查看: 2156|回复: 0
VBA高手请帮忙
发表于 2005-6-20 09:55:00 | 显示全部楼层 |阅读模式
请VBA高手将这个LISP改写成VBA,急用。不胜感谢 defun dstbm ()
(setq mm (entlast))
(setq pb (entget mm))
(regapp "SOUTH")
(setq
xb
(append
pb
(list
(list '-3
(list "SOUTH" (cons 1000 stbmx))
(entmod xb)
) ;;;批量展测量点
(defun c:zdtxt (/ l wzcl wzch l3 oldcmd oldblip oldsnap tckz newlayer fle fn pt dm zb xyz h lscale xyz1 xyz2)
(setq l (getvar "ltscale"))
(setq wzcl (* l 2))
(setq wzch (* l 2))
(setq l3 (angle (getvar "ucsorg")
(getvar "ucsxdir")
(setq oldcmd (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq oldblip (getvar "blipmode"))
(setvar "blipmode" 0)
(setq oldsnap (getvar "osmode"))
(setvar "osmode" 0)
(setvar "angdir" 1)
(setq fle (getfiled "请选择数据文件"
"txt;dat;*"
2
(if (= (tblobjname "layer" "GCD") nil)
(command "layer" "n" "zd" "C" "1" "GCD" "")
(setq fn (open fle "r"))
(read-line fn)
(setq n 0)
(while (setq pt (read-line fn))
(setq dm (vl-princ-to-string (read pt)))
(setq zb (substr pt (+ (strlen dm) 1)))
(setq
xyz (trans (read (strcat "(" zb ")"))
1
0
(setq h (rtos (last xyz) 2 1))
(setq lscale (* l 1))
(entmake
(list (cons 0 "INSERT")
(cons 100 "AcDbEntity")
(cons 8 "GCD")
(cons 100 "AcDbBlockReference")
(cons 10 xyz)
(cons 41 lscale)
(cons 42 lscale)
(cons 43 lscale)
(cons 410 "model")
(cons 2 "gc200")
) ;"gc200"为块名
(setq stbmx (itoa 202101))
(dstbm)
(setq xyz1
(polar xyz (/ pi 2) (* l 2))
(setq xyz2
(polar xyz (* (/ pi 2) 3) (* l 2))
(entmake (list (cons 0 "Text")
(cons 8 "GCD")
(cons 100 "AcDbText")
(cons 7 "standard")
(cons 1 dm)
(cons 40 wzcl)
(cons 41 0.8)
(cons 410 "model")
(cons 71 0)
(cons 72 4)
(cons 73 0)
(cons 10 xyz1)
(cons 11 xyz1)
(setq stbmx (itoa 202111))
(dstbm)
(cons 8 "GCD")
(cons 7 "hz")
(cons 1 h)
(cons 40 wzch)
(cons 41 0.8)
(cons 410 "model")
(cons 71 0)
(cons 72 4)
(cons 73 0)
(cons 10 xyz2)
(cons 11 xyz2)
(dstbm)
(setq n (+ n 1))
(if (= pt nil)
(alert (strcat "*--*展点结束,共展"
(itoa n)
"个点*--*!。"
(setvar "cmdecho" oldcmd)
(setvar "blipmode" oldblip)
(setvar "osmode" oldsnap)
(setvar "angdir" 1)
(setvar "clayer" "0")
(close fn)
(command "zoom" "E")
GMT+8, 2025-5-2 08:34 , Processed in 0.162662 second(s), 24 queries , Gzip On.
