帖子
查看: 2165|回复: 2
用getentity选择实体时如何判断实体已经选择完了
发表于 2005-6-6 11:17:00 | 显示全部楼层 |阅读模式
在一个图形文档中,想用utity.getentity entobj,pntpic 选择实体加入到一选择集中,但不知道该如何判断实体已经被选择完毕了,请高手赐教,谢谢
发表于 2005-6-6 11:47:00 | 显示全部楼层
' Begin the selection
Dim returnObj As AcadObject
Dim basePnt As Variant
On Error Resume Next
' The following example waits for a selection from the user ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select an object"
If Err <> 0 Then
Err.Clear
MsgBox "Program ended.", , "GetEntity Example"
Exit Sub
Else
returnObj.Update
MsgBox "The object type is: " & returnObj.EntityName, , "GetEntity Example"
returnObj.Update
End If 当正确选择实体后,Err是为0的,由此判断.
发表于 2005-6-6 20:30:00 | 显示全部楼层
为什么不用SelectOnScreen方法?
GMT+8, 2025-7-8 13:14 , Processed in 0.188824 second(s), 23 queries , Gzip On.
