8, 2025-5-2 08:33 , Processed in 0.146992 second(s), 23 queries , Gzip On.
