查看: 1755|回复: 5
怎样画出螺旋?
发表于 2005-4-27 07:38:00 | 显示全部楼层 |阅读模式
各位大虾: 我学习CAD有一段时间了,但不知怎样画出立体螺丝线来?
发表于 2005-5-1 18:58:00 | 显示全部楼层
不能在AUTOCAD中直接画出,一般需要编程。
发表于 2005-5-1 19:22:00 | 显示全部楼层
画出来都是近似的,看一圈有多少个控制点,说直观点就是多边形,根本做不出像平面圆那种精确的,最起码理论上是精确的
发表于 2005-5-2 09:30:00 | 显示全部楼层
Threads.lsp可以自动画3D solid螺纹。
 楼主| 发表于 2005-5-5 10:09:00 | 显示全部楼层
版主:
                                 你好,我加载成功后,不知输入什么命令才能画出立体螺丝?
发表于 2005-5-14 06:59:00 | 显示全部楼层
(defun c:tanhuang(/)
(setq p1 (getpoint "请指定螺旋线基点:"))
(setq r (getreal "请输入弹簧平均半径:"))
(setq d0 (getreal "请输入弹簧丝直径:"))
(setq disp (getreal "请输入弹簧节距:"))
(setq n0 (getint "请输入弹簧工作圈数:"))
(setq n (getint "请输入每圈细化段数 (32/36/40/44/48/52/56/60) :"))
(setq n1 (* 1.25 n)) ;支撑圈细化段数
(setq n1 (fix n1))
(setq n2 (* n0 n)) ;工作圈细化段数
(setq delta (/ (* 2.0 pi) n)) ;单位转角
(setq j (/ disp n)) ;工作圈轴向位移量
(setq j0 (/ d0 n)) ;支撑圈轴向位移量
(setq bb (caddr p1))
(setq ang 0)
(setq jj 0)
(command "ucs" "n" p1)
(setq pt1 (list r 0 0))
(command "3dpoly" pt1)
(repeat n1 ;绘制下支撑圈
(setq jj (+ jj 1))
(setq ang (+ delta ang))
(setq pt (list (* r (cos ang)) (* r (sin ang )) (* j0 jj)))
(command pt)
(setq p2 (list 0 0 (* j0 jj)))
(setq g1 (* j0 jj)) ;下支撑圈高度
(setq jj 0)
(repeat n2 ;绘制工作圈
(setq jj (+ jj 1))
(setq pt (list (* r (cos ang )) (* r (sin ang)) (+ g1 (* j jj))))
(command pt)
(setq p3 (list 0 0 (* j jj)))
(setq g2 (* j jj)) ;工作圈高度
(setq jj 0)
(repeat n1 ;绘制上支撑圈
(setq jj (+ jj 1))
(setq pt (list (* r (cos ang)) (* r (sin ang)) (+ g1 g2 (* j0 jj))))
(command pt)
(setq g3 (* j0 jj)) ;上支撑圈高度
(command "")
(setq e1 (entlast ))
(command "ucs" "x" "")
(command "circle" pt1 (/ d0 2))
(setq e2 (entlast))
(command "extrude" e2 "" "p" e1) ;拉伸弹簧
(setq e3 (entlast))
(setq pt2 (list r (/ d0 4) 0))
(setq py (+ g1 g2 g3 (- 0 (/ d0 4))))
(setq pt3 (list (- 0 r) py 0))
(command "slice" e3 "" "zx" pt2 pt3) ;磨平端部支撑面
(command "slice" e3 "" "zx" pt3 pt2)
(command "ucs" "w")
GMT+8, 2025-5-16 07:44 , Processed in 0.190006 second(s), 28 queries , Gzip On.
